Question about Dishwashers
My zanussi dishwasher does not fully drain the water. Itr always leaves a balannce in the sump
  • Dishwashers Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your problem...
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Posted on Apr 27, 2010
I have a dw908 which is not filling with water
Check it is draining properly, if it is then the water level sensor is blocked, usually a small pipe running from the sump up the side of the machine to an air pressure switch, often gets blocked where it joins the plastic sump.
Jul 05, 2011 | Zanussi Dishwashers
MDB5600AWB dishwasher after the cycle has completed some water remains in the bottom of the tub.
either the check valve located in the lower sump is plugged or not closing fully and letting waste water back in,or the sump is plugged with waste food,or the drain line to the sink is partially plugged
Jul 16, 2010 | Dishwashers
After rinse cycle clean water remains in the bottom on the machine
The same thing happened to me -- and it cost me a repair bill of $200 to figure out the cause of it. Before calling for service, I removed the plastic grate covering the sump at the bottom of the dishwasher and looked for something that might be obstructing the flow. I couldn't see anything. When the service guy arrived, he first verified that there was no obstruction in the hose leading to the drain under the sink. Then he removed and replaced the drain pump - he figured the pump impeller was damaged. That didn't solve the problem, either. Finally he checked the connection from the sump to the drain pump. Bingo: a large green grape, slightly squashed but otherwise intact! For the life of me, I can't figure out how it managed to get through the sump cover, because the gaps in the grate can't be much bigger than an eighth of an inch. But when the dishwasher was reinstalled (with the original drain pump) it once again drained fully, leaving no water in the bottom of the tub.
Besides how that grape got there, the other mystery to me is why this (not exactly cheap) dishwasher doesn't have a food chopper - I could have sworn that my old dishwasher had one. In which case that grape would have been history long before it caused a problem.
Jun 08, 2009 | GE 24 in. Profile PDW7800 Built-in...
Water in drain pump for ASKO D5122XXL dishwasher
Yes, Asko dishwashers can leave a small amount of water in the sump after a cycle completes. At the beginning of most cycles the sump is pumped and new water added.
Mar 12, 2009 | Asko D3152XLSS Stainless Steel Built-in...
Water standing at the end of the cycle in my Bosch dish washer
where is the water is it visible above the filter plate or is it in the bottom of the sump
if its in the bottom of the sump thats normal it will always leave water in the sump
Mar 09, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
DD601ver2
check for restriction in sump. ie remove rotor, push pipe cleaner or similar from filter sump into rotor sump
Jun 21, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Bosch dishwasher will not drain - causing moldy odor
Hello Mimhoff it depends on how much water is down there. The sump area always has a little water in it to prevent the circulation pump seals from sticking. Usually around 1 to 2 inches. If there is more than that, check the slots at the bottom of the sump on the left side for being clogged and check the end of the drain hose to make sure it is clear. If you are getting a moldy/odor from the dishwasher, try running Dishwasher Magic or Tang thru the dishwasher. This will remove any build up of food or detergent from the dishwasher. If you are running the dishwasher every few days and just scraping your dishes, then either leave the door ajar or run the rinse & hold cycle to help keep the odor down. Bosch doesn't reccommend running bleach thru the dishwasher as this can cause damage to the rubber seals. However 2 tablespoons of bleach once a year won't hurt.
Feb 01, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Zanussi DE 6965
Hello Russel A L 6 Is Water Drain Time-Out Possible causes are; a) Domestic drain outlet unsuitable (obstructed) b) Motor faulty (pumps group/ drain impeller) c) Pressure switch faulty d) IWMS- Pressure switch tube obstructed e) IWMS- Sump vent hose obstructed f) Control board (Relay interrupt Regards David Marsh
Jun 04, 2007 | Zanussi 24 in. DE6965 Built-in Dishwasher
Bosch Diswasher not draining
Soyben, you need to check to see if either the drain hose or syphon break at the sink is clogged. The drain motor on this model is not a bilge pump that will remove water from the base. Therefore Im leaning on a restriction somewhere. Other than that you may have to check for debris in the drain sump. Check these areas out first...Catriver...post back
Aug 27, 2006 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
73 people viewed this question
Top Dishwashers Experts
Owen Barnes
