Question about Fisher Ovens
Trying to change bulb in oven, but cant remove old one Does it twist or pull staight out?
  • faye_kevin Apr 25, 2010
    Tried that. It has a cover over it and that is hard to get off
  • 523 Answers
If its like a reg bulb it twists out
Posted on Apr 25, 2010
How do I remove cover to change interior light bulb ?
Welcome to FixYa.
In order to answer your question effectively, you'll need to provide a model number for your range and confirm it is indeed a Thermador oven.
There are simply too many different styles to generalize on how to simply "remove cover to change light". In fact some Thermador lens covers are square glass covers which pull off, others are round "dome" shaped which twist off and yet others are held in place via a single metal clip or fastened in placed with a metal bracket and two screws.
I'll watch for your post and be glad to assist you in solving this problem in whatever manner I can.
Thank you for choosing FixYa.
Regards,
Macmarkus :)
Mar 17, 2011 | Thermador Ovens
How do I change the lightbulbs in the oven
Make sure the oven is off and cool (turn off the circuit breaker). Wear a leather glove to protect your hand. Depending on your model, there may be a glass shield held by a metal holder over the lamp. In the case of a unit with this holder, press on one side to release the shield and remove it. Remove the bulb by turning it counter-clockwise. Replace with a 40 W appliance bulb (turn clockwise). Replace the glass shield and the holder. (On some oven models, the shield will twist on and off like a bulb.)
There are several models of Kenmore 47783 Ovens; manuals are available here: http://www.managemylife.com/mmh/owner_manuals/search?query=Kenmore+47783 .
I hope this helps.
(please note: never operate the oven without the shield in place if your oven has one.)
Dec 12, 2010 | Kenmore 47783 Electric Single Oven
The bulb seems to have fused. How to remove the fused bulb and replace with a new one. Have I got to pull the oven out and fix it from the rear?
No, you should be able to replace it within the oven space. The cover should unscrew and reveal the bulb which you then remove and replace.
Jan 19, 2010 | Zanussi ZBS963X Electric Single Oven
How do I change the bulb in an Inglis oven. Can't
Normally the cover will have an anticlockwise turn thread. Twist the glass cover anti clockwise and it should unscrew.
Jan 04, 2010 | Ovens
How to replace oven light bulb for beko DC543 electric cooker
hi
You may need to remove the glass cover by turning it anti-clockwise.
On some models access to the bulb is from outside so the oven has to be slid out of it's housing and an access plate removed.
chek this following steps..
Step 1 Make sure the bulb is actually burned out. Confirm the oven is plugged in and that a circuit breaker is not tripped.
  • Step 2 Look for the manual to determine what size bulb is required. Most use a 40 watt appliance bulb. If you can not find the manual, then buy a bulb to replace it after you take out the old one.
  • Step 3 Confirm that the oven is not on. Allow it to cool to room temperature if it has recently been used.
  • Step 4 Open the door and use a flashlight to light the area where the bulb is located. Do not put weight on the door itself, but go in at an angle or sideways.
  • Step 5 Find the shield or cover over the bulb, gently pull or twist it off. Some glass covers are surrounded by a wire clip or a ring that is screwed in to the back.
  • Step 6 Gently remove either the wire clip or ring. Since the cover is most likely glass, be cautious. Unscrew the entire glass cover similar to a jar lid in older versions of ovens. Then repeat process if there is more than one bulb.
  • chek this usefull link
    http://www.espares.co.uk/advice/cookers-and-hobs/a/1/112/changing-your-oven-light-bulb.html
    hope u will b helpfull
    tnx for contactin fixya
    regards
    Jul 12, 2009 | Ovens
    Double Oven Bulb is stuck in socket
    The best thing to do is to grip the bulb with a pair of grips with a cloth rond the bulb and try twisting it out that way.
    Don't worry if you break the bulb as all you have to do then is twist the remains of the bulb base out with a thin pair of grips..
    You can safley spray it with WD40 , it is not a fire risk..
    PLEASE ENSUREN YOU HAVE THE POWER OFF.
    Plz rate my solution,and feel free to leave antycomments.
    Thanks.
    Jan 03, 2009 | Bosch HBN 3550 Electric Single Oven
    Change oven thermostat
    Not familiar with the brand - but there are two types of temperature sensors - i am assuming here that the person meant temperature sensor rather that a thermostat.
    1 bulb type sensor
    2 rtd type sensor (metal looking tube usually installed at back)
    If its the bulb sensor - then there is a long tube from the bulb to the main dial on the front panel. All of this must be removed to change it. (power turned off) The knob on the dial removed and the front panel removed and the screws removed and the bulb threaded through - reverse to installed.
    If its the rtd - then they are usually secured with two screws inside the oven (look inside to see) loosen those then pull the unit towards you the connecting wires should come through there should be a quick connector - (if under counter type) remove the old sensor and connect new one. Thread the wires back through the hole and secure the new sensor with screws - if the screws were damaged replace with only stainless screws
    Aug 22, 2008 | Zanussi ZDQ895 Electric Double Oven
    Change Bulbs in Neff U1661 Oven
    You don't need to slide the oven out, just remove the glass covers with a flat bladed screwdriver and then unscrew the old bulbs. Replacement is the opposite.
    Bulbs available from Homebase, Wickes, BandQ etc etc.
    Apr 27, 2008 | Neff U1661 Double circotherm super...
    Ovens Logo
    85 people viewed this question
    Top Fisher Ovens Experts
    Dennis Boxerman
    Richard
    Richard
    ray gallant
    Are you a Fisher Oven Expert? Answer questions, earn points and help others
