Question about Car Audio & Video
My 12 inch pioneer sub does not seem to be working, it and my pioneer amp (one channel 1200W) are 3 yers old and I know it is either one or the other. Using a multimeter I have measured the speaker output from the amp to the sub and only get readings of around 10mV. So I know the sub is getting some power to it, though looking online I believe the voltage should in fact be approx double whats going in to it, is that right? Are you able to diagnose the problem with that information? There is nothing wrong with the fuses on the amp etc, and full voltage is getting to the amp aswell. What kind of voltages should be expected coming out of the amp to make the sub work properly?
  • frederator Apr 25, 2010
    Cheers, yeah I pretty much figured it was the amp. I used the formula P=VI gathering the voltage and amps from the amp output and dont even getting a power rating of 1 watt, so makes sense that the amp is gone.
    Thanks
  • 2,335 Answers
I don't have a reference in front of my of what voltage your amp should be pushing, but I can pretty much guarantee its not working if you are measuring a level in millivolts. Thats more like line-level output from your head unit. (measure your head unit as reference.)
The basic math of power is W=EI, that is Watts=Output Voltage X Output Current.
So take the maximum draw of your amps fuses (60A? 80A?) and go E=W/I or E=1200/80=15. Using this example you would expect your amp to be pushing 12-15 Volts, not millivolts.
You could always try hooking a speaker that you know works up to the amp, and an amp that you know works up to the speaker to strengthen the case for the amp being the problem.
I hope that helps.
Posted on Apr 25, 2010
What amp for a Pioneer TS-W304C 12 inch sub
You seem to be looking for an amp made for car audio. There are many brands, but I going to give you the specs for your particular speaker which will help in choosing, not a specific name brand amp, but at least one with the proper power outputs/requirements.
Your speaker, based on the model number you provided, is rated at 4 ohms .Power handling range is 50-300 watts. And a peak of 600watts. That does not mean start cranking 600watts thru the speaker, it will blow. I suggest you acquire a single (mono) channel amp that provides 350-400 watts at 4 ohms.
Hope these specs help you in choosing an amp.
Jan 07, 2013 | Car Audio & Video
Can you run a 1200w pioneer sub and 2x9x9 inch car speakers to a 600w pioneer 4 channell amp??
depends on what the RMS is for the subs because although the subs are 1200 watts, there is a minumim standard you have to follow. If you don't atleast run the lowest wattage thru them, then you will most definately damage the speakers....you should also be aware of the fact that your "600w Pioneer-4 channel amp doesn't even push a true 600 watts... Your best bet is to upgrade ur amp, or add an additional amp to your set-up. And you really need to pay close att to over or under running your power to your stereo system because you'll burn out ur altenator rather quickly. Use proper wattage , and you should also look into getting a power-cell which lessens the chances of destroying your altenator and helps to ensure that your stereo system sounds to its full potential.....
Feb 15, 2011 | Pioneer DEH-P6400 CD Player
My amp is 2 ohm stable what subs should i get?
Two 12 inch dual 2 ohm sub woofer will be perfect wired in parallel.
-david
Nov 10, 2010 | Pioneer A109 2-Channel Amplifier
Ihave a gm-d84004m 1200 watt amp whatsize amp wires should i use
if you are talking about the power and groung use atleast 4 gauge for the subs i usually use 10-12 gauge
Jul 10, 2010 | Pioneer Gm-d8400m 1200w Max, Class D Mono...
I have two 12 inch rockford p1 punches powered by an 800 watt sony explode amp (2 Channel) and i want to install another 15 inch kicker with a 1200 watt amp not sure the model, i got it from a friend and...
I have a similar setup & I just run the second amp straight off the other amp by running positive & remote wires directly from 1 amps positive & remote inputs to the others amps inputs. But my head unit has RCA inputs, (sub in & front & rear inputs) so from my 4 channel amp I run 2 6 inch alpine S's to the front to the front RCA inputs of the head unit, & 2 Pioneer 440w 6x9 inch speakers to the rear inputs. & my 800w 12 inch sub from my 2 channel amp to the sub woofer inputs on the head unit. Has blown my eardrums for nearly 12 months now great stuff! Hope this has helped
Mar 12, 2010 | Sony Car Audio & Video
Settings for a Sony Xplod 1200 watt amp, with two 12 inch subs
What kind of subs are you running? Meaning what brand, what are the ohm, spl and wattage? I'll look up your amp while you get that info to me. Looking forward to helping you:) Thanks!
Apr 08, 2009 | Sony Xplod 1200W Class AB Bridgeable 2-Ch....
Help me...
If you had 4 single voice coil speakers you can create either of those 2 ohm or 4 ohm setups. If you run 2 of them in parallel you will get the 4 ohms. If you run 4 of them in parallel you will get the 2 ohms. In parallel I mean that you connect the positives together and run them to the positive on the amp and the connect the negatives together and run them to the negative on the amp. Let me know if you need more help. Good Luck.
-Andrew Hawkins
Jun 24, 2008 | Cadence TXA 6004 4 Channel High Power...
Car Audio & Video Logo
18 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
