Question about Sony PlayStation Portable (PSP) Console
Memory stick error
Hi guys my memory stick is can be read by my computer i also format it using my pc w/ windows vista but the problem is my psp doesnt read any files on my psp and it also just blink blink!! after plugging my memory stick twice or thrice my psp reads it but only display 0KB in my memory stick it does not recognize it.. but when i plug it harder it gives the right data about my memory stick but does not shown any files.. i know this is kinda weird problem,but any help is well appreciated.. thanks..
  • 4 Answers
FIRST U FORMATE U R MEMORY STICK FROM PSP THAN U SEE IN PC SOME FOLDERS U CAN COPY IN THAT FOLDERS ONLY THAN IT WILL RUN IN psp
Posted on Apr 25, 2010
Tip
How To Recover Data From Various Types of Sony Memory Media
The Memory Card File Rescue Service is used to recover data from various types of Sony Memory Media. This software can be used on all Sony brand Memory Sticks, SD Memory Cards and USB Flash Drives except:<br /><br /> * Non-Sony brand Memory Stick and SD Memory Card<br /> * Memory Stick for AIBO robot<br /> * Memory Stick ROM for electronic dictionaries or e-Book readers<br /> * PSP brand Memory Stick, or Memory Stick Micro<br /><br />Note: Defect or damage of a memory card itself cannot be recovered.<br /><br />What type of files can be recovered?<br />JPG (DCF), MPEG-1, MP4(MPEG-4, MPEG-4 AVC) file, and other types of files. This software analyzes FAT file system and recovers a file regardless of file format whenever possible. Recovery of all data is not guaranteed as some files may not be recoverable.<br /><br />Compatible Operating Systems<br /> <ul> <li>Windows 7</li> <li>Windows Vista</li> <li>Windows XP</li></ul> <ol> <li>Log on with an Administrator account when installing Memory Card File Rescue software for Windows XP, Vista and 7.</li> <li>Download the Memory Card File Rescue Service from here: <a href="http://support.sony-europe.com/rme/downloads/downloads.aspx?m=DCR-TRV355E&f=MS_Rescue">http://support.sony-europe.com/rme/downloads/downloads.aspx?m=DCR-TRV355E&f=MS_Rescue</a></li> <li>Install the software and run the Memory Card File Rescue Service.</li> <li>Follow the prompts to recover your Memory Card Data.</li></ol>
on Mar 13, 2011 | Computers & Internet
MY memory stick can be seen and read in my pc but doesnt work on my psp
  • Flash Storage:
  • Memory Stick PRO Duo Expansion Slot pspphatmodelnumber.gif pspslimmodelnumber.gif pspbritemodelnumber.gif
All flash storage, including Memory Sticks and internal flash, uses the FAT32 file system. http://us.playstation.com/support/answer/index.htm?a_id=1055
The above shows how to format the Memory Stick PRO Duo in the PSP so the correct file structure will be shown.
Be sure to back up any data on the Memory Stick PRO Duo before doing this as all data will be lost on the Memory Stick PRO Duo device.
Aug 06, 2010 | Sony Memory Stick PRO Duo (2GB) for PSP
Well I got a new psp with a 2 gb memory stick produo with a Memory Stick Duo Adaptor. Well this is the problem: When I insert the adaptor with the memory stick inside my computer won't show any files it...
Put the card back in the computer and format it using FAT (not NTFS) format. In the format menu, you'll see the file system pull down option, choose FAT and try and format it again.
Thanks Mark
Jun 24, 2010 | Sony Memory Stick PRO Duo (2GB) for PSP
Vista insists on formatting any memory card I use
you must check your device manger in your computer and look there device microsoft iSCSi initiator if your not found in your device manager in your computer system you must update this device microsoft iSCSi initiator includ to your system computer. good luck
Apr 24, 2010 | Microsoft Windows Vista Home Premium...
My psp memory card dont let me put stuff in
you may have to format the card. Also make sure your card is not placed in the lock position.
    How to Fix a PSP Memory Stick
  1. Step 1 Upgrade your PSP's Firmware (its operating system) before doing anything else. Firmware 5.0 solves many software problems that are encountered with older memory sticks. You can upgrade it by simply connecting your PSP to any wireless connection through its WiFi. Once a connection is established, the PSP will update itself automatically.
  2. Step 2 Check to see that your memory stick's plastic tongs, the small sticks that separate each connection, are straight. If one is bent, your PSP will not recognize the stick.
  3. Step 3 Remove your memory stick if it still does not work. Insert it into a PC with a memory stick slot. You will most likely be able to see all of your saved files. If so, continue to the next step. If you still cannot see your files, then your memory stick is defective, and it is not the PSP's fault.
  4. Step 4 Copy your files from the memory stick to the hard drive.
  5. Step 5 Format your memory stick using the "Format Disk" option in Windows. Open Windows Explorer, and find your memory stick listed in the "Drives" section. Right-click on the memory stick, and click "Format." Follow the on-screen instructions in the windows that pop up.
  6. Step 6 Insert your memory stick into your PSP. It should recognize the disk now. However, you now need to format the memory disk again with the PSP.
  7. Step 7 Go the PSP main menu, and select "Settings." Then select "Format Memory Disk."
  8. Step 8 Put your memory stick back in your PC, and return the files you removed earlier. When you reinsert the stick into your PSP, it should now see all the files.
Mar 25, 2010 | Sony Memory Stick PRO Duo (2GB) for PSP
Can't read the files on hte memory stick
Backup your files and format the memory stick using the PSP your having problems with.
it is possible that the memory stick being used was formatted using a diff firmware.
May 27, 2009 | Sony PlayStation Portable (PSP) Console
Memory stick
Connect your psp on your computer and after go in the file
MY COMPUTER and right click where your psp icon aprears amd there will be many options. To format your memory stick just click on FORMAT. If it doesn`t work you can just go in your psp menu and go to system settings and theere if an option called format memory stick. It will automatically fix your memory stick and after formatting it your memory stick will be completely empty and it should work.
Mar 08, 2008 | Sony PlayStation Portable (PSP) Console
My psp wont read the memory stick
Format the memory-stick As FAT In Windows ( On A PC )
Then re-format The Memory stick in Your PSP.
This Should Solve Your Problem.
Mike @ Compurepair.
Feb 24, 2008 | Sony PlayStation Portable (PSP) Console
PC doesnt recongize my memory stick as a formatted memory stick...
Do both systems run XP? Also, check the driver files on your PC, and test it with another card of the same make. Is the write-protection switch set to on? Test the card reader with other formats of cards, if it is a multiple reader, just to make sure that it is functioning at all.
Jun 04, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
127 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
