Question about GE Profile JTP18 Electric Single Oven
GE Profile Wall Oven Circuit Board
I've got a GE Profile Wall Oven that doesn't heat. The clock and timer work, but when we try to heat in either Broil or Bake mode, it says it's heating up to 100-degrees, but then reverts back to non-heating mode, and none of the elements ever get warm. Model number is jkp13got1bb. Not sure if the ''o'' is an oh or a zero. I took apart the control module and it's a RobertShaw controller, part number 191D1196-G012 Rev 0. Looks like the date code is 6-25-94. Based on what I've found so far on the internet, it looks like I need to replace the controller. I took it apart and there are two multiple circuit boards assembled into a module. Not sure if I need to replace the whole module, or just one board. So far, I haven't found a picture on any of the the spare parts sites that matches mine. Would appreciate any help.
Thanks!
The start buttom wont activate the settings what can i do to start.......
desperate
Posted on Mar 26, 2011
    Scholar:
  • 126 Answers
Http://www.searspartsdirect.com/partsdirect
I HAVE QUESTIONS. THIS THERE 240 VOLTS AC TO OVEN. YOU MAY HAVE A BREAKER PROBLEM. FLIP THE BREAKER BACK AND FORTH 3-5 TIMES FAST TO GET IT TO RESET. IF THE LAST THING YOU DID WAS A SELF CLEAN THEN YOU MAY HAVE A SAFETY THERMOSTAT PROBLEM. IF YOU CANNOT FIND THE WHOLE MODEL NUMBER ON THIS SITE CALL 1-800-GECARES THEY WILL HELP YOU WITH PARTS
Posted on Apr 25, 2010
CONVECTION OVEN CONTINUES TO GIVE fault code and doesn't heat
you either have a bad sensor or a bad clock assy. change the sensor first or check it with a meter it should read around 1080 ohms if this is good you have a bad computer board or clock assy. same part.if this a slide in stove with the burners on top there should be a tech sheet on the back,if this is a wall oven there should be a tech sheet below the top panel,slide it out and tilt it forwards enough to remove the top panel and of course kill the power to it first
Nov 03, 2017 | GE Ovens
Frigidaire wall oven CPEB30S8CC2 lower element does not work
We have a Frigidaire CPE30S8CC2 with the bottom bake element not working. We tried to replace it with no luck. The old element does not look burnt out at all. The timer, clock and broil all work just fine. The bake button works and you can set the temp. it just doesn't actually heat up at all. There are no knobs on the controls for any cook top. it is all on a circuit board for overn only. help?
Jul 16, 2012 | Frigidaire Ovens
Ge profile oven lock button won't go off
  • 1.Press the "Clear/Off" button on the control panel to reset the oven. This will clear the lock setting and unlock the door.
    2.Allow the oven to cool to room temperature to avoid turning the lock on again during this heating cycle.
    3.Reset the oven to the temperature you require to finish cooking by pressing the correct temperature control on the control pad.
    or
  • 1.If your GE Profile microwave won't turn on, unplug it, then plug it back in. A power outage may have occurred due to a power surge. Check your home's fuses and circuit breakers.
    2.Set the clock of your GE Profile microwave. Certain models will not operate until you set the clock. Select the "Clock" key and type in the correct time.
  • 3.Hold down your microwave's "Off" button. You may have accidentally hit the control-lock feature on your GE Profile microwave. Hold down the "Off" button for three seconds to turn the lock off.
  • 4.If the sensors of your GE Profile microwave are not working correctly, remove the food from the machine. If the sensors detect food-surface temperatures over 200 degrees Fahrenheit, it will not work properly until the area cools down.
  • 5.Contact GE Support if you are unable to resolve the issue on your own. Call the GE Support hotline or browse the help library on the GE website. You can also schedule a service visit on GE's website.
  • Nov 22, 2011 | GE Profile JK915 Electric Single Oven
    GE Wall Oven Model # JKP07G0D2BG - The clock has quit working. Any suggestions would be greatly appreciated.
    I assume the display for the clock/timer is now blank. If the oven is still working the only thing you are missing is the clock. If you can't do without it you will need a new clock.
    Most of the time the clock/timer stops working it affects the operation of the oven, the oven won't work. If this is the case you will need a new timer unless you can do without the clock/timer. If so a repairman should be able to bypass the clock with ease so that the oven will operate without the clock/timer.
    Feb 12, 2011 | GE 24" Built-in Single Electric Wall Oven...
    My GE wall Oven Model #jctp18ba1bb is not working.the board is blankm the only thing that works is the oven light.Is there any kind of thermal fuses etc. in this oven.thge control board was replaced 8...
    When you say board I assume you mean the electronic clock/timer. This timer directly affects the oven operation. Even if the internal oven fuse is blown or the thermal overload is tripped the electronic timer and oven light will always work. If the oven light works and the electronic timer/clock does not I'd say that the timer/clock is faulty.
    Feb 10, 2011 | GE Profile 30" Built-In Single Electric...
    My oven will not heat up ge jtp4850f1ss
    check elements. if good replace the main clock board
    Feb 06, 2010 | GE JTP48SFSS Electric Double Oven
    GE Profile Convection Problem
    with GE
    SHORTED OVEN SENSOR CIRCUIT
    if your comfortable taking the range out of the box, it is a pretty easy repair. The oven sensor is a small tube in the range that "sences" temp.
    although it could be the erc, its more than likely the sonsor itself.
    it is on the back wall and has to be unplugged from the back to be removed
    there are two screws that hold it on the back wall
    put the new one in and you should be ready to go
    goto appliancepartspros.com
    type in your modle number and look in the cavity section
    your looking for the oven sensor
    they usually run around 20-30 dollars
    Oct 17, 2009 | GE Profile 30" Built-In Single Electric...
    My GE Oven heating element and timer clock went
    Try unplugging the oven and let sit for 10 min. This will reset the curcuit board and reboot the electronics. You may have to pull out the stove o get to the cord.
    Apr 30, 2009 | GE Profile JTP18 Electric Single Oven
    GE Profile -Installed wall oven - won't heat
    brand new??? under a year old??? if so you have a warr call for service, but it sounds like an ignitor isssue, brand new , perhapsgot damaged in shipping 1-800-ge-cares
    Mar 29, 2008 | GE Profile JTP56 Electric Double Oven
    GE Profile JGB97 Self Cleaning Oven Controls won't work
    You have a problem that may be solved with my solution to the Dreaded F7 Problem. Even though you don't have a F7 error on the display the symptoms are all the same. You can find my fix at the following links.
    http://www.fixya.com/howto/h155060-dreaded_f7_error
    I have shared this with more than 1550 folks and most report success. This problem often develops after a self clean cycle.
    I hope it works for you too. Please let me know at the following:
    hutchipop@yahoo.com
    Good Luck,
    Charlie Popeck,P.E.
    Consulting Engineer
    Feb 06, 2008 | Ovens
    GE Profile JTP18 Electric Single Oven Logo
    910 people viewed this question
    Top GE Ovens Experts
    William Miller
    William Miller
    Dan Webster
    Dan Webster
    Are you a GE Oven Expert? Answer questions, earn points and help others
