Question about Car Audio & Video
Is a metra electronics wiring harness model number 70-1857 able to hook up to a pioneer head unit model number deh 1100m?
  • danwettstein Apr 25, 2010
    thank you. do you happen to know a stereo that is relatively cheap that is compatible with the metra 70-1857?
    President:
  • 563 Answers
Hello.
The Metra 70-1857 is not compatible with the Pioneer 1100m.
Posted on Apr 25, 2010
  • Naajiyah Auladin
    Naajiyah Auladin Apr 25, 2010
    You can try the Bose stereo.
Pioneer DEH-3300 UB
Apparently, you have no power at the 12 volt battery/memory wire at the radio harness of the vehicle. This wire is white with blue in color.
Also, based upon your description, you have connected the battery/memory wire and the accessory wire of the radio to the 12 volt accessory (switched) wire of the vehicle. This wire is white with red in color.
Check the radio/ stereo fuse of the car. You may have blown the fuse during your installation.
You have no memory at the radio because when you turn off the key, you lose all power to the radio.
Also, I mentioned the wire colors just in case you used an aftermarket radio wiring harness. Make sure that the yellow from the Pioneer unit is going to the battery power source and, the red of the Pioneer is going to the switched power source.
Sep 12, 2012 | Pioneer Car Audio & Video
I Have a 2000 Impala without onstar, i tried to replace the in-dash radio with an aftermarket one, i bought an 80$ wiring harness for my car because of a chime and it came with 4 rca cables along with the...
The four RCAs are for the speaker outputs.They plug into the rear of the Pioneer unit (front and rear outputs). Also, you didn't mention the model number of the wiring harness (necessary to properly diagnose the situation) but, some these units have one or two philips head dials to adjust the volume of the stereo and the volume of the chime. These dials may be on the side of the unit or, oyu may need to open the casing to see them.
Jan 26, 2011 | Pioneer DEH-3900MP CD Player
DEH-1200MP to '95 ford ranger i would like to know how to install it successfully and what sort of adapters and harsnesses i will need
Metra part numbers:
  • dash kit \ 99-5802
  • wire harness \ 70-5600
the dash kit comes with specific instructions and on the pioneer harness and metra harness just match all the colors up and your done
Jun 14, 2010 | Car Audio & Video
I have a metra turbowire 70-1857 wiring harness, and i am lost at connecting it to my pioneer aftermarket DEH-1100MP. I have the harness hooked up to the amp in the trunk. and strung through car and in the...
well head units usually dont have just rca inputs....but the outputs can be changed to rca style with adapters. the speaker level outputs are what you need to change....good luck
Apr 25, 2010 | Metra Turbowire 70-1857
HOW TO CONNECT PIONEER DEH-P4700MP TO 91 MAZDA 626
Hello pleazallnite,
Here's a link to the wiring color code for the Mazda 626. This link is to downlaod a copy of the DEH-P4700MP owners manual. The wiring diagram is on page 50. You can simply connect the wires by function to the vehicle wiring. But a better solution to avoid cutting or tapping into the vehicle wiring is to purchase an aftermarket wiring harness. The Metra part number 70-7901 appears to be the correct harness for your vehicle and is available from Crutchfield for $12.99.
Hope this helps.
Jun 14, 2009 | Pioneer DEH-P4700MP CD Player
Problems with Metra METRA PR01-0001 PIONEER 16-PIN UNIVERSAL WIRING HARNESS?which wires are which
I don't know what pins are what on the METRA harness, but the wires coming from the back of the Pioneer unit should be:
black ground
red accessory (KEY)
yellow memory constant power,
blue is remote,
orange is for the dimmer,
green with black is left rear neg.and green is positive,
violet black is right rear negative and violet is positive,
white is left front positive and white with black is negative,
gray black is right front negative and gray is positive.
If you don't have the pioneer harness (and so these wire colors dont' mean much to you) just message back here, and I'll map those wire colors to pin positions on the back of the unit.
May 21, 2009 | Pioneer DEH-1500 CD Player
Radio connection Pioneer vs Subaru Forester
I would like to refer you to a reputable car audio dealer.
If you have NOT yet CUT THE FACTORY HARNESS, DON'T!!!!!!!
Airbags are nothing to take lightly...
I HIGHLY RECOMMEND a wiring harness adapter from a reputable source such as METRA, Scoche, or Pozitive Connections. Every wiring harness adapter changes the colors at the "pioneer side" of the harness to color match the PIONEER RADIO. All you have to do is color match, plug and play.
HOPE I HAVE HELPED.
Scott
Sep 27, 2008 | Pioneer DEH-2800MP CD Player
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
