Question about Cameras
Shutter closes half-way - Cameras
  • 21 Answers
There are many factors that may cause this, so you have to follow each by each under certain conditions:
1. If you have drop the camera recently.
- Disassemble the camera, remove the outter frame (but keep the camera inside body intact). Turn on the camera and look at the shutter neck. Check and see if there is any abnormal shape, is most likely that the thin aluminum casing at the front of the lens got bent and you may be able to bend it back with a thin screw driver, that you can manage to insert between the plastic casing of the shutter and the aluminum cover.
2. If you do not drop the camera however have used the camera for a while.
- Disassemble all parts and clean the camera. There may be dust, sands, or other objects that is in the way of the shutter motor that caused the gears disengage.
Posted on Apr 25, 2010
EOS 1v viewfinder is black and shutter glass is half way closed
There could be something stuck (grains of sand, grit, etc...) in the lens mechanism. Try googling "How to fix stuck lens digital camera". If that doesn't work, try altering the search.
Hope I helped!
Dec 08, 2013 | Cameras
Timer set func select desired
In the manual you can read how to set Tv, fro 15 seconds to 1/3200 second and lots of settings in between. every time half the time of the former one. It is on Pag. 63 , 64 and 65.
The camera does not have Bulb. (press the shutter once to open the shutter and after some time press a second time to close the shutter.
Dec 03, 2013 | Canon PowerShot S51S Digital Camera
Cannon rebel DS6041 shutter problem
You need to determine what is preventing the shutter from opening/closing. Set to "B" mode and with the lens OFF, press shutter button but DO NOT RELEASE just yet. Not any peculiar motions (grabbing, skipping, folding etc). The curtain may well be out of alignment, or there may be a lose part which is grabbing hold of another component.
If you do find the culprit, and it can be fixed on the spot - do it. Technicians can charge >$65 just to open the thing. Then you have to wait at least a week to get it BACK!
Nov 09, 2013 | Canon Eos Digital Rebel Ds6041 6.3 Mp...
Can't take any photo with my Canon S3IS any more. The view finder and the screen is black when I try to take some photo but I am able to see all photo that is already on my memory card in the view finder...
Look into the lense while setting the shutter speed at a half second or so (slow enough for you to see the shutter open and close) and click the shutter release... you should see the shutter open and close. If you don't see this, then you may have a 'sticky shutter' resulting from lubricant seeping into the shutter/aperature mechanism and preventing the shutter from functioning as it should.(Common problem reported with the S2 and S3 cameras... and probably the S1 as well)
I have gotten my S3IS to take pictures by turning on the power, then opening the battery compartment door and reclosing it repeatedly until the shutter opens (from the power surge) and an image appears on the LCD.
After confirming the sticky shutter was indeed the problem, I pursued a more permanent fix.
Jan 30, 2011 | Canon PowerShot S3 IS Digital Camera
When you take a picture there is a delay before it finishes, so taking kids pics are out of the question..how can this be fixed or is it made that way
If you are referring to the delay when you press the shutter button and when the camera actually takes the picture, this is called "shutter lag" and is common to all point and shoot cameras. You need to learn the "half press". This means that you press the shutter button half-way and allow the camera to lock in the focus (it will beep). Then, while holding the button in, you can recompose the shot and when the moment is right, press the rest of the way for an "instant" (or close to it) shot.
Dec 22, 2010 | Sony Cyber-Shot DSC-T5 Digital Camera
Error .press shutter release button again
did a shoot on friday and came home and downloaded all the pics and then I went to do a shoot today and my camera wouldnt work. When you go to take a shot the shutter closes and then and error comes up and says press shutter button again to release. This opens the shutter back up. The picture it takes is only the bottom half of the object you are shooting....any ideas of what I can do to fix this? I have only had my camera 30 days so I have no clue what it could be.
Jul 29, 2010 | Cameras
The flash pictures are only half exposed, like drag on shutter
Sounds like the shutter needs repair. Either the opening curtain is sticking or the closing curtain is not holding long enough. Another problem might be the camera's sync speed might be lower than 1/125 of a second. Many cameras use 1/60th or 1/90th of a second as their flash sync speed.
Feb 02, 2009 | Ricoh KR-5 SUPER II 35mm SLR Camera
Half picture shows up and top portion is black
The camera firmware should be reloaded, if this fails then the camera is likely beyond end user servicing and should be repaired by a professional.
The reason your only seeing bottom half is as the reflex mirror is opening upwards to expose the sensor ( traditional cameras opened the mirror then a shutter to expose film ) your cameras sensor is only registering or transferring the bottom half of the image because it is the image is registered bottom first to the top until the shutter closes and the mirror returns to resting position.
Your problem could be the result of firmware or a more serious issue.
Aug 10, 2008 | Nikon D40x Digital Camera
Shutter problems
I am having a similar problem with my eos 100QD.
shutter opens, then stays open until I depress the shutter switch again.
Sometimes about half my photos are lost on a roll, but the other photos are fine (as would be expected from how the film is wound). This problem looks like it's caused by the shutter mechanism failing, a common problem with older camera and one that is often more expensive to repair than it is to replace the body.
May 25, 2008 | Canon EOS Rebel GII with 35-80 lens 35mm...
Lower half of photos dadrk when printed
Set camera to B , open back door and release the shutter and keep it open while you inspect focal plain area. Is the shutter fully opened ? If you release again is the shutter opening completely and closing completely ? While the shutter is fully opened on B look through the shutter/ mirror box area is anything obstracting your view ? Seems like one of the shutter curtains is not opening properly and shutter will need servicing. Please note that it may not be economical to repair : $ 150-200 if the shutter block does not have to be replaced completely.
Apr 22, 2007 | Minolta Maxxum HTsi Plus 35mm SLR Camera
Cameras Logo
55 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
