Question about Canon Office Equipment & Supplies
How to change the ir 2200 to ir 3300 - Canon Office Equipment & Supplies
  • 149 Answers
Actually this is one thing that can't be done.... all the motors would have to changed. timing carts changed.... there is no upgrade kit for you to that unfortunatly
Posted on Jun 09, 2010
I need a I/R setup for these binos...do you have pr can you tell me where i can get one...thanks
Hello, contact Night Vision Optics they should be able to get you one. You can make your own by using an head light. Get an IR bulb, or change the lens to IR lens. If you want to high tech then get head light will IR LED's. If the white LED's are used don't use IR lens over this white LED's because of the light spectrum is different for the the LED's than incandescent light. They will have to be changed IR LED's..GB...stewbison
Jan 09, 2011 | Kalinka Baigish 12 Russian Night Vision...
My receiver doesn't receive any signal from the remote control
First of all check your remote with a IR tester. You can use your phone camera with the remote pointed to it for IR detection. This will confirm the remote. Now make sure that there is no loose components in the remote that have come off the board and changed the frequency. If so remove and re-solder.
Now check the IR detector in the receiver, use a multimeter to check the voltage on the IR detection as the remote is used. If there is no voltage check and change the IR, if not the signal track must be traced to the processor.- suspect the processor.
Jan 03, 2011 | Kenwood RCR0907 Remote Control
Hi I recently change the main board of my protron 32"pltv television and my remote control does not work anymore, do I need to change the IR remote receiver
You will need the scope to find out if the IR receiver is putting out the signal to the main board, or take a chance by replacing the IR board. Did the remote work before changing the main board?
Testing remote control:
The remote control puts out IR (InfraRed) signal that human eyes cannot see, to find out if the remote is sending out the signal or not you just point the remote at the digital camera’s Lens (Digital Camera can detect IR), you should see flashing light on the camera’s screen when any one of the remote button is pushed. If you do see the flashing on the camera, then the problem is in the TV IR receiver or the main logic board; more troubleshooting with scope will be needed to look at the signals.
Parts: www.shopjimmy.com
www.remotes.com
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Aug 12, 2010 | Protron PLTV-32 Television
Canon iRC 3380i error code E00025-002...help please?
Service Bulletin
Issued by Canon Europa N.V. Copier Color
HARDWARE
Revised:
Addition of the Affected Machines
Hopper Assembly
Subject:
Measures against E025 error due to toner leak
Detail:
<Symptom>
The toner leaking from the toner cartridge flows onto the inside toner sensor (PS3/PS4/PS5/PS6), causing erroneous
detection and E025 error (Error in the toner motor).
Model:
iRC2380i
iRC2880
iRC2880i
iRC3080
iRC3080i
iRC3380
iRC3380i
iRC3580
iRC3580i
Ref No.:
iRC3380-023 Rev. 2
(F2-T01-NO1-10097-03)
Date:
January, 2009
cartridge, the toner in the supply route between the toner cartridge and the
hopper may leak between the gap between the toner cartridge case and the holder of the machine.
<Factory Measures>
The gap between the toner cartridge case and the holder of the machine is covered with the plastic sheet and the shape
of the front unit cable guide on the toner sensor is changed to prevent the toner from flowing onto the toner sensor.
P-1 Position where the toner cartridge is installed
nside and replace the front unit cable guide into its new type.
Points to Note About Service Work:
When the front unit cable guide is replaced, implement periodic cleaning (every year) for the area around the photo
sensor (PS3/PS4/PS5/PS6).
For the affected machines or later, implement periodic cleaning (every two years) for the area around the photo
sensor (PS3/PS4/PS5/PS6) and the area of toner leak [1].
Service Parts:
Supply of the new part(s) will follow a normal supply pattern.
P-2 GUIDE, UNIT CABLE, FRONT
[2] Change Point
Parts Number Description Q'ty Interchange
ability Fig No.
Old FC6-9380-000 GUIDE, UNIT CABLE,
FRONT 1->0 N
620
New FC6-9380-010 GUIDE, UNIT CABLE,
FRONT 0->
and later IR C3580 230V EUR : CZS00218 and later
IR C3580I 230V EUR : CZT04670 and later IR C3580 230V : CZU00011 and later
IR C3580I 230V : CZY00752 and later IR C3580I 230V AU : CZZ00857 and later
IR C3080 UL 120V : DBE01554 and later IR C3080I UL 120V : DBF02861 and later
IR C3080 230V EUR : DBM00294 and later IR C3080I 230V EUR : DBN10330 and later
IR C3080 230V : DBT00011 and later IR C3080I 230V : DBU00714 and later
IR C3080I 230V AU : DBV01085 and later IR C2550 UL 120V : DCA03694 and later
IR C2380I 230V EUR : DCF16473 and later IR C2550I 230V : DCK00864 and later
IR C2550I 230V AU : DCL01033 and later
Jun 15, 2010 | Canon C3380i Color Copier
Why does my TV not respond to any remote, not even the original remote control. I'm unable to turn on or off or change channels. (Proview 3200)
It can be IR receiver is not working or the CPU is getting the signal from IR board but not processing the signal properly, you can try new IR receiver board.
http://www.shopjimmy.com/led-ir-assy-200-500-hx276-from-proview-3206.htm
Mar 13, 2010 | Televison & Video
Which one is better to buy IR 5075 or IR 5065
The all above models are same with minor change for speed
You need model as your daily output requirement
All models are heavy duty.
you can select any one for upto 10,000 print or copy per day or for 20,000 & up print/copy select ir 5075
Jun 15, 2009 | Canon imageRUNNER 5000 Copier
Error Code description
The Canon is coming on with a code E602-0003 can somebody please help it is only 9 months old and the company we bought it from is out of bussiness. Please email me @ reception@biscayneroofing.com
Thanks
Madlyn
Feb 25, 2008 | Canon (6981A002AA) for imagerunner 2200,...
Remote Sensor
Start a DVD playing, cover the IR sensor on the DVD player with something opaque. Try changing the volume, the player should keep playing. Your TV, surround sound, and DVD player have conflicting IR codes. The DVD player probably does not use a discreet IC to filter the IR sensor, and the processor in the DVD player is having to look at all the IR codes picked up by the IR sensor. Go to Walmart or KMart and buy a new DVD player for $29.00 or stop changing the volume while watching DVDs :) Sorry, there's no real solution that I know of. Paul.
Jan 01, 2007 | Norcent Technologies DP313 DVD Player
49 people viewed this question
old marine
old marine
