Question about Dryers
The drum doesn't spin. The heat works and the
The drum doesn't spin. The heat works and the timer works
  • 5,911 Answers
This is most commonly caused by a broken dryer belt, or a belt that has slipped off the idler pulley. Please post back with your MODEL NUMBER and I can explain how to access and/or replace the belt.
Posted on Apr 25, 2010
No heat from dryer
If a Gas dryer look first to see if igniter is coming on or if drum where clothes are gets hot or not.
Dec 10, 2012 | Dryers
Doesn't spin but it heats and blows air
probably the belt snapped that spins the drum
Feb 01, 2012 | Roper RES7646KQ Electric Dryer
Ld lg3788w gas dryer drum won't turn
not a good model number,most likely you have a broken belt as long as it starts,heats but the drum doesn't spin,if you get a buzzing sound and it doesn't start you could have something stuck in the blower wheel,the motor is jammed or the motor is bad,you can open the door,push the door switch in,spin the drum with your other hand and have someone push the start button,if it starts you have a bad motor.
Nov 27, 2011 | Dryers
Dryer does not heat up. Air dries, timer works, drum spins, but no heat.
Your heating element is bad go to a maytag or whirlpool servicer and get one for about $50. this will Fixya
Nov 08, 2010 | Maytag Dryers
My wirlpool dryer drum spin but not heating at all.the timer count but not heating.
If it heats up for a few minutes at the begging and after that goes cold – make sure it is leveled and get good air flow, replace the coils.
If it doesn’t heat up at all, replace the thermo fuse.
Sep 14, 2009 | Whirlpool Dryers
Tumbler spins, heat won't go on, timer won't work
It is your operating thermostat. It controls the heat and runs the timer down.
Jul 07, 2009 | GE DVL223GB Gas Dryer
Hotpoint Dryer Heater stays on when door is opened
Strange. Heaters usually shut down with the spinning drum when door is open. If you check the schematic for unit you can check to see if in fact this is correct operation. Attached site usually has schematics for appliances. You might want to check. Search Over 2 1 Million Appliance Parts
Sep 01, 2017 | Hotpoint NVL333EY Electric Dryer
Roper Electric Dryer Heats but drum won't spin
Yank the filter out the top. Remove the 2 screws in the filter housing. Use a putty knife to pop the top and then remove the screws holding the front on. NOTE: raise up on the front panel slightly so you won't damage the bottom clips. Get the front out yer way and remove the drum. Clean out the dryer and oil the rollers and idler. Use this handy ROUTING GUIDE to see how to put the belt back.
Jan 20, 2009 | Roper REX3614KW Electric Dryer
No heat, timer not advancing
If the timer advances in timed cycle but not automatic, you have a bad heater thermostat.
Apr 10, 2007 | Kenmore 62622 Electric Dryer
Dryers Logo
48 people viewed this question
Top Dryers Experts
