Question about Samsung V25 XVC 2800 Notebook
Switched its self off now it wont go back on - Samsung V25 XVC 2800 Notebook
  • 30 Answers
AC cord is damaged or battery, if not replace real time clock battery . then psu. then . . .
Posted on Apr 25, 2010
My whirlpool oven model RBD245 is locked after the self cleaning cycle, it does not heat up even if i open the latch with a tool?
Whirlpool have the self clean latch assembly solenoid go bad and wont return back to unlock the switch to tell the control is is no longer in self clean. Replace the self clean latch assembly or make sure the switch on the assembly is in the non self clean mode, If the oven starts working then you know the problem if it still doesn't work then there may be other issues.
Feb 13, 2014 | Whirlpool RBS245PDS Electric Single Oven
Side doors switch wont work / passager window wont open.
These power accessories are controlled by a computer module commonly called the body control module (BCM for short), the BCM has the ability to self diagnose, you need the Ford dealer to scan the BCM and make the BCM run an active self test, then the BCM will deliver back fault codes for what it Found wrong in the system while doing the active function self test. Guessing is really not an option here, parts are to expensive to just randomly replace in hopes of fixing the problem.
Jul 17, 2012 | 2000 Ford Windstar
COMPUTER SWITCHES IT'S SELF OFF AND WONT SWITCH BACK ON UNTILL YOU UN PLUG POWER SUPPLY AND RE PLUG POWER SUPPLY BACK IN?
Try new heat sync paste on top of the CPU and clean the areas of dust if any. Mine does the same thing I did this will all of my computers as well as all my clients computers as a preventive measure for overheating. Also it may be your power supply unit as well. So check out those two things and do necessary repair if needed that should solve the issue. It worked for me.
John
Apr 12, 2012 | Computers & Internet
Oven door is locked shut. Latch for self cleaning won't fully open. Thanks
FIRST TRY TO TURN THE BREAKER OFF FOR ABOUT 20 MINUTES, IF THAT DOESNT WORK YOU WILL NEED TO PULL IT OUT AND REMOVE THE BACK PANEL ( UNPLUG IT BEFORE YOU WORK ON IT) THEN LOCATE THE DOOR LOCK MOTOR AND ROD, SOMETIMES THE ROD NEEDS ADJUSTING, SOMETIME THE MICRO SWITCH ON THE MOTOR GOES OUT,, YOU CAN GET IT ULOCKED AND STILL USE IT, BUT YOU WONT BE ABLE TO USE THE SELF CLEANE,, YOU WILL HAVE TO FIND OUT IF IT IS THE MICRO SWITCH OR THE MOTOR AND RELACE THE PART BEFORE YOU CAN USE THE SELF CLEAN
Jan 19, 2011 | Maytag CWE4800A Electric Single Oven
My ge hotpoint self cleaning 30" convention stove
sonud likr the little switch in the door lock is stuck when you put it on self clean there is a switch that puts it in to clean and now its stuck try to give the top at front a light bang and see if that jars the switch if not that will ned to be located and eather replaced or buy passed
Nov 11, 2010 | GE Hotpoint 30" Self-Cleaning Freestanding...
My wall oven wont self clean because the automatic door lock wont lock what part do i change
Hi- The automatic door lock is a safety feature designed to prevent opening of oven door during 'self-clean', or as techs call it: 'self-destruct'. A previous full-power cycle has affected or destroyed a circuit or switch. The most common failures are the door switch, affecting the operation of door motor, or the control itself. - - -Start by replacing the door switch- available locally at an app. parts store. The electronic controls can also get 'cooked', causing a variety of faults, but these controls are expensive.------ On site diagnostics is needed many times. Remember---'self-clean' destroys circuits and controls eventually--every time. Don't let the salesman fool ya... Let me know if this info helps- have more if needed.  Thanks- Ed
Mar 16, 2010 | GE Ovens
Sony lcd projection tv in self diagnosis mode. 4 red flashes
This is a fan error take the back off the set and see if the fan is turning.
Sep 13, 2009 | Televison & Video
Samsung V25 XVC 2800 Notebook Logo
53 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
