Question about LG WM2487H Front Load Washer
My LG Steam Waasher leaks when I use steam during a normal cycle. I can't figure out where the leak is coming from. It doesn't appear to be the door because there is no trace of water dripping down the front.
Have you tried cleaning the filter out??
Posted on Apr 25, 2010
Whirlpool duet dryer stuck on steam cycle
one trick to stop the steam is to remove the water hose connected to the dryer
Nov 20, 2013 | Whirlpool WED9500T Electric Dryer
2000 elantra white smoke during speed, doesn't start
White smoke normally indicates steam, did the car overheat ????...if it overheated check hoses for leaks,,,, loss of water etc
Jun 13, 2013 | 2000 Hyundai Elantra GLS
There is steam inside the microwave when my food is heating up. Is this dangerous?
If the steam is not leaking out of the microwave it is no problem. Steam is normal when you heat moist items. If it is leaking out you need to replace the door seal, but steam will not start a fire.
Feb 16, 2012 | GE Microwave Ovens
Coolant smell with steam
where ever u see the steam is ur leak-- steam is the coolant burning off usually wont show a puddle unless hose leak,or pump leak-- if the steam coming from tailpipe possible head gasket went
Feb 23, 2010 | 2000 Mazda 626
Is it normal to see steam coming out of the dishwasher in the drying cycle?
Yes, The colder the room its in the more steam you will see. It will look like more steam if sun light is shinning over it. Just like your clothes dryer blowing steam out side. Its just drying.
Oct 30, 2009 | Dishwashers
My Shark Iron leaks....
fill with water turn iron on max keep turning steam dial all the way to the right until you get to self clean hold iron horizontal and make sure you have a towel or something to catch water drips and debris coming out of iron let iron steam and spit water out until it stops on its own turn dial back to regular steam settings wipe residue off of the plate with a towel adjust temp settings back to normal
Aug 14, 2009 | Euro-Pro Shark GI490 Iron
When we open the freezer door, a lot of steam/smoke comes out. A lesser amount comes out when the fridge door is opened.
If the fridge is working and keeping things cold and frozen, you don't have a refridgerant leak that is producing vapor that might appear as steam or smoke.
The steam/smoke is actually water vapor being made visable due to the temperature difference between the freezer/fridge temperatures and the air temp in the room (or garage) the appliance is in.
It's nothing to worry about and is normally more likely to happen when the outside or house air temp is very warm (Summer months) and when the air is humid.
What's happening is the very cold and cool air is hitting and mixing with the much warmer and much more dense air (humid air contains microscopic water particles) when you open the doors, and is instantly being cooled. Thus it appears as thou the fridge is steaming or smoking.
Have a great day an hope this explains the situation. Best regards.
Jul 30, 2009 | GE Refrigerators
LG dishwasher is dripping water from vent onto floor
Good that it is working. Recommend you keep a lose eye on the vent on the bottom of the door panel. This model will probably begin leaking again if it has not been retrofit with a kit that LG developed.
Please open a new problem when it starts to leak and please provide the Model and serial number when you do. Good Luck!
Mar 24, 2009 | LG LDF6810ST Stainless Steel Built-in...
Steam coming out near bottom of door causing water to pool
Steam coming out is not normal and you should get it serviced soon. While not dangerous, it probably means that water is leaking inside the door panel from the "Hybrid Drying System" that is a feature which LG uses/touts. Other disheashers use a conventional condensing drying system.
The moist air enters through the internal drying system in the door panel, dry air is added from the outside air with the help of a fan and that air is routed though ducting down to the bottom of the door.
That system is clearly broken. If you have more questions on this, please reply. Good luck!
Mar 19, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
Bosch Dishwasher Door Leaking Steam
Pull the seal that is on the tank 1/2 way out then close the door. This will make sure the door is tight to the seal. This happens sometimes that the seal becomes flattened. I have been using this trick on Bosch dishwashers since this series came out in 1997.
Jan 06, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
LG WM2487H Front Load Washer Logo
137 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
