Question about GE Profile DPSR475GW Dryer
Dryer squeaks like crazy!! how do i fix? - GE Profile DPSR475GW Dryer
  • 523 Answers
Replace front glides and rear bearing
Posted on Apr 25, 2010
I have a squeaky dryer
You have a belt that goes around the barrell and the belt has a tension pulley on a tension arm. Those pulleys go bad. It is an easy fix. It takes longer to get to the pulley than to fix it. It is a 4 minute fix, but it will take a while to take off the housing to get there.
May 08, 2015 | Frigidaire FER641FS Electric Dryer
My kenmore stackable dryer squeaks really loudly. how to stop this it's making me crazy
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Jan 23, 2011 | Kenmore Dryers
I have a FP Electric Dryer DEGX1US and it is squeaking like crazy! Can you help?
more than Likely the rollers that hold the drum,, you have to remove the drum (be sure and look before to see how the belt tensioner is set up) pull the drum, Lube the rollers , and reassemble
Aug 02, 2010 | Fisher and Paykel DEGX1 Electric Dryer
GE washer squeaking
Make sure the felt on the rim of the drum is secure and the plastic glides that the drum sits on are not worn down.
Jul 27, 2010 | GE Dryers
Dryer squeaks like crazy.
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
May 27, 2010 | Maytag Neptune MDG5500AW Gas Dryer
My dryer is squeaking like crazy. What is wrong
all dry have roller that the dry drum roll on an all so there a little wheel that the dry belt go around you may need to replave them are if you know have to take the dry apart an clean the lint out of the botton of your dry an if you left any item in your pocket you will find them in the botton of your dry make sure you unplug your dry b4 you work on it ok
Apr 24, 2010 | Frigidaire FEX831CS Top Load Stacked...
My dryer started making a squeaking sound. It's
Belt needs to be replaced,have you ever had a car drive by and heard a squealing noise? dryer belts "glaze" and squeal due to wear just like the ones in your engine
Apr 01, 2010 | Frigidaire Electric Dryer
Squeaking sound on new samsung dv448aew dryer
first off you need to put your foot down and tell them to replace the belt or the adjuster .dont let them leave until they have satifyed you
Mar 24, 2009 | Samsung DV448AEE Electric Dryer
Maytag dryer squeaks during cycle
if replacing the rollers didn't fix the squeak, you need to replace the teflon drum slides and drum gasket material. mine sqalled so much it would run you out of the room. now it's quiet.
Jan 19, 2009 | Whirlpool LER5636P Electric Dryer
Bosch Dryer squeaking noise
I have not seen any service manuals online. The squeak will possibly be a rubber bush used to silence the machine. If you get it stripped down you should be able to locate the squeak by carefully applying pressure in different areas and the squeak should go... then hopefully you will have found the culprit.
Mar 15, 2008 | Bosch Axxis WTL 6003 Electric Dryer
Dryers Logo
113 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
