Firewalls
Problem for Firewalls
Generic problem for all Firewalls
Emule Show Low ID on Client Computer
By fahadanwar on Mar 23, 2008
Dear Experts!
i have a small network of 4 PCs. PC 1 is mine Broad band connection is attached on my compute. when i Connect to Emule it show me High Id but when i try to use Emule from others PCs which are Clients of my PC Emule show me Low ID on Client PCs. I have shared internet to others 3 computers from my PC. Emule is working with High Id on my Computer but please please please help me that how can i connect Emule with High Id on Client Computers. Even Windows Xp Firewall is off, there is no Router , Just using simple net sharing with D-link 8 Port Switch. Please Help me Thanks!
Best Solution
posted on Apr 01, 2008
Helpful)
Junoon007
Rank: Wiz
Rating: 82%, 377 votes
Dear sir/madam,
You can update the servers it may be become fast. Go this site and add all servers (add to emule) click this link, they automatically update the servers.
http://ed2k.2x4u.de/index.html
OR try this
First of all you need to know the IP of the computer that you use with Emule.
Then go to the router configuration:
- Choose "NAT Settings", and "Virtual Server".
1- If it isn't enabled, enable the "Virtual Server".
2- In "Well-Known Applications" choose de option "User defined".
3- Now the crucial part. Under the Virtual Server List, in the "Local IP" you place the IP of your computer (on the example, 192.168.1.2, i.e. my emule computer ip), "Port Range" put 4662 and Protocol TCP. "Protocol nº." stays blank, and in the "description" you can put Emule Rule Nº1.
4- Click ADD, to add the rule to the table.
- Again you make the same passes from 3 to add the second rule:
3- In the "Port Range" you place 4672 instead 4662, and on Protocol you place UDP instead TCP. On "Description" you can place Emule Rule Nº2.
4- Click ADD.
5- After making the 2 rules, click Finish, and on the next screen click on Save&Restart button.
In the next time you start Emule, you can acess to the servers without Low ID.
Don't forget to rate the solution
thanks
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Firewalls
Questions and Unsolved Problems for Firewalls
Answer
Firewall/ Router Limiting Network Traffic.you need to open up a port so other can connect to you ... (More)
Answer
why my laptop has a problem going shut down when i put a cd to watch movie
Answer
i wanna get rid of a block from linksys my mother blocked a game and i wanna play again
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Firewalls:
Top Firewall Experts
Rank: Guru Guru
Solutions: 3597
Experience: Semi retired, was network administrator, proficient with hardware, software, networks, CAD systems
Ask Me
Find more Firewall Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
