Question about Amana 3.2 cu. ft. Top-Load Washer
The washer doesn't spin and we are smelling burning belt
    Scholar:
  • 126 Answers
YES YOU ARE. THIS BELT WENT THROUGH NUMEROUS REVISIONS. THIS IS THE MOST COMMON REPAIR. ALSO SOMETIMES VERY RARE THERE COULD BE A WATER LEAK AND GOT THE BELT WET AND THEN THE MOTOR PULLEY SMOKED IT UP.
Posted on Apr 25, 2010
The belt broke and we do not know how to replace it.
Posted on May 16, 2010
2 Suggested Answers
ftw1952
  • 10319 Answers
SOURCE: My washer spins very slowly on spin cycle, almost
if the smell is like burning rubber the belt is stretched and needs replacing
if the motor is at fault the smell will be a foul odor instead.
replace the motor if you can smell the insides of it having that smell
Posted on Nov 18, 2010
Washing machine has smell (burning) and doesnt spin or drain tub.
Sounds like the belt may need to be changed. it eh pulley are spinning but the belt is not, nothing will spin and the friction of the pulley against the belt will cause a burning rubber smell
Nov 27, 2013 | Washing Machines
Maytag Performa clothes washer. Model LAT2500AAE. Made screeching sounds during spin cycle also burned rubber smell. Turned off. Removed and replaced belts. One belt was shot. Ran a test run and still...
Check to see if your water pump is spinning. It could be seized up and the burning smell could be the belt spinning on the seized pulley. Good luck Friend.
Oct 10, 2017 | Maytag Washing Machines
My washer wont spin and it smells like it is burning it is only 3 yrs old
The burning you smell is probably the belt slipping. There is a belt which is attached to pulleys. The belt engages to spin the basin in the washer. When this belt slips the burning smell happens because the pulleys are spinning and the belt isn't. You will probably need to adjust the tension on the pulleys or get a new belt. This can happen from constantly overloading the washer or trying to get the washer to wash and extra large load while the water level is set at a smaller load.
Aug 07, 2010 | Maytag Washing Machines
When washer is spinning it smells like something is burning
A burning smell means you have some slipping of the drive belt. I think your belt needs to be replaced. Another reason may be a binding in the tub. possibly a seized tub bearing. The only way to know is to take off the access cover at the back of the washer and visually inspect it first. you can spin the tub by hand from the back and this will give you an idea of what is binding.
May 26, 2010 | Kenmore 24032\24036 Top Load Washer
Washer wont spin, smells like burning glws1649
Burning smell could be the windings in the motor. Better not to use it and have it looked at. If the smell is a rubber smell then the belt is jammed while the motor spins. still needs intervention as it can catch on fire and you will have a bigger problem than the one you have now
Jul 31, 2009 | Frigidaire Washing Machines
Washing machine spins slowly and smells of burning rubber
The belt could be worn and will be slipping on the pullys, as it spins up the rubber , rubs against the pullys and that is what creats the burning rubber smell, the belt needs replacing.
regards jonno
Apr 21, 2009 | GE WBSR3140DW Top Load Washer
Burning smell and washer will not spin
The buring smell could be coming from the belt, try looking to see if the belt i burnt or broken
Nov 22, 2008 | Whirlpool LSN1000LW Top Load Washer
Washer has burning smell and does not spin.
It sounds like your belt has burnt off. take the front off the washer or tip the washer back to check it. easy fix.
Nov 17, 2008 | Washing Machines
Washer
try to change the belt the belt is burning thats what happened to mine it was the belt burning
Oct 22, 2007 | Kenmore 88732 Top Load Stacked Washer /...
Washer smoke during spin cycle...
could be belts slipping or a bad motor going - what's it smell like - burning rubber or an electrical smell?
Aug 28, 2007 | Kenmore 98702 Stacked Washer/Dryer
Amana 3.2 cu. ft. Top-Load Washer Logo
194 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
