Bought new speakers Ozaki WU460. Sound only from one speaker
Bought new speakers Ozaki WU460. Plug into desktop computer and only get sound from one speaker. I thought maybe one speaker was bad so I switched wires and each speaker Worked fine individually. So I assumed the input on the amp was bad for one side. Took speakers back to the store and they tested them on a testing system in the store. Everything worked fine. Felt like an idiot for and the cleark told me to check settings on the computer. Went back home checked all settings everything is fine. Old speakers work fine. OK maybe it's the computer. I have tried 5 different computer and they all have the same problem. Old speaker SAAG work fine with the amp work fine on all computers. Why do these new speakers work in the store on the testing system but don't work on any computers.
Thank John
No sound
open device manager ... check your drivers. update if you see a Yellow ? or anything out of the ordinary
Sep 10, 2009 | Ozaki DT-500 3-Piece Speaker System...
Why my audio cards doesnt work. i installed sound driver and nothing
make sure that it is the right driver for your sound card and operating system
Aug 11, 2009 | Ozaki DT-500 3-Piece Speaker System...
Can"t get my hp speaker going
What you need to do is to install your sound card drivers for your laptop and then you'll get the speakers to work.
May 05, 2009 | Ozaki DT-500 3-Piece Speaker System...
No sound from the OZAKI DT 555 (dotodot 555)
ADJUST THE SOUND WITH ICON DISPLAYED O THE DOWN TOOLBAR
Mar 26, 2009 | Audio Players & Recorders
Cant get sound to come from computer to speaker plz help
check to see if speakers are pluged into the green plug on the computer and if the speakers are turned on volumn high and power is pluged in.
Mar 06, 2009 | Ozaki DT-500 3-Piece Speaker System...
I dont get any sound from my pc guess my sound card is having problem how 2 fix it?
Before replacing the sound card you check the software settings to make sure the mute isn't set and also download and reinstall the driver,
Feb 27, 2009 | Ozaki DT-500 3-Piece Speaker System...
I just hooked up new speakers and I now cant hear them.
Please keep the old speakr and restart the system. Also check the Sound settings through control panel -> Sound
Feb 01, 2009 | Ozaki DT-500 3-Piece Speaker System...
How can i install my speaker to my pc?
Hello rafaelmajiki,
What kind of speakers are you trying to hook up to your PC? You should be able to plug the speakers into the headphones jack and the line out jack.
- Vincent
Nov 25, 2008 | Ozaki DT-500 3-Piece Speaker System...
I pluged in my speakers but the sounds are very low and wierd
you cant get echo on a specker there not made for that just normal sound
Nov 16, 2008 | Ozaki DT-500 3-Piece Speaker System...
Sound card
Remove cover and find a slot which is made for the card you have to install. Plug in the slot plush so you can place a screw to hold card, (be sure the power cord isn't plugged in while working inside)Once installed in computer, plug in and have drivers disc ready in rom.When new hardware is found, send to disc, if doesn't find new hardware run the setup on drivers disc. Good luck Jimmyriggs
Jun 09, 2008 | Ozaki DT-500 3-Piece Speaker System...
126 people viewed this question
 Grubhead
Grubhead
