Question about Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw
Chain break broken - Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw
    President:
  • 2,220 Answers
Find and open the correct "Illustrated parts lists" here:
There is in illustration showing all parts or the "*Compl" is the entire clutch cover.
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000; please contact Husqvarna for single digit clarification http://www.husqvarna.com/us/homeowner/support/customer-support/)
15 = week produced – March
00198 = 198th unit Husky produced that week
If I missed your question please clarify and post back below.
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Posted on Apr 25, 2010
  • dontbother10
    dontbother10 Apr 25, 2010
    Your local Husky dealer can be very beneficial and ordering through him saves shipping and handling fees.
Timing chain if broken can it damage the engine
yes broken timing chain can and will damage an engine do not run vehicle until repair is made
broken timing chain Yahoo Video Search Results
Sep 16, 2016 | Cars & Trucks
Does the 1999 chevrolet cavalier have a timing belt or a timing chain and if it breaks do the valves hit the pistons.
The 99 cavalier 2.2 and 2.4 both use a timing chain and yes, if the chain breaks it can damage valves. If the engine still cranks over you can remove the upper coil module cover, remove a spark plug, roll the engine over and see if compression builds. If the engine does not crank over, the broken chain will prevent the engine from turning.
Feb 23, 2015 | 1999 Chevrolet Cavalier
How do you fix your broken down wheels in the middle of nowhere but you do have your emrgency kit and fixing kit ?
I learned by experience. When something breaks down, I learn to fix it for when it breaks down the next time. On a bike, the parts most likely to break down are a flat tire and a broken chain. Carrying a flat repair kit and a multi tool to fix a broken chain is feasible. You can break a wheel spoke. This you can't fix in the field but you can compensate by learning which spokes to loosen/tighten adjacent the broken one to get you home/shop. You can break a brake or derailleur cable. A spare cable is light and easy to carry but it is very time consuming to replace in the field. Depending on how far you are from home, it may be easier to ride home with a broken cable. Preventive maintenance is the best way to avoid broken cables and/or chains - replace them every 3 years or so, depending on usage and wear/tear. Other broken parts, you will have to assess in the field. You may have to walk home or call a friend to pick you up.
Sep 25, 2014 | Cycling
07 mcculloch 3516 has new bar and chain when running chain will tighten to the point it will bog motor down
Check your brake spring. It may be broken causing the brake to drag. Plus replace melted side cover.
Dec 06, 2013 | McCulloch Garden
How doe the band on my chain break attach to my chainsaw mine is broken and i do not know how to install it. or how to get the clutch off so i can replace it
It can be a little tricky!
If you are referring to chain break band
Tools you will need:
1/2 Socket (to remove bar nuts)
T25(torq) or you can use a Flathead screw driver but is a little harder.
Remove 2 bar nuts,Clutch cover,bar,chain, 2 screws on black bar handle right behind clutch cover(this is needed because there is a hidden screw there for the chain break) You will need a new chain brake (my guess is that it is part # 530071893 aprox $15) but you will want to verify that with your model number.
You should see the chain break assembly, 3 - T25 screws are visible after the clutch cover is removed(note sometimes you have to clean saw dust to make screw head visible) the other T25 screw is hidden under the black bar handle. Once you remove all 4 screws on the chain brake you will be able to pull it off.
Installing the new one is the tricky part because if it is set(or break is on) you will have a hard time putting it on.One of the easiest ways is to focus on it near the muffler you will see that a metal 3 pronged gear fits into the plastic part of the chain break handle.and if the band is too tight to fit over the clutch drum you will have to carefully reset it by applying pressure onto the area that has the 3 pronged gear and chain break handle make sure that the handle is pushed forward all the way while you apply pressure then slowly pull chain break handle back till you hear a "snap" this resets the chain brake spring and the band should now fit over the clutch drum.Now, proceed with putting back together 4 chain brake assembly screws,2 handle screws,and bar,chain,clutch cover,and 2 bar nuts.
Please note it is important that you apply quite a bit of pressure onto chain break area where metal (3 pronged) gear fits into handle while resetting or when you reset it the metal part can cut into and damage the plastic piece in the chain break handle.
You can see a breakdown here: http://www.searspartsdirect.com/partsdirect/part-model/Poulan-Parts/Chainsaw-Parts/Model-P4018WT/1324/1503220/P0506041/00002?blt=06&prst=0&shdMod=P4018WT
Hope this helps!
Feb 20, 2011 | Poulan 18" Wild Thing Chainsaw
What would break my timing cover ,but the car still run
Your may have timing belt get loose / wear down , but still work. Observe your time belt and check your maintenance record. Don't wait any longer. An abnormal timing belt will led your car to fatal damage.
Dec 04, 2010 | Pontiac Firebird Cars & Trucks
How do you know when the timing change go? Thank you.
Technically, timing chains are designed and built to last the entire life of the engine. So in theory, you should replace it only when it's broken. However, if the chain breaks while your engine is running, it could wreak considerable havoc, so waiting for a break isn't the best practical strategy. Before a timing chain breaks there are signs of wear, and it isn't hard to check for them. If your Jeep Cherokee is showing some of the signs, it is time to replace the timing chain.
Timing Chain Function
  • The timing chain connects the camshaft to the crankshaft via a gear system so that the top and bottom ends of the engine rotate together. If the timing chain has stretched and is skipping teeth, the timing will be thrown off badly, causing the Cherokee to run inefficiently, if at all. If the timing chain breaks altogether, the Jeep's engine will simply shut off, and many valve train components can be damaged in the process.
  • Loose Chain
  • Remove the distributor cap on the Cherokee's engine so that you can see the rotor. Then rotate the engine by hand with a wrench on the crank pulley very slowly. The rotor should begin to rotate with the engine almost immediately. If there is any delay, it is likely that the timing chain is stretched and needs to be replaced.
  • Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
  • Aug 17, 2010 | 1996 Jeep Grand Cherokee
    Brake not releasing 14inch ryobisaw
    First try cleaning it. Begin by removing the spark plug wire. Then remove the housing and inspect the chain break for broken chain brake parts such as the spring. If all appears intact clean away saw dust, sticks or other debris. Otherwise, the chain break may be simply wore out and need replacing.
    Mar 22, 2010 | Garden
    Suzuki DR650RS Camshaft is broken into two parts. what could be the reason for breaking axles
    In normal operation, there is no way the chain or valve springs could break a shaft. The only possibility, other than a defective camshaft when the bike was new, is that the cam chain was so loose the slack bound up around the sprocket causing enough pressure to break the shaft. Replace the chain, sprocket and camshaft and check the operation of the cam chain tensioner assembly. Please rate my answer.
    Feb 20, 2010 | 1990 Suzuki DR 650 RS
    Broken timing chain
    That is very early for a timing chain to break they should never BREAK! Something had to sieze up most likely a cam or NO OIL.one part turning one part not turning Its that simple.when this engine is takin apart I hope you repost that is very interesting..DRIVE SAFE TIM
    Feb 18, 2010 | 2005 Ford Focus
    Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw Logo
    81 people viewed this question
    Top Husqvarna Garden Experts
    Phil Walker
    Phil Walker
    Roland W VanLue
    Roland W VanLue
    Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
