Question about Seagate USB 2.0 External Enclosure + 400GB ST3400832A UATA 8MB 7200RPM HDD (NEWITEM31875736) Drive Case
External hard drive is not detected - Seagate USB 2.0 External Enclosure + 400GB ST3400832A UATA 8MB 7200RPM HDD (NEWITEM31875736) Drive Case
  • Meowmmm May 11, 2010
    Please clarify what is not detecting the drive, a PC, Mac or unit like Playstation 3? Also what OS you are using? I have all three and both the PC and Mac detect my Seagate external drive fine, but the PS3 will not recognize it as it uses NTFS and not the Fat32 file system.
    New Friend:
Please don't panic, you can open Disk Management to see if the external hard drive can be recognized. You can also try to connect the external hard drive through back USB port or connect it to another computer. If the external hard drive still cannot be recognized, probably there is something wrong with the external. In this situation, the most important thing is to recover important data from the external drive. You can rely on external hard disk data recovery software to perform data recovery: http://www.icare-recovery.com/disk-drive-recovery/external-disk-hdd-not-recognized.html
Posted on Jun 23, 2014
    Scholar:
  • 125 Answers
Check Following Instructions:
1. Check your USB cable properly connected to the computer.
2. Go to My computer - right click on property - Hardware - Devices Manager - in below - USB Mass storage device - right click on this - and Uninstall - then again right click - click on Scan - it should be reload your USB drivers
your External Hard Drive will be detected
Posted on Apr 25, 2010
How to fix my external hard drive not detected?
If a replacement usb adapter doesn't fix it, your hard drive has failed and usually not recoverable.
Jul 11, 2017 | The Computers & Internet
My external hdd from bytec is not recognized by my computer. What shall I do?
Try to use direct connection to your computer. Using IDE cable.
If your comp can detect, means your external casing problem.
If not detect, your hard disk problem
Jul 09, 2010 | BYTECC ME-740 Aluminum 3.5" Hard Drive...
G60-230US PC Notebook died. It reads: "No bootable device--insert boot disk and press any key" on startup. startup test failed: "there is no hard disk."
It means that your notebook is not able to detect any hard drives or a bootable drive
also plz check if there are any cd/dvd or any external devices like flash drives or external hard drives connected to the nb.. If so disconnect all the external devices and try to boot up ..
If it does'nt work go to the bios screen by continiously tapping F10 or F2 or DEL key as soon as you turn on the nb and check if the hard drive is detected or not.. if its not reset the hard drive and retry.. If the hard drive is detected run a hard drive self test if it fails.. replace the drive if it passes run system recovery
Hope it works
All the best !!!
May 06, 2010 | HP G60-230US Notebook
My seagate hard drive cannot be detected on the desktop anymore. Any ideas what to do? I have a Mac Powerbook G4
am not so sure if this is a similar issue with iomega external drive in which the drive wont show up on My Computer but when the external drive was plugged into an ubuntu machine the drive was being detected and working just fine.
Please try to do the same. plug your external drive to an ubuntu machine and lets see if it can be detected. If it is then the hard disk has a similar issue with iomega drives. check this link.
Apr 05, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
External hard drive not detected
Check your jumpers on the hard drive. DON'T leave it connected very long if the jumpers are not set for master / slave (furthest away/ closest to the IDE port on the computer or it can mess up the circuit boards on one or both drives! If you are using only one hard drive, set the jumper(s) for "cable select" (often abbreviated CS). If it still doesn't detect the drive, the drive may not have an "active" partition on it. You can solve that by booting to your OS installation CD -- assuming you have one!
Feb 02, 2010 | Western Digital Elements powered by WD 320...
Imac is not detecting my LaCie External Hard Drive
Do you have a CD disc software installer of your external hard drive (F.A. Porshe 160GB).? If you got it, you must reinstall it, so that your Imac can detect it. Otherwise, find it at the internet and download it.
The power failure could have damage some stored data about your External Hard Drive in your Imac. That's why, you have to reinstall it. Send us your e-mail comments for us.
Oct 17, 2009 | LaCie Design by F. A. Porsche 160 GB Hard...
PC wont detect external hard drive
Does the drive have a socket for external power?  or do you have a USB cable with 2 usb and 1 mini usb?
Sounds like it needs external power.
May 28, 2009 | Western Digital Passport WDXML800UE...
Can no longer recognize my external hard drive
I cannot get my computer to detect my external hard drive. It worked fine before? Now i get this clicking sound.Please help.
Nov 15, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Open Questions:
Computers & Internet Logo
633 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
