Question about Ovens
Gas oven clicks but doesnt ignite
Great website!
So I have a Whirlpool Gas Accubake oven. The stove top works great, always has. But, my oven just started giving me some problems. Of course it happens on Easter when conmpany is coming.
It seems to click but doesnt ignite. I dont even really smell gas, although this could be a fail-safe devicde I guess. What do you think the problem is?
Thanks!
G
    New Friend:
    Problem Solver:
  • 11 Answers
Not getting gas so check gas outlet in the bottom of the oven for clogs , if not clogged the thermostat is bad
Posted on Jul 22, 2017
4 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 1665 Answers
SOURCE: Gas stove top works, but oven does not.
WHAT IS WRONG WITH YOUR RANGE / STOVE / OVEN?
http://www.repairclinic.com/SmartSearch/SmartSearch.aspx
Posted on Sep 14, 2008
Anonymous
SOURCE: Whirlpool gold accubake oven won't re-ignite
i have a whirlpool gas accubake range and only two burners will ignite. The other two burners make a clicking sound and release gas but never light. I have to use a match to light the other two burners and the flame is uneven on one. What should i do?
Posted on Nov 02, 2008
jumptrout51
steve
  • 3361 Answers
SOURCE: Whirlpool Accubake Super Capacity 465 gas range. Oven won't light
Some gas ranges may take 10 or so minutes to light.
Other than that you may have a defective glow bar ignitor.
If it glows and does not light the reistance in the ignitior has failed.
Posted on Feb 25, 2009
I hav whirlpool accubake.oven wont stay lit.it ignites then flame goes right back out
Whirlpool oven won't light - Appliance Repair Forum
forum.appliancepartspros.com/oven.../225907-whirlpool-oven-wont-lig...
May 19, 2011 - 10 posts - ‎2 authors
I have a Whirlpool Accubake oven (SF362LXSS0) that doesn't seem to be consistently turning on, and the problem's getting worse. ... If I try to turn it on to bake, I hear several clicks, but not that "gas oven turning on" sound and no heat comes out (but a slight smell of gas is ... Whirlpool Gas Oven won't stay lit
1 post
Oct 25, 2012
whirlpool oven won't stay on
1 post
Aug 13, 2012
Whirlpool Gas Oven Will Not Stay Lit
Jun 20, 2012
whirlpool accubake oven will not stay lit
1 post
Nov 9, 2009
More results from forum.appliancepartspros.com
Whirlpool Accubake Model # GW395LEGQ4 - Oven won't Start ...
Dec 12, 2015 | Stoves Ovens
Whirlpool oven/stove with accubake. The cook top works with no problems the clock and display work with no problems. The oven does not work at all no bake no broil. Got it to work a couple time by...
Take a look at the oven ignitor,you might have two.The one at the top is the broiler ignitor.And the one at the bottom is your oven ignitor under your lower oven plate.
Feb 21, 2013 | Ovens
I have a Whirlpool Accubake gas stove Model SF362LXSQ. Range top is working fine Oven will not ignite. No gas smell even. When I set the oven to start I can hear the click and see the spark sometimes, but...
Iquitous, we're sorry to learn of your Oven concerns. We would like to discuss this further with you. Please email us at [email protected] at your earliest convenience with your name, address, a phone number and best time to reach you along with your model and serial number.
Oct 26, 2017 | Whirlpool 30" Self-Cleaning Freestanding...
Stove top ignitors do not ignite but oven does.
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Mar 20, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Whirpool gas stove super capacity 465 the stove works but cant get the oven to work
whirlpool super capacity 465 accubake system gas stove with auto starter - oven worked fine the previous night the next day will not do any thing any help out there?
Jan 16, 2010 | Ovens
Feb 25, 2009 | Ovens
OVEN WON'T LIGHT AND HEAT, NO GAS SMELL
Hi!!! check your oven spark module its inside the oven it looks like this pisture..The module provides the spark to all ignitors..Good luck..
Jan 04, 2009 | GE JGRS14 Gas Single Oven
Whirlpool Accubake Duo Oven Not Heating up
the oven not heating up. it's start up some time and other time u just hear it try to click on but don't hear no fire turn on
Jun 15, 2008 | Ovens
Feb 18, 2008 | Ovens
Whirlpool accubake oven troubleshooting
electric oven heats to correcect temp then drops and does not get back too appropriate temp. For example, set at 400, gets there then drops to 275-300
Dec 18, 2007 | Ovens
Ovens Logo
349 people viewed this question
Top Ovens Experts
Marvin
Marvin
Are you an Oven Expert? Answer questions, earn points and help others
