Question about GE Profile DPSR475GW Dryer
Have a bad squeaking noise when turning on dryer. Is there something I can oil or is this a tech problem?
  • 523 Answers
This is something you can do replace the front glides
Posted on Apr 25, 2010
Dryer makes a squeaking/high pitch rubbing noise
bad drum bearing, bad drum teflon pads or both possibly
or both possibly or in combination the belt could need replacing
& if your not sure get a service tech so you dont do more damage
Apr 06, 2014 | GE DVLR223 Dryers
Really Bad Squeeky Noise
It could be a squeal from the dryer belt. It could be from a belt that has gotten loose, like you hear on a car sometimes when it first starts up, but usually they don't get loose. They just break. Maybe something has gotten jammed between the dryer drum and the interior of the dryer making it hard for the belt to turn the drum and so it is squealing. Does the drum turn by hand without too much force and without squealing?
Feb 10, 2014 | Siemens WTXD5300US Electric Dryer
My dryer drum, when it turns, squeals like it needs oiling, and it is hard to turn. Is there a place to oil it? Should the drum turn more easily?
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Aug 17, 2011 | Dryers
My Maytag dryer model # LSG7804AAE is making a lot of noise when drying. It is squeaking and if I turn the tumbler by hand it seems very stiff and feels like it is rubbing against something. Thankyou.
heatman101
Asker
Jan 26, 2011 | Maytag Dryers
My dryer squeaks when running. Is there something I can oil to make it stop?
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Jan 23, 2011 | Kenmore 500 6952 Dryer
Squeaking Noise coming from Dryer
Could be the roller next to the heating element. Heat tends to cause more wear in it. Use some HVAC oil to lube those noisy rollers. 6b5c930.jpg
Aug 02, 2010 | Maytag PYE2300AY Electric Dryer
Whirlpool LEW0050PQ electric dryer makes a noise.
heatman101
sdfhywt4
May 22, 2010 | Whirlpool LEW0050P Electric Dryer
There is a large squeaking noise when the dryer is turned on.
This could be a couple of issues.
The belt is worn and is slipping and needs to be replaced.
The brake is not disengaging and could just need some oil or be replaced.
The motor is going bad and needs replacing.
The main bearing is going bad and needs to be replaced. I know this is not what you wanted to hear but these are the problems it can be
Jun 01, 2009 | Kenmore Dryers
Candy cic60 condenser dryer
The drum itself turns on an axle or sprocket. It may need to be oiled. The motor that turns it may be going bad. The windings and bearing could be bad. I assume it is drying O.K.
Feb 04, 2009 | Candy CDC266 Dryer
Loud Squeaking Noise kenmore gas dryer 80 series
You need to change your drum rollers. To get to them you take the dryer apart from the front not the back. There are 2 screws where the filter goes in on top. Then pull the top toward you and up. Then remove the 2 - 5/16 inch screws on each side of the front panel about 2 to 3 inches down. Then pull the front up and out. Then you will see everything. Replace the belt, drum rollers, and idler making sure to oil each as you re-install them. Then put back together and your on your way.
Dec 07, 2007 | Kenmore 63942 Dryer
Dryers Logo
105 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
