Question about Jwin BLUETOOTH HEADSET Wireless Headset
Jabra bt4010 what's the passkey and issues pairing to blackberry
How do i make my jabra work with my blackberry
Hi there, You need to pair the two devices. Make sure the cruiser is off, then push and hold the power button the Jabra for 8-10 seconds until it is in pairing mode. You need to continue holding the button after the device has powered on until you get there. Once there, on BlackBerry go to Bluetooth settings and select search for a device. Select the Jabra Cruiser and put in the passkey - 0000. You have now paired the two devices! Alex
Jun 03, 2011 | Jabra Cruiser InCar Speakerphone Black
Where do I find the numeric passkey required to pair jabra with my blackberry? Thanks
I believe the passkey is just 0000 (four zeros) for the Jabra. Hope this helps.
Jan 31, 2011 | GPS
Whats the pass key for jabra blue tooth bt4010
If you haven't changed the passkey for the headset then the passkey should still be 0000
Jan 05, 2011 | Jabra BT4010 Bluetooth Cell Phone Headset
Jabra bt2050 passkey 0000 dosent work with pairing my blackberry is there an alternate passkey i can use
Try putting in 1111. It still will not engage. But after you do this it will reset. Then put the 0000 in and you will be connected.
Sep 06, 2010 | Jabra BT2050 Bluetooth Headset
How do I get my jabra bt4010 to pair up with my Blackberry Curve 8520 smartphone. I had the insturctions when I first bought the Jabra bluetooth but somewhere down the line I lost them. Please help :)
Hello and Welcome to FixYa!
Here is the link for the user manual of the quoted model. Click Here
Please refer to the page 6 and 7 of the given manual for the pairing instructions. That is all you need.
Have a nice day,
Please Do Rate the solution, if this helps you,
Concerned.
Aug 18, 2010 | Jabra BT4010 Bluetooth Cell Phone Headset
Cant connect to my blackberry device is not connecting
This site takes you step by step through the Pairing process of your Blackberry and Jabra
Jul 25, 2010 | Jabra BT4010 Bluetooth Cell Phone Headset
How to connect jabra BT150 to blackberry 8520 curve
You need to pair your Blackberry with your headset.
  1. Turn on your Blackberry's bluetooth and search for bluetooth devices.
  2. While the Blackberry is searching and the headset is off, press and hold the call/end button on the headset until it's light glows steadily. Do not let go until the Blackberry finds it.
  3. Pair the devices and allow the headset to connect automatically.
  4. Default passkey is 0000.
  5. To connect, press and hold call/end button on headset like the one in step 2.
Oct 29, 2009 | Jabra BT150 Wireless Headset
Igave been using my Verizon Jabra VBT185Z
where can I find the setting on my Blackberry Curve to pair my Jabra VBT185z
Jun 20, 2009 | Jabra BT350 Bluetooth Headset Headset
Jwin BLUETOOTH HEADSET Wireless Headset Logo
444 people viewed this question
Top Jwin Radio Communications Experts
Michael Vincent Cruz
Are you a Jwin Radio Communication Expert? Answer questions, earn points and help others
