Question about Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0 Tecumseh Engine
My tiller does not seem to be cutting deep enough
I have made dozens of passes on the same section of ground and have barely made a dent.
  • 1,498 Answers
Hi there kimberly,
Here's what you need to do.
  • Make sure the depth stake (behind the tines) is up as high as it will go. This will allow the tines to go deeper.
  • Fire it up. Set the tine rotation to reverse (more mixing and twisting.
  • Make sure the tines are actually turning, Each side is held in place with a shear pin. In case something binds the blades, this pin breaking will save the drive train
  • Note how the tiller is balanced. Wheels in the middle. You can tilt it forwards or backwards.
  • Tilting forward allows the wheels to gain traction and move the unit forward
  • Tilting Backwards allows the tines to dig in. If the surface is too hard, Press down with your body weight. It will dig through.
I hope this work out for ya
Best regards
Mike
Posted on Apr 25, 2010
Engine cuts out when tiller arm lifted. Starts and ticks over fine. The tiller arm seems loose could this be the problem.
Sounds like the tiller arm has a Kill switch in the end to shut the motor off. If it does there are two black and yellow wires in there and they are shorting to ground or to each other when the arm is lifted. This would shut the motor off when the are is lifted. The black and yellow wire is the kill wire on most outboards. If it grounds out and the engine will not run.
Apr 19, 2015 | Boating
Honda mini tiller cuts off when start tilling. runs great when held above ground with no load. cut off seems to be associated with the movement and shacking when tilling ground.
Hi thermo259, sounds like the high speed adjustment is lean, find the high speed screw and turn it counter clockwise 1 half turn and see if that helps. Should cure it.
Dec 10, 2010 | Honda 25cc 4-cycle Mini Tiller
Tiller running off, can't control it.
Slowly lower your tilling depth regulator a little at a time. Make a pass or two with it set almost as high as it will go then drop it a couple of notches and keep making more passes over the same ground. If you lower the tines to far down on hard ground it will just take off like you are describing. Just take it slow until you get your ground worked up and then it will work great.
Frank
Jun 09, 2010 | Troy-Bilt Pony Garden Tiller
Troy bilt jr tiller
If you try to till too deep, this is what will happen. You have to start shallow and and gradually lower the depth on subsequent passes. That will even happen on my 'Horse' model if I try to go too deep too fast.
May 25, 2009 | Troy-Bilt Pony Garden Tiller
Do you need to add to front of tiller
Hello:
No.
Usually the Weight of the Unit is Enough to Bury the Tines well into the Ground.
Make Several Passes if the Ground is Hard Packed Soil.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
John
May 08, 2009 | Garden
I bought my troybilt rear tine used. When I use it to till new ground (sod) it cuts fine for a few feet, then without warning, it gets on top of the ground, and I can't do anything to make it cut. The...
Hello, I think if you look at the depth setting bar you will find it clogged up with grass and roots. Once it clumps up you can't get it to drop to depth to make the cut. There are two speeds for the rear times for the toller which will make it go forward more slowly and allow the dirt clods to break up better. Also cut the grass as short as you can, make a shallow pass with the tiller 1" to 2 " to cut the heads off the roots and then go to depth with your next cut. This should pretty much break up the cloding when doing the tilling. Also watch it because it is hits a rock it will jump up and drag you away at the speed of the tines, because it lifts the drive wheels off the ground and the times drive the tiller instead. Other than that mine used to chew up everything including wet DG. Good Luck, RAC
Mar 31, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
WHEN TILLING TILER WONT MOVE FORWARD WHEELS JUST SPIN. HAVE TO PICK UP ON HANDLE TO GET IT TO MOVE.
Usually this means you are trying to dig too deep in one pass. Try setting the depth such that your first pass only scratches the surface, dislodging grass, etc. Then, on successive passes dig 1-2 inches, this will prevent the tines from "biting off more than they can chew" and holding back the machine. It will take about 4 passes to till one tiller width in "loose"(garden) soil and possibly more elsewhere. Hope that helps.
Mar 13, 2009 | Mtd Super Bronco Rt Tiller
My rear tine tiller lurches out of control when I use it
Hi it sounds like you are trying too till the soil with the tiller in the fast position and probably too deep for your first pass. Really the fast position is for transporting the tiller from the field. Try putting the tiller in slow which would be the down position. Turn the throttle all the way foward, engage the tines and push your depth rod on the back down to where it is only going into the soil about four inches or even less depending on the hardnes of the soil. Even though a Troy is the best Tiller made it will try to run away with you when your trying to hog the soil all at once. Your depth setting is very important and people seem to forget the importance of adjusting it. Try these things, and remember to alway's start your tilling in the slow full throttle position. Lowering your depth a little at a time. Till you find the appropriete feed for your speed.
Jan 07, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0 Tecumseh Engine Logo
237 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
