Question about Hannspree HW191D LCD Monitor
My screen is changing colors - Hannspree HW191D LCD Monitor
  • 560 Answers
Tighten the video cables screws on your LCDand computer.
Posted on Apr 25, 2010
Screen has reversed colors (appears to look like a color negative). Everything seems to work ok. Repairable?
hello , just you need to enter to the picture options and change the display screen or display color , or change the mode it would be an NTSC mode you should change it
Feb 11, 2016 | Vizio VO370M LCD TV
Sony kdl46ex710 half screen 3 colors vertical
This CAN BE a defective panel, but most likely defective capacitors in the power supply section of your TV, and one that requires a good deal of soldering skills not to mention diagnostic ESR meters and capacitance measuring devices to troubleshoot this. Are you sure you're up to this?
Mar 16, 2014 | Televison & Video
Logon Change
Enable Log-On Screen
Windows, by default, is set to show the Welcome screen during startup.
To enable the log-on screen to show, go to "Start" menu and select "Control Panel".
In the control panel, click on "User Accounts".
In the "User Accounts" dialog-box, click "Change the way users log on or off" and uncheck the "Welcome Screen" option.
Click "Apply Options" to save the changes.
Change Log-On Screen Background Color
To change the log-on screen background color, go to the "Start" menu and click on "Run".
In the run dialog-box, type "mspaint" as the name of the program to "Open".
Click on "OK". In the "Paint" window that opens, select "Colors" from the main menu and click on "Edit Colors". In the "Edit Colors" dialog-box, select "Define custom colors".
Here pick the color of your choice and note down the "Red", "Green" and "Blue" values.
Write down these values somewhere.
Click "Cancel" and close the paint window without saving. Now, go to the "Start" menu, click "Run" and enter "regedit" as the name of the program to "Open".
In the registry editor, navigate to HKEY_USERS\.DEFAULT\CONTROL PANEL\COLORS and double-click the "Background" string.
In the "Edit String" dialog-box that opens up, change the values in the "Value data" field to the red, green and blue color values that you wrote down (e.g. 75 78 173).
The default value will be 0 78 152. Enter the values in the correct red-green-blue order, separated by a space. Close the registry editor and log off to see the changes.
Put Image in Log-On Screen Background
To put your favorite picture in the background of the log-on screen, click "Start", then "Run", and type in "regedit". In the registry editor, navigate to HKEY_USERS\.DEFAULT\CONTROL PANEL\DESKTOP and double-click the string "Wallpaper". In the "Edit String" dialog-box that opens up, enter the full path and filename of the image that you want to use as the background. The image must be in .bmp format. Click "OK" and close the registry editor. Log off to see the changes. hope this helps
Oct 03, 2012 | Microsoft Windows XP Home Edition for PC
Screen is showing all black things red
It sounds like your screen might be going bad. Normally there is no setting you need to be doing to adjust colors on your screen. There are some settings when you click Start/Control Panel/Display to look at your display settings, but these normally just control the color around the windows. For example the normal or default color for the strip that is at the top of your internet browser is blue but you can change it. I would say that when you boot your machine if the colors are not what they should be normally during the boot process, then your screen is going bad. You might try Opening a Word Document then type words such as Black, Red, Green, Blue, Yellow, etc. on different lines in the document. Then highlight the word and change the font color to match the word. This might let you see if your colors are true colors or if the screen is bad.
Mar 16, 2012 | HP Compaq nc4200 Notebook
Change Font color in an excel spreadsheet and it prints correct color but will only show as black on screen.
Make sure you have highlighted yhe area you want to change the color on then click on the color you want and it should change for the screen as well as the printing phase of the program.
Dec 14, 2009 | Microsoft Office Excel 2003 for PC
I want to change the led color on my blackberry
You cannot make any changes in LED colour settings.However, you can set the color contrast of application interfaces, menus, and pop-up screens to Normal, Grayscale, or Reverse Contrast. To change the color contrast, complete the following steps:
  1. In the Options application, click Screen/Keyboard.
  2. Set the Color Contrast field to Normal, Reverse Contrast, or Grayscale.
  3. Press the Menu key.
  4. Click Save.
Oct 29, 2009 | RIM BlackBerry Pearl 8100
Screen color
It's not a color screen so no, you can't change the color. You can, however, change the contrast. Press and release the 2ND key, then press and hold the up-arrow to increase or down-arrow to decrease the contrast.
Sep 23, 2009 | Texas Instruments TI-85 Calculator
How do you change the light color in the radio?
No, you can only change the color of the radio screen on cretin models not all.
Aug 28, 2009 | 2006 Scion tC
LCD Screen colors
you cant change the color at all or it continuously changes. cause i downloaded the manual online and it doesnt show any way to change the color. just that it can change to 7 colors.
Jun 15, 2008 | Jwin JX-MP122FM (128 MB) MP3 Player
Hannspree HW191D LCD Monitor Logo
96 people viewed this question
Top Hannspree Computers & Internet Experts
tomar33
Gregg Errera
Gregg Errera
Level 1 Expert
Are you a Hannspree Computer and Internet Expert? Answer questions, earn points and help others
