Did a system restore. Updated optical drivers and bios. Drive will only read software cd's, will not read any game dvd's, or any dvd for that matter. Running windows 7, drive is optiarc ad-7640S.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 132 Answers
Not sure what brand and model of computer you have but this may help...
Try looking for a Chipset utility update from the manufactur of your computer's website for your particular computer model, re-install it if you already installed it.
Posted on Apr 25, 2010
  • MyPC Solutions
    MyPC Solutions May 02, 2010
    Did my solutions help you with your issue?
Toshiba P25 cannot read cd
Make sure it has power (ejects). Check Device Manager in Safe Mode by pressing F8 during boot. Right click My Computer > Manage. Select Device Manager > View > Show Hidden Devices. Now delete all DVD/CD-ROMs and reboot. Windows will say "New Hardware Found" and install. Check BIOS by pressing F key (correct F key is noted during boot) and make sure BIOS see's the Optical Drive.
Nov 28, 2012 | Toshiba Satellite P25-S5093 Notebook
My TSSTcorp DVDWBD T3-LB23A optical drive is no longer reading any discs, though it spins and tries when I put a factory movie DVD in it. Same with CDs. The system does boot up the same movie on an
when a drive stops reading ANY disk it's most likely a bad drive.
if the computer see the drive and ask for a disk, the software and disk driver is operating correctly. laptops generates a lot of heat,and more so when pluged in and charging. CDs,DVDs, and disk drives also generates heat. proper ventalation and a cooling pad will help extend the life of a laptop. if you have acess to a spare laptop drive, you can swap them. windows-7 will see the new drive and should install driver.
Sep 12, 2012 | Computers & Internet
Did a system restore of compaq presario 5000 computer. cd/dvd player will not play gaming cds
See if it would play regular cd, then see if it would play dvd's. The reason is because most gaming cd now and days are dvd's and maybe your dvd-rom has a driver issue or the laser head isn't reading it. So try that first, then see if the drivers for the cd/dvd rom is working properly in the device manager. It may need a dvd coded software, try installing like powerdvd or something. If it still ain't working, and it can't play dvd's then your cd-drive could be history
Jan 30, 2011 | Compaq Presario 5000 PC Desktop
.i have got a preserio
CD/DVD issue
> is it an internal cd/dvd drive or external cd/dvd drive
> INTERNAL DRIVE
> ask for lights or glowing (optical drive lights)
> check whether the cd/dvd is getting detected
> For that click on my computers
> c- Drive and d- drive and also cd-dvd need to be detected (but in this case you will not find cd-dvd drive)
> Now follow the LOGIC FLOW
> Now need to do SYSTEM RESTORE (start> all programs> accessories > system restore)
> After the system restore
> switch off the laptop
> Now try and get in to the BIOS
> need to do BIOS default and BIOS update
> Now un-install and re-install the drivers (CD/DVD drivers)
> Start search > type Regedit
> Now try to locate H-KEY-LOCAL-MACHINE
> There would be a positive symbol (+) beside this
> Just need to click on that (+) symbol
> locate a folder which says SYSTEM
> Beside the SYSTEM there would be a (+) symbol
> Now locate CURRENT CONTROL SET option
> Now there would be (+) symbol beside the CURRENT CONTROL SET
> Now locate folder CONTROL
> There would be a (+) symbol beside the CONTROL
> Now click on the (+) symbol
> Now to locate CLASS
> Now try to locate an ALPHA NUMERIC NUMBER ends with --- 965
> Now click on the ALPHA NUMERIC NUMBER which ends with ----965
> Now look at the right side partition of the screen you can see a EDIT MENU
> Now try and locate the UPPER FILTERS OR LOWER FILTERS
> right click and DELETE THE FILTERS
> If you find both then DELETE BOTH
> Now just RESTART the laptop
> Now check in laptop whether the cd/dvd drivers are detected using the MY COMPUTER
> If it is detecting now try playing the CD/DVD
> If still NOT ABLE TO PLAY
> Reseat the CD/DVD tray
> After RESEATING the cd/dvd tray if not able to play
> Now PERFORM THE RECOVERY
Dec 07, 2010 | HP Compaq nx6110 PC Laptop
My laptop cannot play DVD
CD/DVD issue
> INTERNAL DRIVE
> Now to locate CLASS
Dec 07, 2010 | Computers & Internet
Bios does not recognize cd/dvd drive, nor external cd or dvd drives (optical drives). Updated to version 2.0 Bios from Toshiba website, but no success with that either. Is there a fix for this? How can I...
well, only way is to flash your bios.
it should be bootable flash bios tool that will assist you to remove all the current settings to the original settings. but if you can get the memory flash for toshiba then try running the system in safe mode the see if your usb devices can function then you try booting the system with cd/dvd drive. it should work
May 21, 2010 | Toshiba Satellite A215-S5822 Laptop
Dvd's & Cd's are not being read
When this happen the problem is usually the CD drive, even if a virus can cause same problem.
To test if the problem is software, go to bios or boot options, set primary bot device CD/DVD, and start the computer with a boot disk inside.When asked chose boot from CD.
If the computer does not see the dvd drive, and does not ask you if to boot from CD on this conditions, then you have a faulty DVD RW drive.
Try first removing the DVD drive and refitting it in place, after removing battery and unplugging the AC adapter cord.
If that does not work, you usually need to replace the driver, even if on rare circumstances a faulty motherboard can cause the same.
That is however quite unusual.
the most common is a faulty optical drive.
May 16, 2009 | Pioneer (DVR-K16) DVD RW Dual Layer Burner
HP CD/DVD optical drive is not recognized
I found that there was a firmware conflict caused by the installation of iTUNES. I uninstalled and cleared the upper and lower filters in the registry and the internal DVD-Rom is recognized. First I cleared the registry and the drive was recognized after a hard boot. So Far no twitches. Knock on wood.
Dec 26, 2008 | Computers & Internet
PC IS NOT RUNNING ANY CD/DVD'S
okay try this
Go to your My computer icon--right click on it
properties-->hardware-->device manager
Find ur cd/dvd drive on it
Uninstall it by right clicking it (dont get scared ur system will detect it itself in next reboot and u dont need any drivers for it)
hope it will works if there is no physical damage
Please Rate ...
Sep 26, 2008 | Computers & Internet
DVD Drive auto ejects on stratup of system & Remains open
did this happen after you have updated your win xp to sp3? try to do a system restore. go to all programs>accessories>system tools>system restore> go back to the date before the sp3 was installed. try also updating the driver for your optical drive
Jun 12, 2008 | BenQ DQ60 DVD RW Dual Layer Burner
Computers & Internet Logo
64 people viewed this question
David Payne
David Payne
