Question about Dishwashers
Fridgidair Dishwasher takes long time to run
I have an issue with a Frigidair Dishwasher, Model #: FDBB240FB0. The dishwasher is about 2 years old. It used to take about an hour and a half to run through the whole cycle, but now it takes over 2.5 hours. Also, there seems to be a problem with the soap dispenser, when the cycle completes, there is still soap running down... Thanks
  • 3,740 Answers
There are serveral things than can slow down a complete cycle.
1. A partially clogged drain
2. The timer motor is not functioning properly
3. A broken or worn pump impeller
Check your entire drain system. Start at the final outlet and work your way backward to the motor pump connection on the dishwasher.
Suspected areas are.
a. The sink connection outlet is clogged (this can be inside a garbage disposal.
b. The air-gap is clogged in the very top part of the air-gap (Usually located on the back of the sink and is around 3 inches tall) Remove the cover, unscrew the top nut and check under the horse shoe bend inside the plastic top for obstructions. Clean as needed)
c. There is debris on top of the the motor pump housing blocking the inlet drain. (This would be inside the housing of the lower wash arm on the very bottom)
d. The motor pump outlet drain port is partially blocked. (only accessable from the motor pump exit hole after drain hose removal.)
A partially blocked inlet tub drain to the motor pump would also explain your soap dispenser problem. Additionally you would have spotted dishes post cycle.
When the drain is partially blocked some models use the float level switch in the tub to control the advancement of the timer. If the water does not drain the motor pump continues to run and run and the cycle does not advance until the tub is drained and the float switch senses same. i.e extended cycle
Thanks for using FixYa.
Kelly
Posted on Apr 25, 2010
  • 523 Answers
Ok with the soap prime the sink before you start it and clean the dish washer.take a table sppon full of tang put it the dispencer and run the unit this will clean the unit
Frigidaire fghd2433kf dishwasher. less than a year old. flashed PF. the power hasnt been off. now whole unit is dead. no lights or movement.
Hello bidness_67 please check inside of the sink cabinet look for a switch on the back wall. If there is one flip it. Many new building electrical codes require a switchto turn off power to the dishwasher. Sometimes when putting items in the cabinet the switch is hit unknowingly. If there is no switch check outlets (the GFCI ones)and press the reset then check the dishwasher.if not those two items check breaker box for a tripped breaker.
Aug 15, 2011 | Frigidaire FGHD2433KF Builtin Dishwasher
My dishwasher (model # DU81ODWGU1) is leaking water and suds during the wash cycle. I ran out of dishwasher powder so I had used regular dish soap for this cycle. Did this cause the problem? My...
MOST DEFINITLY You can put regular dish washing liquid in a dishwasher will do that every time take a few washings to stop run 2-3 times empty it will stop.
May 06, 2011 | Whirlpool Dishwashers
Dishwasher only runs for 21 minute cycle
I bought and replaced the control board in the door. $145 CAD it took 5 min saved myself $300
May 07, 2009 | Dishwashers
Water on floor after Kenmore dishwasher runs
you could fix this, however the price of repair will be 1/2 of the price of a new dishasher.  I would suggest you buy a new oneand not waste money on a six year old dishwasher.  find a good scratch and dent model.
Mar 15, 2009 | Kenmore Dishwashers
While not in operation dishwasher slowly fills up.
water valve is clogged try to turn your valve to dishwasher under sink
Nov 29, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Maytag Dishwasher Model DWU9200BAB
Do you have an air gap between the disposal and the dishwasher? If not required raise the hose and as high as you can. It must be above the water level in the sink. Try attaching it to the underside of the counter. At some point the hose should be above 32 inches. It the problem is with the dishwasher itself. Don't fix, replace. They are not really designed to last over 10 years. The new ones , especially in the last year or two are a BIG improvement over any older one. So quiet you can't tell they are even running, they clean so much better and are much more energy efficient. Stainless steel interiors are just a fad. The plastic tubs are actually less likely to leak and are by there nature more quiet.
Jul 02, 2008 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
Asko Excellence Dishwasher Model # 1504
I have a manual for 1504 and it says F2 blinking means high water level in machine
Apr 15, 2008 | Asko W6021 Front Load Washer
Rusty dish rack
Clearly a design or manufacturing flaw. I have the same model and the rack is disintegrating after 6 years. I believe it is a manufacturing flaw. Our previous dishwasher rack lasted over 20 years in the same conditions. Same construction, vinyl covered steel. New upper and lower racks cost over 200.00 and there is no guarantee that this won't happen every six years. I recommend a new non-Maytag dishwasher as soon as you can. Meanwhile, limp along with the defective racks.
Oct 02, 2007 | Maytag MDB7100AWB Dishwasher
Dishwashers Logo
165 people viewed this question
Top Dishwashers Experts
