Question about HP Photosmart 3310 Printer
My hp 3310 is leaking the magneta ink inside the printer.
  • 1 more comment
  • muztambo Apr 26, 2010
    I have checked and cleaned the cartridge contacts
    and placed new cartridges were needed.the magneta ink is a new cartridge and still im getting a puddle of ink inside the printer.
    (HP 3310 ALIN ONE )
    I HAVE DISASEMBELED THE TOP OF MY HP 3310 AND REMOVED THE PRINTER HEAD ,IT SEEMS LIKE THE INK IS STREAMING OUT FROM THE BASE OF PRINTER HEAD.COULD THIS BE MY PROBLEM ?
    SO THIS MEANS IM REPLACING THE PRINTER HEAD?
    President:
  • 4,070 Answers
Hi! The waste inkpad may be full and this will require replacement. Its really gonna be messy till you replace the waste inkpad. Please have it replaced as soon as possible to avoid the hassles. HOpe this helps and have a good one!
Posted on Apr 26, 2010
  • dj_relly999
    dj_relly999 Apr 26, 2010
    Yes the base will be the problem. Its where the wastepad is located. Have this replaced and you'll be good.
  • dj_relly999
    Dont you worry about the head for I believe its still good. Worry about the wastepad that's full causing leakage from the bottom of the printer. You may replace the sponge (wastepad) or just clean it by drying it out so that it can absorb waste inks. This wont cost you, just a little patience and you'll be fine. This will work, always does.
  • 643 Answers
Welcome to fixya..
If your not getting any error codes on the Hp 3310,
then it would seem that you need to replace your cartridges.. ( the ones that are leaking)
its possible that a cleaning will help, and worth a try before purchasing the cartridge,,
the link below contains cleaning instructions for the cartridges on the hp3310
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00409514&cc=us&lc=en&dlc=en&product=439491
Posted on Apr 25, 2010
Hp Photosmart C5180 I am unable to get Light magneta and magneta cartridge to work. There is ink in the cartridges. All other work fine. the self test page shows no solid color bars under these two. I have...
Greetings the easy cleaning in the back of the cartridges have a metal connectors should be clean and not be exposed for anything ben ink. Well to solve the problem of the magenta who spends a lot is that you get a new cartridge and inserting it as many times you buy to fill and the ink is so solid that nothing comes out of ink.
Jan 29, 2011 | HP Photosmart C5180 All-In-One InkJet...
0xc18a0106 error from hp 3310 printer.... ink system has failed
That error code indicates a Ink system failure error message. Ink system failed mainly caused by your cartridge spitting extra inks into the copper contacts inside the printer. All you need is to remove all cartridge, clean the copper contacts at the back of it, clean also the contacts inside the printer (cartridge slots). Insert it back in after cleaning, unplug the power cord without turning off the printer, wait for 1 min before plugging it back in. Let me know the result.
Nov 23, 2010 | HP Photosmart 3310 Printer
Have a hp 3310 it says ink system failure error 0xc18a0106 it wont print,scan,copy and it does have enough ink. thank 4 ur help
Turn off the machine using the power button, unplug the power cord from the back of the machine, remove the ink cartridges, wait 2 min, plug the power cord back in, press the on button, wait until the printer prompts that the ink cartridges are missing, then replace the ink cartridges. If this doesn't clear the error then you may need to re-prime ink through the system to clear the error. There are good instructions for doing this at http://www.ccl-la.com/blog/index.php/hp-photosmart-ink-system-failure-1/.
Feb 20, 2010 | HP Photosmart 3310 All-In-One InkJet...
The ink seems to be bleeding all over the page and leaking inside the machine? Can anyone tell me if this is a common problem and how to fix it?
Hello my friend,open your printer and open your tray(the door),you will see the cartridges coming in the middle,you can check now if a cartridge blow up or your print-head destroyed
Jan 15, 2010 | HP Photosmart 3310 Printer
Ink is leaking
Is the printer in warranty or extended warranty, If yes then you will get a free replacement from HP, or try this bellow link:
http://partsurfer.hp.com/cgi-bin/spi/main
Aug 23, 2008 | HP Photosmart 3310 Printer
Not able to get printer to respond
Try the solution suggested by 'STP162'
I had the same problem with a yellow cartridge, and, fingers crossed, his solution appears to have cured it.
Thank you STP162.
Dec 11, 2007 | HP Photosmart 3310 Printer
HP Photosmart 3310 Printer Logo
444 people viewed this question
Seeker5211
Seeker5211
