Toshiba laptop 225cds
I just bought a used laptop for my daughter and it worked fine until I took out a cd and now it is frozen and just keeps beeping, It won't doing anything but beep, I have tried to turn it off but it just beeps. I am a single mom and not too computer friendly. I am emailing you on own my newer toshiba my family bought for me. Any suggestions, or did I buy a dud?
Thanks Cindy
    Genius:
  • 1,913 Answers
Hi
i open your rom lock and pull the rom.then simply reconnect it.
Posted on Mar 23, 2008
SOURCE:
MY TOSHIBA SATELLITE PRO LAPTOP WONT GO PAST THE WINDOWS XP LOGO SCREEN AND HAS BEEN FROZEN LIKE THAT FOR HOURS BUT THE LOADING BAR IS STILL MOVING
Hi Good day!!! Try to boot in safe mode, to boot from safe mode, do this: while booting just keep pressing f8 button until advanced boot menu appear after that choose safemode. after that your OS will boot in safemode. if not booting there should be a files missing in your OS you will need to repair it using a CD of you OS. reply to me to help you more
Thank you for using FixYA
Please accept if my solution helps you
Nov 24, 2010 | Toshiba Satellite Pro L300 Notebook
Does a Toshiba Satellite 225CDS come with a modem?
Yes of course.
All laptops come with a NIC (Ethernet) port and a modem port to. Their usually at the back of the laptop and are right next to each other.
Regards.
Jun 27, 2010 | Toshiba Satellite 225CDS PC Notebook
Toshiba laptop stuck
try to use the restore cd.. .. select boot from the cd/dvd and boot the repair features with the OS
look at the boot screen that initially shows up and get in the setup.... switch the cd/dvd to be the boot device that starts first...
run the cd/dvd installation normally until you find a repair feature.....
then follow the standard repair method
Sep 30, 2009 | Computers & Internet
Toshiba laptop frozen on logging off screen; won't switch off, nothing working. Tried esc, cad, now trying to run down battery. Any ideas?
I unplugged the a/c adapter, took the battery out then plugged in again and everything was fine. Otherwise, when I tried to turn off it would just sleep. But that's the way I solved it.
Jun 29, 2009 | Toshiba Satellite Pro A210-EZ2202X...
Dell Studio 1700 - dvd/cd will not work
Hello
i have the same laptop and you have to install it properly because vista needs time
Thanks
May 24, 2009 | Dell Studio 1737 Laptop
MS Office Home/Student 2007 Product Key!!! Thank YOU!!!
rggfv-3d7yq-qmyrk-4664w-9hy6d
or
KGFVY-7733B-8WCK9-KTG64-BC7D8
Feb 18, 2009 | HP Pavilion dv6326us Laptop
GATEWAY 7322
If you replace the HDD, there is no reason why system hung up. try cleaning your memory cause on that case i can pinpoint that memory something wrong. try cleaning memory fixed it again, if your don't mind maybe you need to replace the memory.
if the same happen, try examine CD Disc or your cd rom drive cannot read the files on the disc.
(Option solution)Examine your motherboard after clear prove that the above solution is not working. i can assure u that main board is good. if ever it was damage that causes overheating.
Jan 10, 2008 | Gateway 7322GZ Notebook
Toshiba p35-s609 laptop
Sounds like you have diagnosed your own problem to me. Its not the video card or you wouldn't be able to use the monitor, so it has to be a bad switch. If you can remove the bezel covering the switch you my be able to spray some contact cleaner into the switch and get it working again. Removal of most bezels starts with removing the screws on the back side of the lid hinges and lifting the bezell until it un-snaps from the housing.
Good luck. let us know how you make out.
Jan 06, 2008 | Toshiba Satellite P35-S609: Pentium 4-3.2...
Computers & Internet Logo
87 people viewed this question
Ekse
Alun Cox
