Question about Dell 924 All-in-One InkJet Printer
Ink cartridge levels
Installed the printer with no issues but the ink levels are showing empty so will not print?
  • 41 Answers
If you refill your own ink cartridges the instructions tell you to ignore the low ink messages, so that should not prevent it from printing.
Posted on May 23, 2008
I've just installed both cartridges in my lexmark X4650 printer but they show as empty on the maintenance page
Note that a refilled cartridge will not be able to report its ink level. Check if correct ink level is displayed on your printer operator panel. Press Setup button > Maintenance > Ink Level - check your black and color ink levels. If ink levels are correct, then the problem could be on your computer.
The Print Spooler service on your computer may be disabled. To enable the Print Spooler service, follow the steps below:
  1. Browse to Start -> Run... and type in "NET STOP SPOOLER" (this will stop the print spooler service)
  2. Type in "NET START SPOOLER" (this will restart the print spooler service)
Try to check your ink levels again.
Jun 25, 2011 | Lexmark X4650 InkJet Printer
My hp deskjet 6940 inkjet printer doesn't show me level of ink in cartridge
Print a diagnostic page If the steps above have not helped, print and evaluate a diagnostic page to see if the cartridges or the printer is causing the problem.
  1. Make sure the printer is on and loaded with unused, plain, white paper.
  2. Press and hold the Power button and then press the Cancel button. Release both buttons. The diagnostic page prints. Figure 1: Power and Cancel buttonsc00584735.gif 1 - Cancel button 2 - Power button
Step 4: Note which cartridges printed which areas of the diagnostic page You must identify which cartridge printed which part of the diagnostic page, so that if you find defects on the page, you will know which cartridge is the problem. However, you can install different combinations of print cartridges in your printer, and different cartridge combinations print different diagnostic page patterns. Your diagnostic page may not look exactly like the picture below, but the right and left cartridges will print in the same areas of the page no matter which cartridges are installed. Figure 2: Diagnostic page layout (the patterns in each area may look slightly different on your page)c00584715.gif 1 - Printed by the right cartridge 2 - Printed by the left cartridge NOTE: If you are printing in reserve mode (one cartridge is missing), the missing cartridge's area of the diagnostic page will be blank. Step 5: Check ink levels NOTE: If you have installed a refilled or remanufactured ink cartridge, or a cartridge that has been used in another product, the ink level indicator is inaccurate or unavailable. Look in the middle of the diagnostic page. The bars with "E" (for "empty") and "F" (for "full") at each end show the ink levels in the cartridges. As ink is used, the solid color changes to a faded color. Figure 3: Left (tri-color) cartridge almost full - right cartridge emptyc00235259.gif Figure 4: Both left and right cartridges almost fullc00235260.gif
Feb 22, 2011 | HP Deskjet 6940 InkJet Printer
Installed new ink cartridges mx 300, compatible B&W 40, color 41, printer status still says low ink, printing as if it is low ink. properly installed, tape removed, what i miss? can I check something...
Do you know what?. As a matter of fact,it is not compatible cartridges you buy. It is refurbished cartridges that repackaged with other brand as if this is their product. I say it is original cartridges that once empty and repackaged. So that's why when you install the cartridge the ink level stays low. You can make it sure by comparing it with new original cartridge. Find original cartridge,may be you can borrow from someone,which ink level still full and install on your printer. I am a hundred percent sure ink level will show properly :).
Feb 19, 2011 | Canon MX300 Office All-In-One Printer
When i gave print from doucment machine takes paper and give it as it as blank, solve my problem,
Solution one: Check the ink levels To allow for full use of the cartridges, some printers continue to print even after the cartridges are completely out of ink. Follow these steps to check the ink levels in the Toolbox . The Toolbox is part of the standard printer software. Depending on the version of Toolbox on your computer, the appearance of the Toolbox features might vary. NOTE: Ink level warnings and indicators provide estimates for planning purposes only. When an indicator shows low ink levels, consider having a replacement cartridge available to avoid possible printing delays. Print quality deteriorates as cartridges run out of ink.
  1. Click Start .
  2. Click Printers and Faxes .
  3. Right-click the icon for your printer (c01532298.gif ), and then click Printing Preferences .
  4. Click the Features tab.
  5. Click the Printer Services button. The Toolbox window opens.
  6. Click the Estimated Ink Levels tab. A window opens that indicates the estimated ink level of each cartridge. NOTE: Depending on the printer, the estimated ink level indicators can vary in appearance. Examples of estimated ink level indicators c01867289.gif c01867290.gif
  7. If the ink level indicators show that a cartridge is low or empty, replace the cartridge.
  8. Try printing again.
  • If these steps resolved the issue , you do not need to continue troubleshooting.
  • If the issue persists , continue to the next solution.
Solution two: Restart the printer Restarting the printer might clear the issues and allow the printer to function correctly again.
  1. Press the Power button (c01602202.gif ) to turn off the printer. NOTE: Pressing the Power button might not turn off the printer. This might happen if the printer is in an error state. Continue with these steps regardless.
  2. Disconnect the power cord from the back of the printer. Figure 1: Disconnect the power cordc01869581.gif
  3. Disconnect the USB cable from the back of the printer. Figure 2: Disconnect the USB cablec01850063.gif
  4. Wait 30 seconds.
  5. Reconnect the USB cable to the printer. Figure 3: Reconnect the USB cablec01868577.gif
  6. Reconnect the power cord to the printer. Figure 4: Reconnect the power cordc01869582.gif
  7. Press the Power button (c01602202.gif ) to turn on the printer.
for more information see this page
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01892627&lc=en&dlc=hu&cc=hu&product=1138373#N46
i hoprt his helpful
thank you for using fixya
Feb 15, 2011 | HP Officejet 4355 All-In-One InkJet...
I replaced an ink cartridge because the printer stopped working and showed a message that the old cartridge is empty. However after putting the new one in but the printer still refuses to work and shows...
maybe the cartridge is wrong, release it and clean the electrical contacts, put them again one by one, if notting happen, try this
Solution As the printer operates, it moves ink from the ink cartridges into a printhead reservoir. The printer does not deliver a message when an ink cartridge goes empty, because it still has ink in the reservoir. The printer continues printing until the ink level in the reservoir falls to a first trigger point - then a message appears advising the printer owner to Replace Cartridges Soon . At this point, other cartridges that are empty but have not reached the trigger point are also mentioned in the message, to save trips to the retailer. After the first trigger point, the printer can continue printing until ink levels in the reservoir reach a second trigger point. At the second trigger point there is only enough ink left to perform vital servicing tasks, and a new message appears, saying Ink Cartridges Empty . The options offered depend on the usable inks remaining. If no options are offered, the cartridges indicated must be replaced before printing can continue. The Ink Cartridges Empty options are described in the table below: Ink colors out Option Print mode possible All Cancel None Black
AND
Cyan, Magenta, or Yellow (any or all) Black only Continue with other colors Cyan/Magenta/Yellow mode (composite black)
Text and photo quality will differ from those printed when all colors are available Light Cyan or Light Magenta (either or both) Cyan, Magenta, or Yellow (any or all)
(Black still available) Print with black ink only Grayscale
Apr 07, 2010 | HP Photosmart 3210 Printer
When we do a fax test, we get clear print; when we try to print documents nothing appears, altho it goes thru all the right sound motions
Sounds like your colour cartridge is empty. Fax test will pull from black only but documents sometimes use a combination of colours in order to print out black. I suggest checking your ink levels - instructions for windows;
Check ink levels
NOTE: If you have installed a refilled or remanufactured print cartridge, or a cartridge that has been used in another printer, the ink level indicator will be inaccurate or unavailable.
  1. Open the Printer Toolbox . There are two ways to do this:
    • Open HP Director , select the Settings menu, then the Print Settings submenu, and finally the Printer Toolbox .
    • Open Printers and Faxes in the Windows Control Panel , then right-click your printer icon and choose Properties . Click Printing Preferences . Click the Services tab, then the Service This Device icon.
  2. The Printer Toolbox opens. Click the Estimated Ink Level tab. A cartridge may be running out of ink even if the graphic shows ink remaining (see the note at the start of this section). Lines or streaks always appear in printouts when the cartridges begin to run out of ink. Replace print cartridges that are out of ink or low Check ink levels
Mar 05, 2010 | HP Officejet 5610 All-In-One InkJet...
With new cartridge indicates low ink level,
The ink level gauge may not work properly with refilled cartridges. Because of this, you might get low ink message after refilling. To install the refilled cartridge you might need to override the ink level gauge. Overriding the ink level gauge disables the printer’s ink level tracking feature, but allows you to use refilled cartridges. To override the ink level gauge, please check your printer reference guide. After disabling the ink level tracking feature you should check the ink level visually and as soon as the ink level gets low you need to refill the cartridge. You do not want to try to print with an empty cartridge. Trying to print with an empty cartridge may damage your print-heads.
otherwise you will have to replace the cartridge .
Oct 21, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
My canon mp140 shows E4
From CANON FAQs for your printer:
Issue: ERROR LED: E, 4
Solution: Press and hold Stop/Reset button for at least five seconds.
Clearing the Ink Error If you want to continue printing in this condition, press and hold the <Stop/Reset> button on the printer for at least five seconds, and then release it. Replace the ink cartridge and close the Scanning Unit (Printer Cover).
If printing is in progress and you want to continue printing, press the Stop/Reset button for at least 5 seconds with the ink cartridge installed. Then printing can continue under the ink out condition.
The function for detecting the remaining ink level will be disabled.
Replace the empty ink cartridge immediately after the printing. The resulting print quality is not satisfactory, if printing is continued under the ink out condition.
Apr 01, 2009 | Canon MP140 PHOTO AIO All-In-One InkJet...
Printer level gauge shows cartridges aas empty even when they are
hi,
many times the ink gauge is not true, if u wanna see the actual level of ink, try to print the self test page..........
regards,  raj_p5983
Jan 21, 2009 | HP Photosmart C5280 Printer
Refilled black ink before it ran out-now can use at all
After hours of reading about this I finally found the solution. This will NOT reset your levels but you will be able to print without being told you have empty levels.
Start, Control Panel, then Printers and Faxes.
On the next screen, Right click on your printer then on Printing Preferences. Now select the Advanced tab.
Near the bottom left, you will see more options. Click that and then Appearance. Check NEVER display printing status and make sure under Complete-A-Print, all is unchecked. Click OK at the bottom.
You can print without the stupid messages coming up. Dells printer ink cartridges have a computer chip in them and the refurbished ink does not which causes these error messages telling you your ink cartridges are empty.
Jan 14, 2007 | Dell 924 All-in-One InkJet Printer
Dell 924 All-in-One InkJet Printer Logo
74 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
