Question about Maytag Neptune MAH5500B Front Load Washer
My machine is about 10 years old. it will run and then stop. we push start again and it will run a few minutes and then stop again.
    Scholar:
  • 126 Answers
THERE IS TROUBLESHOOTING GUIDE IN THAT CONSOLE TO TELL YOU HOW TO DO A SELF TEST. MOST LIKELY YOU WILL END UP WITH AN LR CODE. YOU MAY HAVE A BAD MOTOR CONTROL BOARD.
Posted on Apr 25, 2010
When pushing the start button the dryer will come on for about 10 minutes and then stop. Then sometimes it doesnt come on at all
If it starts right back up after stopping there is an electrical problem maybe at the motor start switch. If you have to wait for an hour before it will start again then the problem might be that the motor needs to be cleaned of a lint build up.
Oct 23, 2012 | Roper RES7646KQ Electric Dryer
Calypso washer stops/runs every 5 - 30 seconds in the middle of any washing cycle. No error codes. It just stops and than runs again all the time and cannot finish any washing cycle. It is 8 years...
I had the same problem. The washer control board has an intermittent failure. If you unplug power for about 30 minutes then plug it back in you will get a PF code (power failure). Ignore this code and push start again. It may run till it finishes the cycle or it may start cycling again right away. A new board costs about $180 at repairclinic.com
Aug 21, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore 868738000 Elect Dryer Starts for 10 minutes then stop.
That is gong to be a bad motor. $72.
Tools needed:
Putty knife
nut-drivers
screwdrivers
adjustable wrench
locking pliers
Notes:
Motor blower is reversed threads
Difficulty 1 to 10 = 3
Start by: removing filter and filter housing screws
then remove front panel screws LIFT UP on panel to remove it.
Remove belt remove tub. Get filter housing off
Clean up dryer. Lock down shaft and remove blower. Pop motor mount clips. Unplug motor. make hote of position f motor. Install new motor use nutdriver to snap down clips. I have the manual and some photos. In my sleep I can completely replace a motor in less than an hour and that includes oiling the rollers and idler and doing a through hoovering out the machine. This machine is worth replacing the motor and really a breeze to repair. Nothing has worked better for over 50 years. Go for it.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 22, 2010 | Kenmore 62602 Electric Dryer
Turns off after a few minutes
sounds like your motor is overheating or going bad. sometimes lint built up around the motor can cause it to overheat. or the motor is dying.
Aug 31, 2009 | Kenmore 73952 Gas Dryer
6 yr old mower starts, won't run
sounds like a plugged high speed jet in carb - you can attempt to prime again , push at least 7-8 times - once it fires continue to push primer to keep running - it may clear out the carb if this doesnt work the carb will need to be removed and cleaned
Sep 27, 2008 | Garden
I have GE Madellion 870 Washing machine I guess I have motor problem motor stopr after smoke Now Motor spins for few second then stops after 15~ 20 minutes, it will run again for few seconds if my...
Hello ashankhan,
huuum,happy to assist you!
You said,
motor stops after smoke
if my motor burned then why it still runs for few seconds.
The motor is shot and it still works until it heats up, and then it binds up after it over heats!
How old is the appliance?
If the appliance is 10 years old or more you may not be advisable to put good money into bad! New appliances are so much more efficient today that they can save you a lot of money in energy.
Therefore they pay for them selves in only a few years.
You can buy New and save today.
Find the small privately owned and operated appliance store and you will get better service and good treatment! They also will be the best informed!
Bless You, let me know how it goes.
huuum
Please give me a good rating for my fine advice before you sign off.
Thank You
Sep 18, 2008 | Dishwashers
Cycle stopped
Peace Friend,
ngafm At your service!
With an error code the only way to find and to repair this is,
First unplug the washer and wait a few minutes then restart it like rebooting your computer when its acting strange!
If it corrects the problem GREAT!!! WE WIN!
If not only a trained laundry tech can make the electronic diagnoses.
Like we used to be able to fix my own cars, but not today they need diagnostic equipment!
How old is the washer?
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
You will be fine
Bless You ngafm
PLEASE GIVE ME A GOOD RATING HERE AT FIXYA.COM BEFORE YOU SIGN OFF!!!!!!!!!!!!!!!!!
Sep 03, 2008 | Kenmore Elite 45986 Front Load Washer
Braun Aromaster 10 coffee maker
time to descale the machine not with vinegar but with descaler product 1part descaler 1 part descaler fill the water tank put machine on for few minute stop it for few minute start untill empty rinse very good a few water container and that it if our coffee does not stay warm after that at the bottom of machineinside check the element contactsometime the contact overheat they get some corosion on less power go trus them = less heat i say not to use vinegar vinegar remove calcium in little piese you might block the machine descaler melt calcium thanks for using fixya pierre
Feb 04, 2008 | Coffee Makers & Espresso Machines
Maytag Neptune MAH5500B Front Load Washer Logo
211 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
