Question about Campbell Hausfeld Air Tools & Compressors
I have a campbell hausfeld 2 gallon 135 max psi compressor suddenly stop working. How can I trouble shoot?
3 Suggested Answers
  • 1383 Answers
SOURCE: Campbell Hausfeld Air Compressor 1.8hp
You compressor is listed as being oil free. The only liquids that could possibly leak out of the motor (if still from factory condition) is black substance from overheated capacitor/s or grease from a failing bearing. Remove capacitor covers and check for failed cap. Motor bearings will become noisy before failure. Capacitors are available from motor repair shops and many times on ebay. Replace with same uf rating and same or higher voltage. Some caps are larger /smaller with same reading (notice size so cap cover will fit). Good luck
Posted on Jul 11, 2011
  • 643 Answers
SOURCE: I have a campbell hausfeld 2 gallon 135 max psi
No Fuse However this model is known for having the switch go bad. You can check it with a meter or Continunity tester with the unit unplugged
Hope this answers all your questions
Please remember to Rate/vote for any solution that helps you out.
Leave a comment if you need more help.
Thanks for using Fixya
Posted on Aug 12, 2011
I have a campbell hausfeld 2 gallon 135 max psi compressor suddenly stop working, when i turn the switch on, and making sure its plugged into a "hot" outlet, nothing happens, no buzzing, no sound...
Aug 12, 2011 | Campbell Hausfeld 2 Gallon Air Compressor
Campbell Hausfeld Air Compressor 1.8hp 135 max psi 20 gal wl611800aj the prob is there is a fluild leaking from the motor
Jul 11, 2011 | Campbell Hausfeld 1NNF5 Air Compressor,...
Max pressure 40 psi
i would say rings r gone on piston if u take out oil filler bung to see if it blowing air dat will tell the tale
Jul 28, 2010 | Campbell Hausfeld 26 Gallon Low Rider...
I have a 5hp 16gal. 135 max psi. The compressor builds up to about 50 psi. But no more. The compressor continuously runs never shutting off. I can hear no leaks. Also the on/off switch runs in the off...
take the power surply cover off and look down the side on the butten at the contacts, id say it isnot the pressur switch itself, and make sure all bolts are tight and check the reeds
Jun 10, 2010 | Campbell Hausfeld 02-Gallon Air...
I have a model FP209501 Air Compressor 2 Gallon,
2 gallons is small to begin with u need to buy an in line pressure adjuster/regulator their a few bucks and can be attached to the paint gun or line and will keep the pressure at ur adjustment the regulator on the tank sets the tank pressure at 50 so when u us it will let it drop down to about 45 than start up to build the pressure up to 50 than shuts off than repeats it self the inline keeps pressure steady even if tanks are at 200 psi
Jan 18, 2010 | Campbell Hausfeld 04 Gallon Twin Stack...
I need an owners manual.
plz follow this link and choose your model and get the manuals.
http://www.chpower.com/webapp/wcs/stores/servlet/XItemDocuments?storeId=10051&langId=-1&catalogId=10001&findModel=FP2080
i hope u will get the solution.
Oct 29, 2009 | Campbell Hausfeld No.FP2028 Gal Pancake...
I have a 26 gallon campbell compressor elec. Problem is runs fine for a min. then shuts off and on every couple of min does not get to max psi
REPLACE THE PRESSURE SWITCH BUDDY THESE CAN BECOME FAULTY WHICH IS THE CASE OF THIS PROBLEM BUY THEM ON EBAY FOR CHEAP THE PRESSURE SWITCH CONTROLLES YOUR ON AND OFFF AND STOPING PRESSURE SO THAT HAS GOT TO BEE THE PROBLENM OR TRY AND TAP IT A BIT TO MAKE IT WORK
Oct 21, 2009 | Campbell Hausfeld 26 - Gallon Air...
Unit turns on, builds prssure to about 45 psi, and won't go any higher. Continues to run. regulator is set for max line pressure.
Compressor has a bad valve. Needs to be replaced. The owners manual should have a break down of the compressor. Order the head kit.
Aug 05, 2009 | Campbell Hausfeld 02-Gallon Air...
No air pressure past 60PSI on a 125PSI Campbell Hausfield WL61110
Your comperssor is oilless type and suffers from short cylinder / piston life. When the compressor no longer reaches cycle pressure the cylinder / piston should be replaced. These parts are available at www.chpower.com I believe that the part number is wl210300aj. Not expensive, enjoy.
Dec 13, 2008 | Campbell Hausfeld 26 - Gallon Air...
Air Tools & Compressors Logo
63 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
