Question about Dryers
DRYER WILL NOT GET CLOTHS DRY
WASH AND GET THINGS CLEAN. NEXT STEP IS PUT THEM IN THE DRYER. IT WILL GO AROUND, BUT NOT DRY. PUT THINGS IN FOR HOURS AND THEY COME OUT DAMP. THIS HAS 01-95 BUILD DATE
  • 1 more comment
  • snowsnake845 Mar 23, 2008
    This a Frigidaire fron loading gas FDG436RBS1
  • snowsnake845 Apr 03, 2008
    The hole on the front does not show a glow.
  • Anonymous Mar 27, 2014
    When the wheel gets to the stop position it just keeps going past it to the next selection
    Novelist:
  • 131 Answers
A dryer needs only three things to dry clothes:
1. Tumble the clothes.
2. Blow the air.
3. Heat the air.
If your clothes aren't drying, you are missing one or more of these.
You've mentioned that the basket is tumbling. That's good. The blower is also running if the motor is turning. But that doesn't mean the air is blowing. It could be clogged up behind the lint screen, in the vent pipe behind the machine, or at the vent outside the house.
If it's blowing lots of cold air (go to the outside vent to find out) then your dryer isn't heating. This would mean some part inside the dryer has failed. If so, the first thing you want to determine is, does the ignitor glow? There's a hole at the very bottom front edge where you might see it glow. You may have to place a mirror in front of the hole to see it glow.
Write back with more symptoms, and I'll help you through the rest.
Posted on Mar 24, 2008
  • Michael Grimshaw Apr 04, 2008
    If the ignitor isn't glowing, that means either it doesn't have power, or the ignitor itself has failed.
    You will need a multimeter to determine what's wrong.
    Unplug the machine. While working inside the machine, it is very easy to get cut on the metal edges.
    Use a putty knife along the front edge, about 2 in from each side to push in the spring clips and release the top panel. Tilt the top up on the back hinges.
    Remove the screw holding the yellow plastic thing on to the center of the top front rail.
    Unplug any wires to the door switch. Remember where they go, but they're also different sized connectors.
    Remove the screws, one on each side - inside the frame, about 6 in down from the top. Pull the top of the front panel out, and lift it off the hinge on the bottom. (it may be hard to pull, as it snaps into place.)
    Check the three white plastic glides across the top of the front felt bearing. If any of them are missing or worn through, it's time for a new top bearing. Set the front panel aside.
    Reach under the basket and disconnect the belt from the motor pulley. Remember how it's connected. Remove the belt from the machine.
    This next step is the most likely place to get cut. You should wear some leather gloves if available. Lift the top rear of the basket to disengage the ball-and socket rear bearing. It should lift up about 1 in. Remove the basket. Check the bearing itself. It should be smooth, without deep rings or gouges in it. The white socket in the back should still have some grease in it, and no rusty powder. A rear bearing kit is available, if needed. (BTW, Use all the parts provided, and the small silver ball goes between the white cup and the bracket behind the machine. A bit of grease will hold it to the cup while you assemble the pieces.) Set the basket aside.
    Now you have access to all the parts that could be the cause your trouble. Every part should allow current to go through it. (Less than 15 ohms.) Use the ohmmeter on the lowest scale. The ohmmeter setting is marked with the greek letter Omega. You will need to disconnect at least one wire from each component as you take your measurements to prevent misleading results.
    I'll list the possible parts in order of probability: There is a thermostat next to the blower wheel. Another thermostat is bolted to the metal housing at the top back right. The black box on the left of the burner tube is the optical switch. The ignitor itself has two white fabric-covered wires going to it.
    Find the part that measures "open" (i.e. the reading on the meter doesn't change when you connect the test leads to the connectors) and replace that part.
    If you don't have access to an ohmmeter, you can bring the suspected part(s) to your local parts store and they will be able to tell you if they are good or bad. But I'd leave the ignitor in place unless you plan to change it (it's fragile and you must not touch the grey part).
    While you have it apart, be sure to clean the chamber under the door, behind the lint screen. Remove the two screws holding on the plastic grate to make this easier. Scrape, rub and vacuum as much lint as you can. This is also a good time to vacuum the lint that has accumulated in the bottom of the machine. Be careful to not blow or shove the lint further into the motor or other rotating parts.
    Reassemble by reversing the above directions.
How to clean clothes with mold
Put the cloths in bleach without chlorine of at least 2 hours. Could be peroxide. Be aware it will hurt colours, so if there are colours this won't work. Don't let the clothes dry.
Then rinse and wash like always (what the label in the clothes say)
Test with one piece first, to see how it works on the clothes you want to clean.
Jun 26, 2014 | Computers & Internet
Tip
How to receive the best dryer repair help on FixYa
There are a couple of things that you should include in your dryer repair question so you receive the quickest and most accurate answers.
1. Model Number
The model number can be located on the model/serial number tag that is located on the dryer.
Make sure you get the full model number from this tag and not the model number from the owners manual.
The model number from the owners manual only includes the first few digits of the full model number because they include that owners manual with many similar models of dryers.
With the full model number I'm able to look up factory service manuals, tech sheets, wiring diagrams, factory service pointers and so much more.
2. Detailed description of the problem
At the very least give a brief description of the problem you are having with your dryer.
Descriptions like 'My dryer don't work' is not very helpful.
Describe what is not working. For example is the not heating? Maybe the dryer is heating, but takes a long time to dry?
The more details you can give the better. Instead of saying 'The dryer is heating, but takes a long time to dry' you could go into more detail and say something like...
"I put a load of cloths in my dryer and set it on the auto dry cycle. When I went to take them out two hours later the dryer was still running. The cloths were still a bit damp too. Most of the time I can dry a load of cloths this size in one hour. Why is my dryer taking so long to dry?"
Following these couple tips can help you get a faster and more accurate reply to your dryer repair question.
on Aug 03, 2011 | Dryers
MY DRYER TAKING TO LONG TO DRY
You need to clean your dryer vent. When the dryer vent is clogged it cant circulate the air.
Aug 26, 2012 | Dryers
I have a GE washer/dryer Model WSM2700RAWWH stack type and the dryer is taking very long time to dry the clothes. Please advise if it can be fixed. If not what will be best alternate washer/dryer stack...
first things first. if any dryer regardless of brand takes 2-3 hours to dry cloths 90% of the time it is your exhaust duct. take the exhaust duct off the back of the dryer and dry some clothes if the clothes dry fast then you need to have your exhaust duct cleaned. either DIY or call a professional
if it still takes a long time to dry then it could be the thermostats or the thermistor.
but in my experience its normally the exhaust duct.
Feb 10, 2011 | GE Washing Machines
Put the cloths in the dryer like usuall and waited for peep to let me know its dry. but when i heard the peep assumed the cloths will be dry, the cloths were just like i got out of the washer, wet. it is...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Feb 02, 2011 | LG DLGX8388 Gas Dryer
I have a LG Electric Dryer DLE5932W. When I run it on any of the settings in sensor dry the dryer turns off before the clothes are dry and you have to run it multiple times to get a load dry. Then if you...
this could be operator error please hear me out...... when wash bath towels you also put in wash cloths and hand towels .... there is a sensor in dryer drum shroud in front of lint filter to metal silver strips when the clothes are tumbling they sweep across this sensor telling the dryer heat to stay on and continue to dry.... if th small wash cloth sweeps it first before the bath towel then u get the same results as your describing just like if you were waqshing colors load like cotton tshirt and blue jeans the tshirt is going to dry way faster than blue jeans so if the tshirt sweeps that sensor first the dryer going to shut off we have to sort our clothes to thickness ans same size articles just try it once i bet your clothes are dry when cycle completes
Jan 31, 2011 | LG DLE5932W Electric Dryer
Dum turns to fast for cloths to tumble, 2 hrs. to dry!!
don't know about the drum turning to fast, but the two hours to dry I do know. Disconnect the vent tube and dry a load of clothes, as there is a restriction in your vent tube. You will need to clean the tube out with a vacuum or leaf blower, you may want to clean the inside of the dryer out,also. Good Luck Tim
Jan 06, 2011 | Maytag Neptune MDG9700A Gas Dryer
Hi, I had purchased second hand MARGHERITA 2000-AB63 Washine Machine. BUt i dont have manual to operate. Pls Help.
i have ariston marghrita 2000 AB 63 it does not clean cloths and does not dry cloths.whenever i takeout cloths they are so wet that water drops out of these cloths. pl tell me what shall be position of different buttons and knob when i wash wash cotton/tetron mix cloths
Oct 25, 2010 | Ariston Technologies Ariston AWD12 Front...
Dryer takes hours to dry
sound like you dry not heating,might need to replace the element
Apr 24, 2010 | Whirlpool GGW9250PL Gas Dryer
Why it take so long for my whirlpool dryer to dry my cloths. When I put in a load of cloths it take about (2) hours to dry. I feel the heat in the dryer, but it not getting hot enough. Could it be the the...
try running the dryer with out the vent hose hooked up.if the dryer works well than you have a blockage some were in the vent line.also be for you pull the dryer out,look behind the dryer to see if the vent line is kinked or massed together.
Jan 24, 2010 | Whirlpool LER4634J Electric Dryer
Dryers Logo
389 people viewed this question
Top Dryers Experts
