Question about ViewSonic VX912 19" LCD Monitor
My 19 inch ViewSonic monitor shows red /voilet
My 19 inch ViewSonic monitor shows red /voilet color on the whole sceeen , Look like there is a red transpernt glass covered in the screen. I tried to change the Monitor color options and Graphic card color options like Gamma and all . But no use.
Now what can I do .. Do you have any Idia why it came like this.
It started like , I was working on my pc first it suddebly changed to this Red overlay but it wents away after some time . This happend 4 to 5 times . after that it permanatly stays there :(
  • 11,361 Answers
Please check the VGA cable at both ends to make sure there are no bent pins and fit into the socket properly at both ends. Also try this monitor with other PC also since it can be in the video card.
Posted on Apr 26, 2010
My viewsonic 19 inches lcd monitor screen displays full pink colour..it happens for sometime and becomes normal alternatively...
If you are using a VGA cable (analog, rather than a digital DVI) you can try replacing the cable. sometime some of the lines will break in the cable causing it to lose some color channels. Try tightening the cable connections on both the monitor (if it is removable) and the PC.
If that is not the cause, your backlight could be worn out. Cold cathode tubes run more pinkish red the older they get. Once they warm up they may return to a more normal color temperature.
Jan 07, 2011 | ViewSonic VA1912w 19" LCD Monitor
Shaded areas on my X2gen 19 inch monitor do not Show up.
It sounds like the PC video color setting is at 16 instead of 24 or 32 bit color setup. You need to check the display properties setting on the PC (Right click on the desk top). Also try it on other PC and also check the VGA cable.
Apr 07, 2010 | X2Gen MG19MY 19" LCD Monitor
Viewsonic VP930b color problem - Red tint
Go to the setup menu on the LCD panel by pressing button 1 on the front. See if there is an option to reset the lcd to factory settings. Reset it and report if it helps not.
Jul 29, 2009 | ViewSonic VP930b 19" LCD Monitor
Viewsonic lcd tv 37"
try to check the RAM, video card, or processor maybe it is not properly inserted to the slot.
Jan 08, 2009 | ViewSonic A90f+ 19" CRT Monitor
Color
your monitor CRT gone bad.
Jan 20, 2008 | ViewSonic G790 19" CRT Monitor
ViewSonic monitor color red is orange
hi there, try replacing the video cable, you may have a one broken video cable, sometimes the pin is broke out. ty
Dec 26, 2007 | Acer AL1916W 19" LCD Monitor
Ps790 no red color
ur color ic is demaged replace it
Dec 07, 2007 | ViewSonic PS790 19" CRT Monitor
Red color problem
Could be a bad main board or a bad LCD panel.
Make sure your cable is not causing it by wiggling it at each end.
Check that none of the capacitors on the main board or power board are bad.
Call Viewsonic and find your closest service provider. Have them check on the price of the main board. If it's under $50 it might be worth buying to see if it fixes the ptoblem.
Nov 15, 2007 | ViewSonic VX924 19" LCD Monitor
Viewsonic VG919S 19" LCD
Hi
You must focus to mainboard of LCD monitor find the voltage regulator IC. Voltage test the regulator IC use digital or analog multimeter range 10v dc connect the negative to cold ground, these regulator providing a constant supply of 2.5 - 5v to all IC in the mainboard. check the scalar IC. Because scalar IC will convert analog input signal of Red, Green & Blue. Lastly check the controller board, check the ribbon cable connector from mainboard to
controller board for lose, check the fuse inside controller. I think the exact problem of your monitor could be either the (mainboard) or (LCD panel where the controller board is located).
Oct 06, 2007 | ViewSonic VG910S (Black, Silver) 19" LCD...
15 pin VGA connector damaged.
i want to know that what is the color combination of vaga cable connector
Aug 28, 2006 | SAMTRON 55V 15" CRT Monitor
ViewSonic VX912 19" LCD Monitor Logo
124 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
