Question about Frigidaire GLTF2940E Gallery 3.5 Cu. Ft. King Size Front Loading Washer
Frigidaire Washer Model FWT449GFS1
How can we put the Asmy-timer Knob which you pull out to turn wash cycle on???  The big know broke, we have a replacement but it appears that we need to pull out or remove more of the knob fixture. Part Number is 131446202
  • 1 more comment
  • cbish Apr 22, 2008
    took the top off but cant figure out how to get at the old knob to remove it.
  • lillianramsd Jan 29, 2009
    I have the same problem, except my model number is FWT 445 GES 1 (an older model, perhaps?). The centre shaft is black, not white, as described in the solution, and when I tried to turn it counterclockwise to loosen the rest of the broken knob assembly, nothing happened, it wouldn't turn. Any ideas? My replacement part number is very similar as well - 131446200
  • Anonymous Apr 24, 2009
    Fridgidaire Gallery
    I ordered the knob, but after looking at the washer I am not sure how to pull off the old know. Is there step by step directions?
    Thank you,
    Dan
Needlenose pliers grabbing the center shaft (white plastic around a brass center around a screw), turned counterclockwise will free the remainder of the broken knob and allow you to remove it and then screw on the new part.
Posted on Jun 26, 2008
The center knob screws off of a threaded shaft, counterclockwise. The outer dial you turn to set your wash cycle will now show an orange, tanged insert. You simply press in on both sides of the tang, at the same time, and pull the dial out. I've done it on the exact same machine
SOURCE:
I have a frigidaire gallery front load washer that won't start a regular wash cycle.When i select a regular cycle and pull up the start knob,the cycle light comes on and nothing happens.When i mov
Good Afternoon Leszek - Thank you for your question. Based on the symptoms you are describing it sounds like the unit has a faulty timer or a potential wiring failure. Try reprogramming the unit by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait approximately ten minutes and then turn on the unit. If issue persists, then at this point I strongly suggest reaching out to a professional that can accurately diagnose and repair the washer.
Jun 09, 2013 | Frigidaire Washing Machines
Frigidaire front loading washer model FWT449GFS1
For a repair manual, contact Frigidaire directly.
Oct 07, 2017 | Washing Machines
Washer Knob broke
You can use the knob to turn the washer to the correct cycle, and then use a pair of long nose pliers to gently pull the center hub out to start the washer. This is of course only a work around. I'll post more if I figure out how to fix this as well.
Jan 21, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
I have a Frigidaire gas dryer. First, the timer
check the ignitor element those go bad after long usage... if you see that when you turn the machine on and the ignitor turn red but the flame not start then you need to replace it.
let me know if it help you , if not let me know as well we will keep working on it...
Jan 12, 2010 | Frigidaire ATF6000ES Front Load Washer
Model FWT449GFS1 Frigidaire Gallery problems: roaring during spin cycle, worsening drum won't turn manually and this last run, was making sounds like slipping belt. During drain time, can hear coin in...
most likely transmission bearings are worn out (sounds like a jet plane taking off) unfortunately this requires replacing the transmission which is a costly job.
Sep 07, 2009 | Frigidaire ATF6000ES Front Load Washer
My frigidaire top loader fills with water at the beginning of the wash...then nothing. it just sits there full of water.
Hi, could be your timer motor, timer or water level switch, first push timer knob in and manually advance to wash or spin cycle (program) then pull knob, see if machine operates, let me know, then i can tell you exactly what's problem.also advance timer, to spin cycle (program) machine should pump out water, or you can lower drain hose into bucket and empty machine, you should empty machine and try again, let me know what happened, we can solved this together. good luck.
Aug 12, 2009 | Frigidaire FWS933F Top Load Washer
Kenmore Washer, Loose Timer Knob
There should be a spring clip that holds the timer knob on. It or the timer knob may need replaced. Here is a picture of the timer knob and the spring clip. Sure hope this helps and best wishes.
Jul 23, 2009 | GE WBSR3140DW Top Load Washer
Wash cycle knob turns without controlling wash cycle
it's possible go to www.repairclinic.com and enter the numbers you have posted and it will show you what they are. I have the same problem. What I did was not pretty but it works for now. I broke a piece off of your part#387997 and simply turn my dial that way and then pull the center out to start the wash. Considering a new timer is close to $100+ and it works fine this way , well you know...
Apr 06, 2009 | Washing Machines
Washer wont complete cycle. its full of water and I cant drain it
if this a manuel timer,,you either stripped the ,,knob,,or you broke the timer its self...make sure that timer can be pushed and pulled,, pull ----on push is off
Nov 30, 2008 | Kenmore 24902 Top Load Washer
Door Locked and wont open
Mine is crazy too! Sometimes, if I open the soap dispenser it will open, othertimes not. Sometimes, if I pull up on the big, round knob (that you use to turn on the cycle), because it gets stuck down. Once in awhile, I just put it on the last 2 minutes of spin cycle again.
Nov 16, 2007 | Frigidaire GLTR1670A Front Load Washer
Frigidaire GLTF2940E Gallery 3.5 Cu. Ft. King Size Front Loading Washer Logo
1,156 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
