Question about Cell Phones
I have a txt8026c that was in water. i have tried all the tricks to get it to turn on, to no avail. i need the phone numbers. i would like to take off the back and spray the circuit board with electrical cleaner then blow dry. i have the screws out but the back seems glued. is there a repair manual somewhere?
    Problem Solver:
  • 5 Answers
Do not do any thing on it directly go to shop they remove water and dehyrated your phone that will help you
Or
keep the your phone in dry place and dip it in water absorbing material like rice,sand,wheat
Posted on Apr 25, 2010
How can repair a wet mobile cell?
Samsung Galaxy Smartphone: Water damaged phone: How fix:
Hello.. the procedure:
Electricity and water do not mix. If continue to use water short circuits chips inside making your phone's motherboard burn out = phone as a paperweight
1. Do not try to use your phone. Power it off. Immediately, if able to: remove the battery back door and take out the battery.
If you turned the phone on after getting wet, you probably shorted something out.. If you never turned it off and kept using it thinking it is fine.. but time passes and the phone continues to act up.. you are probably killing your phone as the water continues to damage the motherboard. Once you turn off the phone, consider the phone dead, because trying to turn it back on with spark energy to the motherboard frying it in the process. (I've seen that happen several times)
(if for example, you have a s6 family/note 5 whereas the phone where the battery does not come out without breaking the glue seal to take it out, leave it in. just power off the device.)
2. dry it off with a towel, shake out any loose water droplets inside the phone
3. use a hair dryer on low setting to try to dry out the phone... no hair dryer? set your phone out in the sun, but don't bake it.. (what you are trying to do dry up any water that might be inside)
4. get a empty container that's bigger/taller than your phone by at least 1/2 inch on either side, fill it with rice and submerge your battery-less and battery backdoor-less phone for 24-72 hours.
(the rice will dry out your phone. this takes time. water is usually trapped underneath the chips on the motherboard where you would not be able to get to dry off unless you un-solder the chips)
5. If you phone doesn't turn on after that.. it means that the water has either fried the chips on your phone and/or corrosion from water that is undried in the phone has effectively made it useless. You can't send it back to Samsung to fix, because it is your fault. Water damaged phones will cost anywhere up to $300 to fix. Consider all data on the phone lost. Time to buy a new phone.
If the phone turns on but something doesn't work, it means you shorted that part of the phone out.. Don't bother sending it to Samsung to fix because it was your fault. Take it to your local cell phone repair shop to fix. Ask them for a quote or at least get a diagnostic inspection to see what might be fixable. Explain it was water damaged upfront. Assess the damage costs to decide if you want to repair it or not
If the screen is black and you get a constant flashing red light that won't stop.. that indicates to service technician that your device is water damaged. Don't try to trick servicing shops about fault, there are water indicators in your phone that tells them it was your fault. Best to man up and tell the truth before you waste your time and money.
Feb 07, 2016 | Samsung Galaxy Cell Phones
Is my phone done?
if the rice trick does not work, you can also try blow drying it on low heat, but at this point, sadly, it probably is
Jun 05, 2013 | LG Dare VX9700 Cell Phone
Need unlock code for PCD model TXT8026C
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
Jul 23, 2012 | Nokia 6230i Cellular Phone
Cannot store numbers for One-touch dialing.
I can.
A lot depends on where you're trying to store these numbers and how you get an outside line. In my system, I dial "9" on the intercom and it gives me any available outside line. Also, IIRC a 7453 has 24 buttons with LED's on them. So, the Pana trick is the digit "2". Try this: PROGRAM 99, touch a button with an LED, and dial 2 + 9 + your number and STORE. The "2" tells the system to use the button as a "one touch" button. In other phones, the "F" buttons (ones without lights) already assume the "2" so it's programmed with just the access code "9" and the number.
Carl
Mar 11, 2011 | Panasonic KX-T7453 Corded Phone
Phone "died"
i have the same problem with my txt8026c. im sending it back to the manufacturer. it comes wit a 12 month warranty
Jun 30, 2010 | Pantech PN-218 Cellular Phone
Car kit?
No you won't, all you have to do is, while the phone is on, stick a piece of tin foil (a SMALL piece, preferably folded up) into the slot where you plug in the charger and wiggle it around until the phone shuts off. Then plug it in, turn it back on, and everything will be back to normal. The same thing happened to me and this advice was given to me, so I tried it and crazy as it sounds, it worked. Don't waste your money getting it repaired when it doesn't require anything more than a little foil. The number one cause of "car kit" is: babies sticking the phone in their mouths. :)
May 11, 2010 | LG VX8300 Cellular Phone
I have a TXT8026C that i changed the security code
usually the 4 digit code is the last 4 numbers of your cells number...
does anyone know how to fix this problem? My cell does voice calls in and out with no issues, I can send text messages out, but I do not get text messages coming in. I only got 4 on the day it was activated and once by tech support. Now I cna use the cell for voice calls in and out and text sent out... how do I make the phone allow me to receive text messages?? another site said to upgrade-update software but that option is not in my phones menu at the settings section.
Nov 14, 2009 | Pantech PN-218 Cellular Phone
Samsung sgh-a737
You need to place the phone in a bag of rice for 24 hours. This usually works to get all the moisture out of the phone. I hope this trick helps.
Jun 23, 2009 | Samsung SGH-a737 Cellular Phone
Cell phone will not turn on when only using battery power
Have you tried leaving it over night plugged and on and see if that helps? If u pulled it out of the water quickly, that might do the trick.
Mar 09, 2009 | Samsung SGH-a437 Cellular Phone
My handset 3230automatically restarts and ask web connection
turn off ur mobile.
follow the folwing instructions.
press and hold this 3 buttons till the phones start
1.green button use for accepting calls.
2. * key there on the keypad.
3. number 3 in ur keypad.
now start phone
press and hold untill the phones starts
it takes some time then normal bootup of ur phone
but it will reset ur phone
another trick is
*#7370# and call from ur phone
try this both trick it works
Nov 25, 2008 | Nokia 3230
Cell Phones Logo
117 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
