Question about Pioneer GM-X324 Car Audio Amplifier
Pioneer gm x324, always on protection?
I have a pioneer gm x324, that always turns on, but goes directly to protection mode. whether or not any speakers or subwoofers are hooked up, i can't get any sound (due to protection of course). i looked inside to see if any transistors were burnt out, and noticed inside it, straight back from where the remote cable plugs in, next to a white arrow pointing to a screw, there are two holes where it looks like a piece was pulled out. it's labeled r641. any insight on this? there are no burn marks anywhere, maybe a little piece fell out at some point and it's messing with the whole amp? all i know is, if i can fix it, it will save me $150 worth of sending it to get fixed by the company...
  • 86 Answers
I have technics tx 30 amp wen turn up volume it goes into protection
Sounds like you should put the fan back then doesn't it.....?
Jan 04, 2014 | Pioneer GM-X524 Car Audio Amplifier
I have a pioneer gm-354 amp and the power indicater light on the front has changed from solid to flashing and no sound from the amp to the subwoofer it used to power any idea's
If it is flashing it went into the protect mode.Check that a speaker wire hasn,t come off, Or that the ground cable conection is good end all other hook up wires to it.
Oct 27, 2012 | Pioneer GM-X354 Car Audio Amplifier
Witch wire
i dont know what those 2 wires are for but if the amp cuts on and works just tape the 2 wires seperatley because that amp shouldnt even have those 2 wires
Apr 06, 2009 | Pioneer GM-X324 Car Audio Amplifier
Pioneer GM-D7400M power light keeps flashing?
ur rcas could b round the wrong way you might have a weak earth aswll
Mar 24, 2009 | Pioneer GM-D7400M Car Audio Amplifier
As i turn volume up amp either cuts off or act wierd
ur pushing to much power throught the amp shutting off the amp and the light might turn yellow on the amp if so then it is that reason
Nov 17, 2008 | Pioneer GM-X324 Car Audio Amplifier
Light flash power
Hi. You most probably have a power supply problem. Check capacitors and possible dry joints.
Sep 08, 2008 | Pioneer GM-X324 Car Audio Amplifier
Sub woofers dont give clear sound on high volume
THE AMPS PERFORMCE IS DIRECTLY RELATED TO THE STATE OF THE BATTERY AND THE CONNECTION FROM THE AMP TO THE BATTERY, CONNECT THE AMP DIRECTLY TO THE BATTERY TO SEE IF THE SAME PROBLEM EXIST OUTSIDE THE CAR
Aug 28, 2008 | Pioneer GM-X924 Car Audio Amplifier
Amplifier won't turn on
You need to confirm that you have voltage on the B+ and ground terminals and have a good ground.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
If all of that checks out, the amp probably has an internal fault (blown parts, broken connections...).
Let me know if you have any other questions.
Aug 24, 2008 | Pioneer GM-X324 Car Audio Amplifier
Amp cuts off
So you have an EQ and a Pioneer amp you're trying to hook up to each other? And only some Stinger RCA cable works? And when the lightning audio RCA cable is hooked up, it doesn't turn on? The amp isn't grounding itself through the RCA cables, is it? Check your ground wire and make sure it has a clean contact that's free of rust or any paint that might be in the way. Otherwise, the RCA cables should have nothing to do with an amp turning on or not.
May 07, 2006 | Pioneer GM-X324 Car Audio Amplifier
Pioneer GM-X324 Car Audio Amplifier Logo
209 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
