Question about HP Photosmart C5180 All-In-One InkJet Printer
The carberator on my 1981 corvette is running too lean, what can I do to fix this? Wendy
  • JIMMY May 21, 2010
    How are you making this determination?
    Genius:
  • 1,374 Answers
I'll give you a list of of possibilities:O2 sensor may be defective, you may have a vacuum leak., incorrect coolant / water mixture. (too much coolant in mixture)
Incorrect thermostat. Have all these items checked out and get back to me.
Posted on Jun 11, 2010
My 1981 corvette tach quite working how do I get working again?
1981 Corvette has an electical tachometer that is driven by impulses from the distributor. First, check for blown fuses, next make sure the tach wire is plugged into the distributor. Next bypass silver tach filter or capacitor located by manifold to see if the tach moves at all. If these steps do not reveal a change in tach operation, then the most obvious next step is to remove the tachometer and get a new board for the tachometer. Unscrew and remove cluster lens and then unscrew tach bezel, and gently pull out the tach noting position of insulators. I believe these boards are available still at local autoparts locations. Replace board, note position of insulators and reinstall tach, bezel and lens. Old corvette are cool and are pretty easy to work on! Should be fixed, enjoy!
Feb 15, 2015 | 1981 Chevrolet Corvette
1981 corvette running lights stay on when key is off
lights must be connected to a circuit that does not run thru ignition switch.
Sep 21, 2014 | 1981 Chevrolet Corvette
Sucking air in carberator
perhaps a carberator adjustment then, would say it's running kinda lean maybe
Mar 10, 2013 | Garden
Suspension problem on 81 corvette
just an idea, have you tried using spring blocks(rubber wedges) ?
Nov 05, 2009 | 1981 Chevrolet Corvette
1981 corvette seat conversion
you will need to pull off the four retaining nuts holding seat in place. Measure the length and width of bottom support frames. Many seats are interchangable.
May 11, 2009 | 1981 Chevrolet Corvette
1981 corvette new radio
See if you get power from the gray wire. Use a 12 volt bulb, or a multimeter.
Apr 21, 2009 | 1981 Chevrolet Corvette
1981 Chevrolet Corvette runs "rich"
Have you done an engine vacuum leak test with carby cleaner especially around injector seals.A leak will throw a lean signal to oxy sensor there by telling the computer it needs more fuel.Cant think of anything other than what you have already done.
Oct 22, 2008 | 1981 Chevrolet Corvette
How do I replace the brake power booster on a 1981 corvette
you will have to remove the master cyl no need to dissconnect the lines and dissconnect the vacuume line and from inside the car under the dash dissconnect the brake pedal from the shaft running to the booster. and remove the 4 mounting bolts that hold the booster to the firewall and pull foward in the engine compartment.
as long as you dont dissconect the brake lines you wont need to bleed the brakes.
good luck
paul
Sep 28, 2008 | 1981 Chevrolet Corvette
HP Photosmart C5180 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
