Question about NRS S129 - Starter Solenoid Switch, D984
Why do harley davidson starter solenoids keep going out?
  • 251 Answers
Hi, the main reason is the engine takes a lot of torque to crank it over therefore the starter solenoid is handling a lot of current(amps ) for the starter motor .
this is a link for a repair kit , i have fitted few and there very easy and straightforward to do .
hope this helps .
http://cgi.ebay.co.uk/Accel-Starter-Solenoid-Repair-Kit-for-Harley-Davidson_W0QQitemZ360244902004QQcmdZViewItem?rvr_id=&rvr_id=&cguid=e07087f91260a0aad234d794ffec53f0
Posted on Apr 25, 2010
1976 Harley shovel head,starter will not dis-engage keeps on turning over,new solenoid even if you by-pass the starter button it still does this
Pull the starter, take it apart, give everything a good cleaning, sounds like either the solenoid is hanging or there is a broken return spring
Jun 07, 2014 | 1993 Harley Davidson FXR Super Glide
Engine will not turn over, engine just keeps clicking
Hi Anonymous, and the usual suspects are:
1.Ignition/Light Key Switch not in IGNITION position.
2.Engine Stop switch in the OFF position.
3.Discharged battery, loose or corroded connections (solenoid chatters).
4. Bank Angle Sensor tripped and Ignition/Light Key Switch not cycled to Off and then back to Ignition
5. Starter control circuit, relay or solenoid faulty.
6. Electric starter shaft pinion gear not engaging or over-running clutch slipping.
For the prime suspect please visit the websitw below:
Harley Davidson Sportster error codes and how to access them
Good luck
Mar 30, 2014 | 2001 Harley Davidson XL 1200 S Sportster...
No start just clicks at starter 2002 flhtci
For a possible prime suspect please visit website below and good Luck.
Big Twin Carb EFI DTC Intructions codes Harley Davidson Forums Harley...
Jan 05, 2014 | Harley Davidson FLHT Electra Glide...
Starter solenoid bypass
Hi Anonymous, for more information about your question please visit the website below. Good luck and have nice day.
Harley Davidson Starter Solenoid Components
Jun 20, 2013 | Harley Davidson Motorcycles
Starter on 1982 Harley Dividson FXR keeps running
Sounds like your starter solenoid is sticking closed. Remove the positive battery post,and remove the solenoid. Most likely,the copper contacts inside are worn out.
Oct 04, 2012 | Harley Davidson FXR Super Glide...
Looking for a location
All Harleys built after 1989 had Nippondenso starters on them. The "solenoid" is actually part of the starter. It's the top part of the starter that is shaped kind of like a pentagon, five sided. The large battery cable connects here and then another cable comes out the other side of it going to the starter motor. Please post the specific problem you're having and maybe someone can help.
Sep 06, 2009 | 1993 Harley Davidson FXR Super Glide
Harley davidson won't start
Test for power to the solenoid when you push the starter button. This should help to eliminate the switch, relay,wiring etc. You can also run a jumper wire from the large (power) cable on the top of the starter to the green wire on the white connector on the end of the starter.
Nov 22, 2008 | Harley Davidson Harley-Davidson Motorcycle...
NRS S129 - Starter Solenoid Switch, D984 Logo
932 people viewed this question
Top NRS Electrical Supplies Experts
Craig Butler
Craig Butler
ken skalski
Gil Shultz
Are you a NRS Electrical Supply Expert? Answer questions, earn points and help others
