Question about HP Compaq WF1907 Monitor
I've got an HP WF1907 19" monitor with a bad AC power connector. It only works when the AC cord is in exactly the right position, angle-wise. I don't know how to get the casing open. If I could, then I could fix it myself. Pixels are okay and I don't think we got an extended warranty on this beast. I can't see any way to open it up without removing the upper "cap" on the unit, but I don't want to break anything. I've heard that these things are a bit delicate, and don't want to have to replace it.
  • 11,361 Answers
You need to use flat blade screwdriver, starting at the bottom edge first, once you get it open enough, lay it face down and try lifting the back cover up, be careful on the front panel cables. There is not much you can do to not scratch up the monitor a little bit, they just do not make them to be repaired these days, look for bad solder joints on the power board.
http://s807.photobucket.com/home/budm/allalbums
Posted on Apr 25, 2010
Need 3pin connector for Salton glass hot tray 3028 (HA2) Type B
I found the hot tray you are referring to and looked at the 3 pins on the tray. They look exactly like a power cord for a monitor. If they are the same size, they would work. If this helps, don't forget to mark as helpful Check these ebay search results, you may have to scroll down a little to find the ones I am talking about 198results for 3 prong ac monitor power cord.
Jul 01, 2014 | Salton Elec Food Warmer Warming Hot Tray +...
I NEED APOWER CORD FOR DAEWOO L950
I can't find information online about your monitor, so I'll give you a generic answer for all monitors.
Almost all monitors use a C13 cord - the same kind used for a desktop computer. Some use a C7 (two-wire, like that used for some name brand laptop adapters) or a C5 (three-wire, used on other laptop adapters)
C13 image:
C7 image: ac15wna-r.jpg
C5 image:
These images were lifted from the Mouser Electronics website (AC Power Cords Mouser ). They also carry C13 cords with right-angled plugs, which may be more convenient with some monitors.
There are a very few monitors that use an external power supply, which is like a laptop computer power adapter. If this is the case, the voltage and current requirements for the power supply should be on the label on the back of the monitor, and the only other thing you have match is the plug on the power adapter output cord (it needs to fit the power jack on the back of the monitor). Note: the voltage of the power supply must be the same as that shown on the label (usually 12 VDC) and the current rating must be the same or higher. If you don't see the voltage and current listed on the label, look closely at the power jack - the numbers may be molded into the plastic next to it.
It is rare to find a monitor with a permanently attached power cord. If this is the case with yours and it is damaged, do not attempt to splice it outside of the monitor. Put a replacement plug on if the good part of the cord is long enough, and use a good extension cord. Otherwise, you should open up the case and replace the entire cord. You will probably have to get a connector for the part of the power cord inside the monitor also. (If you are good with soldering, you may be able to splice to this connector, using heat-shrink tubing to insulate the connections.)
May 08, 2014 | Daewoo Computers & Internet
Nc6000 when ac disconnected, computer shuts down even though battery charged 100%
Hello, if on XP, go to control panel and open up 'Power Options' and look to increasing the 'Running on batteries' settings. However, you don't say whether it will power up without the mains connected...if it doesn't then maybe you've a bad/poor battery connection, ie it will display a voltage to the monitoring system, but won't allow any current to be drawn....this could be due to a bad connection so it may be worth removing the battery, taking a look at the connectors (maybe wipe them clean) and then refit and try again. Best of luck Nicam49
Jul 27, 2011 | HP Compaq nc6000 Notebook
I need an internal pin out diagram for a 4 Pin connector to connect power supply to a hp pavillion f70 monitor. I do have a power supply with same specs but it has a normal plug with outer as +ve and Inner...
12 VDC , 4.16 A (4,16 A) Frequency: 50/60 Hz Power Consumption: less than 36 W in operating mode.
I think the other two pins are not used. It just requires the 12 Volts DC. +ve and -ve, positive and negative, respectively.
Feb 10, 2011 | HP Pavilion F70 17" Flat Panel LCD Monitor
I have an HP vs17e flat sceen monitor that will not power up. Checked the power supply cord and it is fine, just acts like it is not getting power ????
I'm working on exactly this board right now, same problem. Two of the capacitors (c822 and c824, right at the top edge center of the board) are bulged and blown, causing my power-fail situation. They're available for about thirty cents a capacitor from any specialty electronic place. Piece of cake to solder in with the right tools and a bit of care. Hope it might be another clue to your problem. Good luck.
Nov 12, 2009 | HP w1907 LCD Monitor
Hp w2207h screen in blank but flashlight shows icons are
The power supply-inverter board is probably at fault. Remove the back cover and locate the standard ac power cord connector. The board that the power input connector is soldered to is your power supply - inverter board. Check the electrolytic capacitors on the board. They probably went bad. A visual inspection is usually enough to find out which ones are bad. They will be either bulging or cracked at the top and leaking fluid. I usually replace all of the capacitors that have the same rating whether they look bad or not. Will save you another repair later. If the caps don't look bad, you can take the board to your local tv repair shop and have the caps checked with a esr tester. It's more accurate and they can be tested with the caps in place. Hope this helps.
Oct 10, 2009 | HP Computers & Internet
Replacement AC/DC cord to power up my 1730B comp monitor
You cannot use a VGA cord to power a monitor. That is the cord that connects the monitor to the computer and is not the power cord. Almost all monitors use the exact same 3 prong power cord. Any computer shop will have a used one on hand.
Sep 06, 2009 | Solarism LM-1730 (Black) 17 in. Flat Panel...
No plug in play... don't think their dead... do I need drives first?
no country stated or if not usa what is your line power?(volts AC)
your PSU is inside monitor not outside, so uses a simple line power cord. (just wires)
12 year old monitors, found, (dead)
page one of your user guide is clear, read it yet?
seems not.,
Auto-ranging, 90 to 265 VAC
1280 x 1024 @ 60 Hz, 75 Hz (never higher) resolution settings.
those are very old monitors.. worth like $10 used.
if the power lamp shows wrong, the monitor is dead.
right button is power to the right of it is a power led that must glow.
the old monitors had CCFL backlamps before year 2010.
those are back lamps, that fail fast. 20k hours, fast. (short)
first is the power switch
2nd is a working PC with at least sync signals on 2 pins
Horz/vertical.
then the OSD screens work of not the monitor IS DEAD.
inside this OLD monitor is sleep time, turn if off with OSD menu's its nothing but trouble.
some have an OSD lock, so hold the menu key for 10 seconds
and it unlocks. button 2 from left is MENU.
see page 4-10
the guide is here. not too good , poor diagnosis sections
http://h10032.www1.hp.com/ctg/Manual/c00276671
specs.
https://support.hp.com/us-en/product/hp-l1940-lcd-flat-panel-monitor/427303/document/c00278650#AbT3
testing
power it on, LED power , glows.
with a PC working, say running any BIOS screen only....
or running, windows, in low resolution mode 1280 x 1024
if wise set the pc up to that first. not second.
then plug in the vga cable so the MOnitor only sees that signal above. (if you do above wrong, monitor shows OUT OF RANGE on the screen)
at mon.
PUSH the OSD button, menu, if OSD is dead the montor is dead.
OSD= on screen display., (yes the LDC has brain inside)
then take a flash light . point it at screen
see data now, if yes, in the beam is data the back lamp is dead
as are most 12 years old montors now.
see those 4 cream colored connectors bottom of this PCB
those are the high voltage CCFL lamps.
2 lamps 4 ends. the lamps are bad or the board 500 to 1000vdc
power supply is dead.
Sep 20, 2017 | HP L1940 19" LCD Monitor
SyncMaster 510N 15
It might be the connection loose of power cord problem or check your TFT power connector inside the TFT if you can open the TFT screen!!! It may be dry solder….
Other wise go to repairer and do the same….!!!
Dec 06, 2007 | Samsung SyncMaster 510N (Silver) 15 inch...
HP Compaq WF1907 Monitor Logo
417 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
