Question about Samsung PCN5425R 54" Rear Projection Television
Samsung 46inch rear pro
Iv had my answer back and said its the dmd board. were do i get it fixed and cost please. ennn
  • 59 Answers
Hi..not sure where you are but where I live it cost $250.00 to repair the DMD (Digital Mirror Display) board or $970.00 to replace it. I would check at the store you purchased your TV at or even look in the yellow pages.
Posted on Mar 25, 2008
71 inch Samsung DLP TV with white dots model code HLS7178WX/XAA how do I fix
Buy a new DMD Chip and replace it yourself only cost you $159 which save at least $100 to ask a repairing center to do it for you. Check the video how to do this. Source: DMD Chip replacement tips And your DMD chip should looks like
Mar 16, 2011 | Samsung Televison & Video
White spots are just emerging on my 46inch
There seems to be an issue with your DMD board, which is the on in charge of the pixelation. What you can do to confirm if it's indeed the DMD board, is the following: GO to the menu on the TV and if the dots show in the menu, it's your DMD board, but if they don't the issue might be with one of your Video Boards.
Dec 10, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
I'm getting white spots on the screen on my Samsung HL-R4264W TV. i heard there may be a free fix from Samsung. does anyone know who to contact?
Hello! Those white spots are most probably to be the DMD board, I'm not sure Samsung will fix it for free, you will need to call them and ask. The board is not that expensive. on the other hand, the installation will need to be done by a technician since it's a board and you want to be very careful with the boards that are around it.
Dec 09, 2009 | Samsung HL-R4264W 42" DLP HDTV
TV Screen 'freezing' while watching.
Most likely the DMD board is at fault. If the DMD board is failing it will hold the data lines in the set down which will cause it to stay on until you unplug it. The part number for the DMD board is BP96-00249A but I suggest you have a technician verify the issue and replace the board as it requires mechanical alignment after wards. Please take a moment to rate my answer. Thank you.
Nov 18, 2009 | Samsung HLN437W 43" Rear Projection HDTV
Own a Samsung DLP TV 42 inch and white dots have
The random whit dots you are seeing is more than not the DMD or million little mirrors board. The white spots represent some of the mirrors that are sticking in the on position. In that case they are always reflecting white light from the lamp. I don't concider the DMD board a do it yourself repair since on the older DLP set it requires mechanical alignment as well. The best thing to do is contact a techincian and see what they might charge to repair the TV for you. Please take a few moments to rate my answer...Thanks..
Nov 15, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
The fields of stars shows up on the tv. Is this a big issue?
The white dots/stars you are seeing is a failing DMD board. It is the board with the million little mirrors on it. The white dots are mirrors stuck in the on position always reflecting the white light from the lamp. The DMD board is a technician replaceable item and part number varies by model code. Please contact a local servicer to have them look at your TV so they can order the right part number for your DMD board. Please take a moment to rate my answer. Thanks....
Oct 25, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
I have black spots on my samsung dlp tv
I had the same problem with my Samsung DLP tv a couple of weeks ago. I had to clean the lenses, mirrors and the DMD sensor to fix it, you must remove the rear cover to do this. If the mirrors and lenses were cleaned but the spots were still there, the final thing to do is to clean the sensor chip on the DMD board. It is located under the heat sink behind the small fan in the lower center of the rear of the TV. The DMD board will have to be removed to get to the back of the sensor. All you have to do is blow some dry canned air across it to remove the dust, do not wipe it with anything. The repair is somewhat complicated and you will probably have to realign the picture by adjusting the position of the DMD board when finished.
Jul 16, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Samsumg 46 inch rear pro tv
This is very common in Samsung DLPs. The DMD board is going bad. You will need to replace it.
Mar 21, 2008 | Samsung PCN5425R 54" Rear Projection...
VERTICAL LINE ON SAMSUNG HLN617W WHEN USING ANALOG INPUTS OK WITH COMPOSITE INPUTS AND COMPUTER
Nope, nope and nope... It's likely the DMD board and unless you have some SMT (surface mount technology) equipment just laying around you're not repairing that board too easily... You could however remove it and send it in to PTS for rebuild at about half the cost of a new replacement..
Bill
Dec 08, 2007 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
Fan
one is located behind the DMD bord and One above the lamp blast
Dec 05, 2007 | Samsung HLN5065W 50" Rear Projection...
Open Questions:
Samsung PCN5425R 54" Rear Projection Television Logo
37 people viewed this question
Jerry Greenberg
Jerry Greenberg
