Question about Emerson LC320EM8 32 in. LCD TV
32inch Emerson lcd tv with 2 black lines running from top to bottom how do I get rid of them?
SOURCE: hyundai 42inch plasma tv
have got 2 or3 1inch thick black lines running top to bottom of screen how do i get rid of the black line
Posted on Jan 23, 2007
  • 58 Answers
SOURCE: I have a 37in LCD
sounds like a failed backlight or inverter.
larger LCD sets use multiple lamps horizontally across the screen.
Posted on Dec 06, 2008
dsacco86
  • 1077 Answers
SOURCE: Shuts off automatically after 2 seconds
Hi, you're one of many people with this problem.
The problem is the Inverter transformers on this board here:
6f139ad.jpg You can see 6 of them lined up in the front of the board. The windings in the Inverter Transformer are very small copper wire that breaks easily. My new TV lasted 4 months until this problem occurred. I had to solder in a new Inverter to fix the problem.
The board number is BA71F0F01042.
The board is hard to find right now. Only three places I know of to find it.
Ebay,
Discount-Merchant.com,
and Shopjimmy.com
You can replace the whole board or replace the bad Inverter to fix the problem.
Let me know if you need any more help.
Posted on May 10, 2009
roety
  • 585 Answers
SOURCE: 42 inch samsung plasma tv black vertical lines
Hi, Depeending on the thickness of the lines matters. If the lines are Black and about 1-2 inches thick it may be a bad bottom buffer board or a bad panel (screen).
If the lines are thin 1/16 to 1/8 inch it is most likely a bad panel.
You can open up the set and depending on the model, see the thin board/boards running across the bottom with ribbon cables going to the panel. You may be able to attempt reseating the ribbon cables, but be careful as some retainer plugs break very easy.
If the lines are thick black and the reseating doesn't correct it you may be able to buy the coresponding buffer. Unfortunately some bottom buffers are actually part of the panel. If you are not comfortable taking it apart then call a professional but be aware labor charges start around $200 not counting parts, panels start at $600 up to over $1000
hope this helps
Thanks
Eric
Posted on Aug 19, 2009
SOURCE: emerson 32 inch lcd tv two years old has lines
I don't know anything of this particular TV, but what you describe is generally a known problem in LCD displays.
it's caused by one of two things - either parts of the LCD film thin film for the vertical lines detatching from the board it is glued on or certain micro controllers that are also glued on the LCD film starting to get burned bit by bit. In both cases, the whole vertical line responsible for one of the three colors that a single pixel consist off get dead and depending on how they get dead they get either all open or all closed, respectively completely turning on or shutting off the particular color.
It is most commonly the first case, but whichever of the two it is, there's no known cure for it within reasonable cost.
I've experimented a few times and was able to press the film to the board by using firm objects and fastening the display case, but it would often cause more harm than it brings and even more often it would just not hold reliably. Overall I do not recommend experimenting with it it unless you have lots of time on your hands and you're ready to face an evern worse damage.
In a very rare cases it might also be the tcon also known as LCD controller...but from what you describe it's hardly it. It's worth trying, but if I had to take a guess I'd rather rule it out - it sounds like the LCD.
And the bottom line is you just have to face it - you likely need a new TV. If there's some chance for me to be wrong, try the tcon board at the back first. Then just sold the TV on eBay or CL for whoever gives you most and apply the money towards the new purchase.
Don't kill me, I'm just the messenger :-)
Posted on Nov 09, 2009
My 42 in phillips LCD flat seen has a black horizontal line toward the bottom how can I fix this.
Samsung LN46B650 Thin Black Horizontal Lines - Forums - CNET
www.cnet.com > Forums > Samsung
CNETI'm experiencing thin black lines from the top of the screen to the bottom. ... by babes808gpa / January 15, 2010 1:42 AM PST ... lines are about 1/4 inch apart from top to bottom of screen. starts on the right and about a 1/3 of the way toward the ...have the exact same problem, my lcd tv has multiple lines are horizontal it ...
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the ...
? 3:05
https://www.youtube.com/watch?v=KiqJuMiEiak
Jun 8, 2013 - Uploaded by Sameh Moustafa
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the picture SOLVED .... I just have one black line ...
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Dec 20, 2015 | Televison & Video
2 days ago, a narrow black horizontal line appeared in the middle of the screen.
CNETJun 11, 2015 - I'm experiencing thin black lines from the top of the screen to the bottom. ... my lcd tv has multiple lines are horizontal it starts from the right and fades too the left, ... Samsung LN55a950 - Horizontal lines on right side - Forums - CNET
Jun 11, 2015
Samsung 52" LCD TV black lines - Forums - CNET - CNET.com
Jun 10, 2015
More results from www.cnet.com
Plasma TV Repair Horizontal Lines - How to Diagnose ...
? 2:49
https://www.youtube.com/watch?v=h4XWCxUsSVU
Sep 2, 2014 - Uploaded by ShopJimmy.com
I have thin horizontal black lines on the top and bottom areas of my TV. .... Hi, I have a 2011 64-inch 3D Samsung PN64D8000 Plasma TV.
how to fix horizontal or vertical lines on lcd tv - YouTube
? 4:52
https://www.youtube.com/watch?v=k2QpYJp6MU8
Apr 12, 2014 - Uploaded by cr4zyw3ld3r
Hi my LG 47ln5700 tv set has thin greyish black horizontal lineson one side of the .... I hope this works good with Samsung LCD as well....
Dec 19, 2015 | Samsung HP-R5072 50 in. Plasma HDTV
Black line through middle of emerson led tv screen
Sounds like panel fault. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Screen-shots to defective LCD panel are given. You can compare it to that of your TVs'.
Apr 23, 2014 | Emerson Televison & Video
How do I set my remote-control to my Emerson,LC320EMX hdtv 32inch
Google the model number with "manual" or as last resort contact Emerson customer service.
Dec 17, 2012 | Emerson LC320EM8 32 in. LCD TV
LG plasma 50 inch tv with a fine vertical black line in the center of the screen that runs from the top of the screen to the bottom
Try changing the input device to something you are sure works. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Jul 25, 2012 | LG 50PG20 50 in. Plasma HDTV
I have a Polaroid TDA 03211C 32inch LCD TV /DVD COMBO screen went black cant get screen to work,sound works
It has 2 blown capacitors in it. Mine had the same problem. The capacitors are located at EC17 & EC18 on the top circuit board inside the tv. They cost about 1.00 a piece. You can get them at DigiKey.com. It is very easy to take the board out and have someone soldier the new ones in and then put it back together. You can fix it for about 40.00. Hope this helps. Do a search on line of what the capacitors look like........
Nov 01, 2010 | Polaroid TDA-03211C 32 in. LCD HDTV
TV HAS BKACK AT BOTTOM AND TOP AND PICTURE WAVES
you have a fault in the power pack, ths can only be repaired by a tv engineer..
Sep 27, 2009 | Emerson LC320EM9 32 in. LCD HDTV
Black screen with a line of the picture running
The vertical sweep generator is dead. The circuit that controls the lines being drawn from top to bottom has malfunctioned or died. This not something you can fix, you will need a professional.
Apr 02, 2009 | Emerson EWF2703 27" TV
I have a 37in LCD Emerson tv and there is a division line in the tv. Top is normal bottom is dark. How do i fix it
Dec 03, 2008 | Emerson EWL3706 37 in. LCD Television
Emerson LC320EM8 32 in. LCD TV Logo
192 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
