I have an old mitsubishi televsion and I cannot get channel 3 on the television so that I can watch my uverse tv
  • 438 Answers
Look on the back of you device, most channel modulators allow for channel 2 and 3 or 3 and 4 setup you may find a switch to set this or refer to the devices user manual for the location of this feature also and if you have a component audio video input on your TV try using RCA cables to connect them together
Posted on Apr 27, 2010
Lost channel 3 to watch tv on uverse
you need cable box on when you search so the tv can find it
Feb 16, 2015 | Westinghouse SK-32H640G 32" LCD HDTV
2 tv's. recently had uverse removed. neighbor has rabbit ears-gets local channels. I get nothing. Does something with uverse change my tv's?
Your tv my have a setting for type of input. Cable of Air channels. You would need to switch that to AIr. Also, the air channels have gone to a digital signal and I believe they take "digital rabbit ears" I think the old style may not pull in the digital signal, but I'm not entirely certain about that one. Something like this http://www.amazon.com/AmazonBasics-Ultra-Thin-Performance-Indoor-Antenna/dp/B00DIFIO8E/ref=sr_1_1?ie=UTF8&qid=1409885138&sr=8-1&keywords=digital+antenna+for+hdtv+indoor
Sep 05, 2014 | Televison & Video
Trying to set up my new elements tv with a uverse wireless box. Did a channel scan but still can't find any channels. Help please!!
Is this a high def tv? Are you using an hdmi cable, component cable(red green & blue) or a low def coax cable to connect the tv? If coax, the tv needs to be on channel 3 or 4. If hdmi or component cable is used you need to change your input on the tv with your remote to the matching input you wired it to. The uverse stb (set top box) changes the actual channels once you have selected the correct input.
Jun 26, 2014 | Televison & Video
I have a Sony KV-27ts27 television that I bought secondhand, without a remote. I need to know how to turn on closed captions. When I had cable service with AT&T Uverse, the closed captions were working but...
Here is a link to the manual. It appears to me your set does not support closed captioning. It is too old. It mentions channel captioning, but that is for a channel identifier for reference. http://diplo-best.com/314.php?k=ac30c98e172782467c3895e8cba613ad&ID=87078&q=SONY KV-27TS27
Oct 31, 2013 | Televison & Video
Mitsubishi tv customer service
i have a blinking green light and then the red lamp light comes on and stays. no picture no sound
Aug 07, 2013 | Televison & Video
On the Onkyo receiver, I have a uverse box hooked to an hdmi input, and a Samsung un55c8000 hooked to the hdmi out. Even though the uverse box is set to output 1081i, the Onkyo receiver tells the...
Hello, please press and hold the display button on the remote for 3 seconds to confirm the incoming resolution from the cable box. Thank you, Onkyo USA
Jun 04, 2017 | Onkyo TXNR708 72 Channels Receiver
What channnel do I put the televsion on to see cable. I was watching tapes on VCR when it snowed and I totally forget what channel it goes on.
Please check the input on your TV. Normally TV has AV in . If you use VCR , you should set your TV in to AV ( some tv has AV1, AV2). Sometimes on some brands, if we set TV channel to 0 , it will automatically reroute the TV input to AV.
Regards, Jay
Feb 03, 2011 | Televison & Video
I have lost my remote and the kids pushed the side buttons on the TV to raise the volume but instead changed the channel. Now I can't get back to the channel that works with my AT&T uverse box.
Instead of changing the channels, press the "INPUT" button on the side of the TV slowly and repeatedly. The TV will cycle through all of the available external inputs one of which will be for your Uverse box. If this doesn't work, try switching to channel 3 or 4. I can't say which will be correct as it depends how the equipment is setup.
Hope this helps.
Regards,
BElectric
Jan 07, 2011 | Vizio VX32LHDTV10A 32 in. LCD HDTV
Television will not program channels 2-7
It seems you have already try everything We might suggest< I dont know if you have tried using the video and audio outputs in the dvd/vcr combi unit conecting them to the audio and video imputs of your tv and the selecting maybe one of the AUX channels to watch it,If you have a tuner problem in your tv this will be a way to bypass it and control the channels from you combi unit.We would like to know the outcome,please let us know.
Oct 09, 2006 | RCA F27669 TV
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
Electro Med Services...
