Question about Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer
Gas line on line trimmer is broken, have replacement but there are two lines, cannot figure out where they hook up
  • 149 Answers
SOURCE: replacing the 3 fuel lines
check my postings 3 days ago it give a good run down
Posted on Jan 15, 2009
  • 297 Answers
SOURCE: I REPLACE THE FUEL LINES,NOW IT ACTS LIKE IT WANT TO START,BUT D'
http://outdoordistributors.com/pdf/Ryobi/RYOBI-700r-serials-304051232-thru-.pdf
Have a look at this drawing.
Posted on Apr 18, 2009
  • 8 Answers
SOURCE: ryobi 700r gas trimmer, replace old fuel lines
Line from tank with the filter on it is the supply line and goes to the carb inlet fitting. This is typically on the "bottom" of the carb (with the tank being up) and will usually have a fitting with barbs or a bulge on it to ensure a tight fit. The other fitting on the carb is the return line and is usually a straight tube fitting with no barbs. That line goes the suction side of the primer bulb. The third line goes from the outlet of the primer bulb to the return barb fitting in the bottom of the tank. Fittings have to be removed from tank to properly install the new hoses on them. Remove retainer ring on outide of tank and push fittings into tank, then shake out of the fill opening. More details on replacing hoses are listed in another post about Repairing Ryobi trimmer.
To leemineres, if hoses are on right and unit still stalls after starting initially you probably need to disassemble carb and clean out using spray carb cleaner. May be sticky needle valve, or partially plugged port or jet.Could also be hole in diaphragm. Gasket and diaphragm kit would be good to add when you take apart, even if diaphragm does not have a hole.
Posted on May 20, 2009
  • 969 Answers
1-800-345-8745 US
1-800-265-6778 Canada
Posted on Aug 23, 2009
  • 56 Answers
SOURCE: gas line replacement for ryobi trimmer
Noticed on my last trip to Home Depot, that they had replacement fuel line kits for Ryobi trimmers with instructions on how to do it.....if you don't have a Home Depot handy, take your machine to any mower shop or mower parts house and they have bulk tubing you can buy...match the size of the line and get about 14in of line...next remove the fuel cap and dump any fuel in the tank...look inside and find the tube with the small filter attached to the end....remove the fuel line from the fitting on the carburetor and with a twisting motion push the fuel line into the tank from the outside...when you get enough slack in the line grasp the filter end of the line with long needle nosed pliers or a hemostat through the tank fill hole and gently pull on the line...it should slide right out....now take your new line and with a razor blade or sharp knife cut about a 1inch angled taper on the end of the new line...put a little oil on the new line and feed the tapered end from the outside of the tank through the hole in the tank, pushing and turning it a little as you insert it. as with the removal procedure when you get enough line inside the tank grasp with your pliers and pull the line through....cut off the tapered end and re install the fuel filter ( now would be a good time to replace it with a new one, they're cheap and prevent problems down the road)... pull the fuel line back toward the carburetor until the filter lies on the bottom of the tank... about 7in inside the tank and 5 in on the outside is about right take the carburetor end of the line and cut it to fit making sure you don't have any sharp bends in the line and re- attach it to the carb fitting.... that should do it...you can replace the fuel return line the same way !!! hope this helps.... ;-D
Posted on Jul 17, 2010
How do the fuel lines in a weedeater trimmer pe550 hook up inside the gas tank
I have an older model that has a weighted filter in the tank. The filter flops around and can 'fall' into the fuel no matter which way you tilt the trimmer/tank. You should have one in your tank. Feed in the new line and make the end come out the gas cap. Push the filter/weight into the end of the fuel line. Pull the extra fuel line out of the tank to match the original position. You should have cut the new line to approximately the proper or same length as the old fuel line with an angle cut so you could push it into the tank.
Jul 23, 2014 | Poulan Craftsman/poulan/weedeater Fuel...
How do you change a craftsman 32cc weedwacker gas filter in the gas tank?
Hi davemac918...
I used a long pair of tweesers to grab the filter, but you can also grab it with a piece of wire with a hook bent on the end of it large enough to fit the tubing the filter is inserted into.
Hook the filter tubing, and pull the filter to the top of the tank and manuver it out of the tank.
Please take time to rate me
Sep 11, 2011 | Craftsman Convertible 25cc. Gas Line...
I need to feed the line back into the holes on the craftsman 17' 25cc weed trimmer. I dont know how to remove the line holder to replace
Although it is called dual line, only one line is used - except that you use both ends of the line. Cut off as much line as you think the spool will hold. Put the two ends together to find the center of the line. Some trimmers have holes to thread the lines through and others have a place to hook the bend at the middle of the line. if yours has threading holes, thread one end of the line through each hole and then pull on both ends until the bend of the center of the line won't allow any more slack. If your trimmer has the place to hook the bend, hook there and start winding the lines in the direction shown on the spool. Be sure one line is on one half of the spool and the other line on the other half. Wind both lines at the same time as smoothly as you can. When the spool is full, insert the loose ends through the trimmer head, insert the spool and pull on the strings. Hope this helps Tim
Here is a site that can help if I did not understand your question correctly:
http://www.ehow.com/how_7872475_replace-craftsman-25cc-line-trimmer.html
Apr 10, 2011 | Craftsman 25cc Gas Line Trimmer
Weedeater, 18cc, replaced fuel line & purge button, the purge button will draw fuel into the fuel line but the purge button will remain colapsed.
You may have accidently hooked the lines to the purge button wrong. The purge button (primer button) should have a short stem and a long stem. The short stem is the suction side of the primer button and should be hooked up to the return on the carburetor. You actually s*uck gas through the carb and not from the tank. The carb should have two hook ups. If you hook the fuel line up to one of the lines on the carb and the button is hard to push and doesn't return to normal, hook the line up to the other one. When you push the primer button gas should be pulled through the carb. The other line on the carb goes back to the fuel tank.80a09a6.jpg
Apr 18, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
Try to replace fuel line craftman weedwacker 32cc/1.9c.u -trimmer-hose all rotten cant figure how to replace
You will need to get some TYGON fuel line. Match it up to the size of each fuel line, some of these trimmer use two different size lines, and remember which size went on which connection. You will want about a foot of each. Cut one end of each line at a 60 degree angle. With a pair of needle nose pliers, feed the angled end of the fuel line into the hole going into the tank and feed it into the tank untill you can see at the tank fill. You cut the angled end off and put your filter on the line. Pull it back until the filter lays at the bottom of the tank. Hook this line up to the supply side of carburetor. Take the other line and put it in the tank about 1" or 2"
then cut it off to fit on the carburetor. HTH
Good Day.
Nov 10, 2009 | Craftsman 25cc Gas Line Trimmer
I need to replace to fuel lines on a Craftman 32cc trimmer. The old ones cracked apart. 2 of the lines look like 1/8" OD one line looks like 3/32" OD. Larger line looks like it hooks to filter, Smaller...
Depending on the brand of line you use, Tygon line is self sealing but seems to shrink faster then factory supplied because of the ethanol in the gas. The stone gas filter is designed to fall to the lowest part of the tank, not stop the line from falling out.
Nov 01, 2009 | Craftsman 25cc Gas Line Trimmer
Have an old T27 the gas cannot be sent from the tank to the bulb and into the carburetor.
Just a thought, either your fuel filter is clogged, your gas line is collapsed, or there is an air leak in the system between tank and bulb. Obviously you've inspected the gas lines and the bulb for wear (cracks) and you haven't recently replaced gas lines where it might have been possible to switch in / out lines....the only reason I ask is that is what I did when swapping parts from one model trimmer to another..my bad, but I finally figured it out.....Please let me know.
Oct 24, 2009 | Husqvarna 28cc Gas Line Trimmer
How do you replace the gas lines?
ok the first thing you do is get the right size fuel line get the fuel line extra long run the line through the hole in the tank from top long needle nose pliers to pull through the tank on the inside install fuel filter on the line that has it then pull it back up measure to the carb then cut at right lenth if i can further help e-mail me @ wadembly@aol.com thanks, wade
Jun 08, 2009 | Garden
Broken Gas Line
You can obtain a length of gas line locally. Just take the broken piece to any store that services trimmers and chain saws. They will be able to match it.
Dec 06, 2008 | Husqvarna Forest & Garden 125l 18" Gas...
Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer Logo
366 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
