Question about Samsung AW0603B Air Conditioner
I have split ac samsung,which has problem with no cooling.. also voltage flactuate when ac start i.e. from 240 to 188.. plz help
    New Friend:
    Problem Solver:
  • 5 Answers
Sounds like the compressor capacitor.As compressor wants to start the voltage drops as compressor drawing to much current ,as capacitor faulty,thus compressor will trip out either on the klixon or internal thermal.Try replacing capacitor they are cheap
Posted on Jan 11, 2015
My friend us hould check your aircon have proper gas and may be there is a problem in your compressor u should chech power current supply of air con its possible there is aircon have short gas problem so contect to your a.c technician for further action.
Posted on Apr 25, 2010
My orient split a.c shows Ec error in digital display
sir plz answer me my ac orien 1 ton showing EC error on display what is this i can't understand what is this plz reply
Jul 12, 2014 | Heating & Cooling
Any body tell me what is the problem with my 1.5 Dawlance split ac It gives perfect cooling in night and morning but in afternoon its compressor turn on and off every after 15 minutes. And due to this my...
when the heat ambient temps go up . the start capacitor gets hot to turn on fan and heat sensor for the compressor senses it and turns off . check the run/start cap first
May 25, 2014 | Haier 18000 Btu Air Conditioner Heat Pump...
Dawlance split ac
My guess is compressor motor overtemp cutout. So why is the motor overheating? Possibles: Needs bearing oil, bad bearings, compressor too much pressure, overfull with freon, mechanical friction, cooling fan not turning.
Suggest set thermostat to demand less cooling, see if compressor stays on longer.
--Gil
SPLIT AC CONDENSER TRIPS AFTER 1 OR 2 MINS, ONLY DURING THE DAY TIME
The condensor is not cooling fast enough. Try cleaning the condensor coil. Also check that the fan goes on. At night the outside temperature is cooler and does not need much work to cool down the condensor.
Jul 15, 2012 | Haier Heating & Cooling
Ac trip down showing voltage flactuation
Either have the line voltage into the house checked or the circuit it is connected to looked at.
Jun 14, 2012 | Heating & Cooling
The SMR40000 and HISO169A ICs was blown whar is the problem?
Hi rg watts2k,
Your unit is samsung tv, Blown SMR4000 and Hiso169a was due to voltage flactuation, shorted on the ac line section or on the rectifier diode. Check also the posistor for short and the degausing coil, check the main filter capacitor for leak. Resolder all bad solder joints in that area. After you check all of this you may now install the new SMR4000 and Hiso169a.
Let me know if you need further assistance.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Feb 24, 2011 | Televison & Video
My 1.5 ton,LG split AC shuts off rather
Hello
First the foam insulation is not just for looks,you will have some loss of cooling on the unit,the larger cooper line needs to be insulated,the small one does not.The large line is the suction line,the small one the liquid line.
Voltage,168 is low,sounds like a 208 volt unit or 220 volt.running at 168 or 198 ac volts is going to raise the amperage causing the compressor to run hot and work harder and soon burn up,And cause it to trip the breaker or shut itsself down on high heat.Your going to need to get that voltage fixed.I dont know why it needs a stabilizer if the unit was sized correctly it shouldnt need one.
Hope this helps.
Apr 14, 2010 | LG LS-K2430HL Heat Cool Mini Split Air...
Split system Samsung AC not cooling
The compressor is not compressing. Either the compressor isn't running or the freon has escaped.
Jul 26, 2008 | Samsung AS18A6RB Air Conditioner
Samsung AW0603B Air Conditioner Logo
179 people viewed this question
Top Samsung Heating & Cooling Experts
Nyte_Ryder
gbob59
billconfused
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
