Question about Zojirushi NH-VBC18 10-Cup Rice Cooker
The rice dries out in the "keep warm" mode
My rice cooker is about 4 years old and in the the last 4 months, the top of the rice completely dries out when left in the "keep warm" mode while water seems to collect in the bottom of the pot. I can no longer keep the rice warm otherwise I have to throw the whole pot of rice out. I can't figure out what is causing this to happen and really want to try to fix it.
    Scholar:
  • 59 Answers
You have a strange problem. I use my rice cooker often and the only thing that I can think of that may be casing your problem is if the steam vent is clogged. A clogged vent would cause the steam to condense and run to the bottom.
With the machine empty of food, you could try pouring hot water through the vent to see if this clears any clogs. If it does not, it could be other problems that I can tell you will cost more money to fix than to replace with a new Rice cooker.
Good Luck.
Posted on Apr 25, 2010
I just bought a rice cooker at a garage sale. It had no instruction manual
To make rice, remove the trivet if you have one as this is only for steaming food.
Wash rice to get rid of excess starch and put in pan. Then add the same amount of water as rice (2 cups water to 2 cups rice etc.) then shut lid and switch on and leave it.
Once it has switched off do not open the lid for a further 20 minutes (the machine will keep the rice warm do not worry) Stir rice and serve. Most rice cookers will keep the rice warm for a couple of hours.
If you find the rice is a bit dry then add a little bit more water, the amount of water really depends on the quality of rice used.
Sep 20, 2014 | Krups Kitchen Appliances - Others
Started rice cooker it was on..when I went back to check on it it was off and won't turn back on. I tried unplugging the ricecooker and plugging into a different outlet but it still doesn't work. The rice...
There is a sensor that regulates how hot the cooker gets and shuts it down to the warm setting when it senses that the heat is too high...meaning that all the water has cooked off....my guess is that the sensor failed and as far as I know it is not replaceable.
Here is a tip that I wrote about rice cookers and the amount of rice and water needed...
How much Rice and Water go in the Cooker
http://www.fixya.com/support/r5396567-much_rice_water_go_in_cooker
heatman101
Apr 07, 2010 | Oster 3072 20-Cup Rice Cooker
Purchased Durabrand Rice Cooker model HRC 18G working fine Is there a User manual for this cooker? All that is needed is ratio of water to rice including plain long grain and Basmati rice for 1 - 4...
Instructions quoted from the Durabrand Rice Cooker model HRC 18G manual...... 1 cup of uncooked rice rice will make about 2 cups of cooked rice. Add rice to the inner pot. Maximum four cups uncooked rice for the model. Many varieties of rice can be used including basmati, wild rice, arborio risotto, saffron rice and long grain rice. Whole grains, such as barley can also be prepared with the rice cooker, follow instructions on the package.
For every cup (160ml) of raw rice, add 1-1/2cups of water. For stickier rice add slightly more water, for fluffier rice use slightly less water.
When your rice is cooked, the cooker will automatically switch to the warm function and the yellow warm light will turn on. The cooker will stay in the warm function untill is disconnected from the wall outlet. The cooker will keep the rice warm 158F - 212F
Hope this helps, its quoted right out of the manual I have for my cooker
Jul 27, 2009 | Kitchen Ranges
Rice cooker goes to "keep warm" mode before rice is cooked
bad thermostat . there are no parts made for this model . sorry
Jan 17, 2009 | Tiger JNP-1000 5.5-Cup Rice Cooker
Rice Cooker promaturely pops up before rice is cooked
try adding a little less water, And letting it sit about 4 min to make sure the steaming has stopped
Oct 21, 2008 | Zojirushi NRC-15 8-Cup Rice Cooker
The rice getting spoiled
hygiene is an important thing first the cooker may say you can save it but frankly I take my cooked rice and put it in Tupperware and place it in the fridge, bacteria will grow in a warm environment no matter how tight the lid is on. next the unit will have to be washed and then sterilized with bleach water. then let it sit for more than 10 days to dry you should be ok after that but please save your food in the fridge a microwave will warm a bowl in about 30 seconds.
Jun 29, 2008 | Zojirushi NH-VBC18 10-Cup Rice Cooker
Spoiled rice after 20+ hours
I know this thread is old but after much research and trying all the crazy theories on sanitizing the rice cooker I have solved the problem and it should work for you too. EVERY person I've shared this with has reported the same results, rice that keeps for up to a week, nice and hot in the rice cooker as it ALWAYS has, the way you remember when you were a kid.
The problem lies not with the cooker itself but in the water you're using. Yes as simple as that. Let me give you a brief overview. You probably don't know but the tap water you're using most likely is treated with a compound called chloramine. The problem is this compound is also subject to a biological process called nitrification which in turn leads to an accelerated biological process in your rice cooker. This is a very high level explanation and there is much more detailed scientific explanations of the process and issues that are exacerbated by the pipes in your house and at the plant. I will not cover all the technical aspects but if you're wondering why this didn't happen before it's mainly because water was treated with chlorine before, not chloramine.
The bottom line is this. Rinse and cook your rice using ONLY bottled spring water, check the label. If it indicates the bottled water you're using is from municipal sources, call the manufacturer to make sure there is no chloramine. If you do this you will be so relieved and happy, I'll be happy knowing I saved you the frustration and brought rice peace to your life.
Forget about all the special cleaning procedures or equipment testing, I too thought there was something wrong with my fuzzy logic cooker...NOT!!!
If you want more in depth information about chloriminated water you can join my Facebook page and read/discuss it: https://www.facebook.com/pages/Chloramines-and-You/339649646128698
Mar 10, 2008 | Zojirushi NH-VBC18 10-Cup Rice Cooker
Zojirushi NH-VBC18 10-Cup Rice Cooker Logo
288 people viewed this question
Top Zojirushi Kitchen Appliances - Others Experts
30yrmech
Level 1 Expert
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Zojirushi Kitchen Appliances - Other Expert? Answer questions, earn points and help others
