Question about Vector VEC010S Jump Start System 300 Amp starting power
I want to change batteries in my 03 Crown Vic and I am wondering if I hook up the dc/dc cord if this unit will feed current back into the car thus retaining the computer settings and the radio station settings?
  • 699 Answers
This actually quite a good trick to provide an appropriate (eg. charged) 'alternate' DC power source to maintain the minimum voltage and current to hold the computer, radio and alarm setting for your car while swapping your car battery (I have myself used 2 small 9 Volts batteries in series via alligators clips for this purpose): just make sure that it is connected on the correct side of the cables where voltage and current will be maintained after the main car battery is disconnected!
Hope it works for you and have fun!
Posted on Apr 25, 2010
How do I set the clock in my 03 crown vic. I don't have a rds button and I don't have a clock button.
Michael, Found this info. at Car Gurus site. Set the clock by pressing the RDS button until SELECT HOUR or SELCET MINS is displayed, then use the SEL arrows to set the time. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
change time 2003 crown vic
How to Set the Clock on Ford Crown Victoria 1992 2011 2003 Ford Crown...
Jul 23, 2016 | Cars & Trucks
Why do the fan stay running when car is off on my 03 crown vic?
Sounds like you have a double problem . First locate the radiator fan relay it should be in the fuse box change the relay. Also change the tempature sending unit (attached to radiator) . If your car is overheating . You need to check. For a leak, be sure you have enough. Fluid in radiator, check. Thermostat , change it anyway cheap enough, ( 16 lbs. pressure ) this should solve your problem
Aug 07, 2014 | 2003 Ford Crown Victoria
Where is the ambient air temp sensor for the 03 crown vic p71
i have a 99 crown vic suvillan and i cant find the ambient air temp sensor where is it please help
Mar 02, 2011 | 2003 Ford Crown Victoria
2004 Crown Vic tran whines in low gear only, took ...
It's normal on the AOD transmissions. Their first gear uses straight cut gear and thus has the whining noise. Gear 2, 3 and 4 are helical gears and thus quiet.
May 20, 2010 | 2004 Ford Crown Victoria
Hvac blower not operating any speed,
have you tried replacing the blower resister module?
Sep 29, 2009 | 2003 Ford Crown Victoria
How do I reconnect my 95 Crown Vic air suspension compressor?
most likely someone unhooked it due to some part being bad in the system and even possiable that the air bags have been removed and coil springs installed
Jul 15, 2017 | 1995 Ford Crown Victoria
Trying to install a subwoofer on a 97 crown vic
Make sure you are using a 12volt DC system in both units. It may sound simply but an AC sub may need an inverter. Also check grounds.
May 21, 2009 | 1997 Ford Crown Victoria
'94 Ford Crown Vic Headlights
They are changed from within the engine compartment... at the rear of the headlight bazels... if it's the side on the battery you may have to remove it.... also don't touch the bulbs with your fingers as that shortens the life of them.
Robert
Jan 17, 2009 | 1994 Ford Crown Victoria
Location of fuel pump relay on a 2001 Ford Crown Vic
where is the fuel pump relay on a 2001 crown vic p71
Jan 10, 2009 | 2001 Ford Crown Victoria
Vector VEC010S Jump Start System 300 Amp starting power Logo
127 people viewed this question
Top Vector Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you a Vector Electrical Supply Expert? Answer questions, earn points and help others
