Question about Logitech Harmony 890 LCD Remote Control
My Harmony 890 remote has a difficult time inputing numbers
If I try to input numbers for the channel it jumps ahead and puts numbers in. While typing in 150 it will put in 1500 or 1150. While trying to use the channel up or down it will jump more that one channel. I have reprogrammed the remote twice, It seems to fix it for a short time (1-2 days) and then its back to the same problem
Hi. This problem is caused because the 'repeat' setting on the device that you use to change channels (TV or cable box) is too high.
1. In the software, click 'Troubleshoot' next to the icon for the device that you change channels on.
2. Select '<device> responds to some commands either too many times or only occasionally' and click NEXT.
3. Decrease the setting by one (the default is usually 3).
4. Update your remote and test it.
Posted on Apr 26, 2010
My Harmony 890 will not change the channels through my U-Verse box unless I am 2-3 feet from the face of the unit. The volume control works fine with my receiver.
Hi. This could be an issue with the IR emitters on your remote wearing out, or your U-verse's IR receiver could be faulty. Try controlling the U-verse with the original remote. If the same thing happens with the original remote, then it is the IR receiver (U-verse) that is the problem. If the original remote is able to control the device from the normal distance, then your 890's IR emitters are the problem.
If you find that it is the Harmony remote that is the problem, try doing a firmware update as this often solves issues. To update the firmware on your remote, log in to the Harmony software, click "Downloads" at the top of the screen then click "Firmware."
I hope this helps.
D
Aug 20, 2011 | Logitech Harmony 890 LCD Remote Control
Tip
Harmony 890 Manual Download
Download Logitech Harmony 890 Remote Control Manual
Have you misplaced your Logitech Harmony 890 Remote Control Owners Manual?
Would you like a digital, searchable, pdf version of the Logitech Harmony 890 Remote Control Users Guide?
Follow this link to download a pdf version of the operations manual.
I hope that helps.
__________________________________________
Logitech Harmony Firmware Update
Harmony Mac Software Download
Harmony Win Software Download
Logitech Harmony Safe Mode Fix
Harmony Remote Glow Light Fix
on Apr 30, 2010 | Logitech Harmony 890 Universal Remote
Tip
I hope that helps.
on Apr 30, 2010 | Logitech Harmony 890 LCD Remote Control
I have been struggling to get the tv to move to the correct input when I switch from watching TV with Tivo to watching a DVD. I thought I'd made the correct selections, but end up either having to use the...
There are 5 types of input switching methods that you can come accross for each device. In the Software is says there is certain input switching methods that go with certain manufacturers - This is NOT the case. The following is the list of all the inputs:
1) Toggle (Method 1): You only use one button on your original remote to cycle through a set of inputs.
2) Discrete (Method 2): You have multiple buttons on your original remote where each button goes to a particular input and stays there, no matter how many times you press this button.
3) Menu Toggle (Method 3): A menu pulls up where you can scroll through the set of inputs and select which input you would like.
4) Menu Discrete (Method 4): A menu is pulled up where you use another set of numbers to select which input you would like. (you do not cycle through each input)
5) Multi Method (Method 5): A combination of any of the above. This can also mean that you have multiples of one of the above input switching methods.
Make sure you follow through the prompts for them but the Method 5 - you would have to contact Logitech Directly to get it added!
Jan 18, 2010 | Logitech Harmony 890 Universal Remote
I am trying to set up the "favorite channels" function on my harmony 880 remote and I keep getting an error message that the channel numbers are not valid. On my TV, for example, NBC is 05-1 (that's what I...
I have seen channel designations like this when using a satellite TV provider. From what I know (which is not a lot, I'm afraid) is that some affiliates offer analog and digital and digital sub channels so an example would be:
05 (main analog channel)
05-1 'digital' (depending on the receiver)
05-2 'digital sub channel'
05-3 'digital sub channel'
etc
So, you may want to try just putting in the main channel '05' when using the Logitech software to program your favorites. Below is a link to a good post on the Logitech forum that tells how to program your favorites. Hope this helps!
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=9691
Mar 24, 2009 | Logitech Harmony 880 Universal Remote...
How do we set the time on our Harmony Remote 890?
You have to update the remote, using the software. This will correct the time
Mar 17, 2009 | Logitech Harmony 890 LCD Remote Control
Need a manual to know how to use the various menus on the remote
The Logitech Harmony 890 remote control is programmed through the
Harmony Windows Setup Software.
Once installed, you will simply run the program and select the devices you would like to control from menus. This program finds the right codes for you and loads them into your remote control.
You can get a copy of the Harmony 890 Manual by clicking here.
I hope that helps.
_____________________________________________
Harmony MAC Software Download
Jan 23, 2009 | Logitech Harmony 890 Universal Remote
Abilities of Universal Remotes
Yes!
When you define different activities (such as Watch TV, Watch DVD, etc.) the remote will ask which of the TV inputs your device is plugged into.  After programming, when you select the appropriate activity, the remote will automatically select the correct input.
Jan 02, 2009 | Logitech Harmony 890 LCD Remote Control
Changes 2 channels at a time
I can help you with your Logitech Harmony 890 remote control.
I recommend resetting it up with your components to get rid of the two channel problem.
I hope that helps.
Nov 25, 2008 | Logitech Harmony 890 LCD Remote Control
Logitech Harmony 890 LCD Remote Control Logo
115 people viewed this question
Top Logitech Televison & Video Experts
Jerry Umali
cwradio73
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
