Question about Frigidaire FRS26KF6E Side by Side Refrigerator
My refrigerator side is making a grinding noise and today I noticed that it is warm. the freezer side is fine. I have a frigidaire frs26kf6e.
  • Frigidaire Master
  • 3,740 Answers
Hi and welcome to FixYa, I am Kelly.
That grinding noise is usually ice build up on the evaporator coils to the point that the evaporator fan blades strike the ice build up. i.e. Possibly an automatic defrosting problem.
Here is what you can do to find out.
1. Unplug the refrigerator
2. Remove the contents from the freezer section
3. Place a fan blowing into the freezer compartment for a little over 2 hours. THIS MAKES A WATER MESS so be prepared.
4. After the manual defrosting period with the fan then reload the freezer.
5. Plug the unit back in
6. After 4 hours recheck your freezer and fresh food section temps.
7. You should no longer hear the grinding sound
It is highly probable that the ice build up will repeat. If it does then for sure you have an automatic defrosting problem and will need to service the defrosting problem. At least you will know what caused the grinding noise.
If after all of this that grinding noise you heard is still present you will have to check the evaporator fan assembly for signs of bearing wear.
If the grinding noise is coming from the compressor... bad news the compressor rotor is dragging and that requires a compressor replacement.
Your parts can be found here:
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=frs26kf6e
(there are 2 missing digits from the model number)
Click on the model number of your exact model and the parts page will appear.
Thanks for using FixYa
Kelly
Posted on Apr 25, 2010
Testimonial: "thank you"
I bought a new frigidaire fridge with the freezer on top. It's made a weird grunting, gurgling, groaning sound on and off from day one. Should have called Leon's where I bought it to complain but never...
hmmm, could be in defrost cycle when that happens, when the defrost element warms up and the frost/ice drips it then makes sounds about how oftern do you hear the noise?
Dec 18, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
I have ocean fridge freezer and the freezer part not working i.e not freezing properly. Many thanks i await for your reply.
the ptc overload on the compressor is not working and needs replacing,its located on the compressors side body under a spring clip,merely unplug it and get a replacement and plug it back in and its good to go
Jul 29, 2010 | Frigidaire FRS26KF6E Side by Side...
Describe your frigidaire frs23f5a freezer
With ours it is ice collection on the fan in the freezer section. This is located about half way down under the icemaker (please unplug to proceed). If you remove the four hex head screws and lift up the metal flap you will find the fan assemble and most likely the ice build up to chip off.
Jul 01, 2010 | Frigidaire FRS23KF7AB Side by Side...
I have a Frigidaire Upright Freezer making strange noise.
Check the condenser fan,m sounds like the bearings are failing.
Good Luck,
Gilsh
Nov 28, 2009 | Refrigerators
Frigidaire Frig side by side making a loud buzzing noise
it sounds like the compressor, or something near it. it is generally the only moving part in a refrigerator other than the door, so would be my first guess. If it is constantly running, but staying cool in the freezer there may be a small leak somewhere or the compressor is losing power, and pumping slower.
Jun 15, 2009 | Frigidaire FRS26H5AS Side by Side...
Grinding noise when running
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
gdhjh
Apr 17, 2009 | Frigidaire FSC23F7DSB Stainless Steel Side...
Frigidaire FRS23H5AS refrigerator - freezer not cold
Humming noise would be your compressor going bad. The noise from the fan is because they are over working to try and keep everything cool
Feb 12, 2009 | Frigidaire FRS23H5AS Side by Side...
Frigidaire refrigerator is warm on top of frig and freezer but fine on the bottom of both.
i suspect the fan is not working. take the back panel off inside the freezer and check that the fan is free to rotate, check for continuity thro the fan motor and check you have power to the fan
Oct 15, 2008 | Frigidaire FRS26H5AS Side by Side...
Fridge and Freezer losing cooling
thermostat control to deice the freezer is malfunctioning need a service tech to replace it so it doesn't keep the deicer on . Its exactly that, a warmer to deice the coils.
May 27, 2008 | Fisher and Paykel Active Smart E522B...
Keeps defrosting or stoping all together.
Check that the AC outlet works where the unit plug. Its seems that you have a power loss problem, either on the unit or in the wall outlet.
Aug 04, 2007 | Frigidaire FRS26KF6E Side by Side...
Open Questions:
Frigidaire FRS26KF6E Side by Side Refrigerator Logo
1,261 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
