Question about Boston Acoustics BA65 Computer Speakers
I don't have the AC DC 12V in (power cord). What kind is it?
Model # BA265 powered two-piece speaker system. I tried to swap in other AC DC 12V cords from my other household electronics, they all look like they would fit but non of them do. I think maybe that's because A: the power supply has a unique 12V adapter, or B: the power port on the back of my speakers has become damaged or displaced from its original postion; but of course I'm not sure can someone please help?
-Anthony
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 141 Answers
Not only do you need the correct voltage and amperage (MAH) but you need the corectly sized plug to fit the socket AND it has to be in the correct polarity. Usually the polarity is marked by a broken circle with a dot in the middle. Leading to this dot will be an arrow or just a line and at the other end of the line will be either A positive (+) or negative(-) It's important you get this polarity correct when plugging a new power supply in.
Your local electrical store should be able to sell you either a fixed 12volt supply or even a variable supply allowing 3, 6, 9 or 13 volts output. Make sure it has the amperage capacity you need. It won't matter if you need 500Mah and the supply is 750Mah as long as it isn't less than what you need.
The power supply should come with an assortment of plugs which are insrted into the socket on the end of the power supplies lead. Follow the instructions on the packaging and ensure you have the center pin set as either + or -. If you are in doubt. Take your speaker which has the socket fitted and show the salesman. He should be able to pick the correct plug and make sure it's the right way around.
If you plug it in and nothing lights up, quickly remove the plug and turn it 180 degrees in the power lead socket. Obviously it's been put in the wrong way round. If you were quick enough no damage should have occured and away you go.
Just one tip. Wrap a small piece of insulation tape around the plug to stop it from being pulled out of the power lead's socket. They do tend to work loose after a while. Oh and make sure it's switched to 12 volts if you get the variable one.
Posted on Apr 25, 2010
I own Boston speakers BA265 I have the correct AC/DC 12 volts MAH 300 the adapter Adapter that came with it. I went to Radio got a replacement adapter it's correct the Tip is No - At All...
Jason Cruz
Posted on May 09, 2012
Adapter/power supply cord missing emachine model SP 30A speakers
AC/DC Adapter
Model MA-9200
Input 120 VAC 60 Hz
Output 9 VAC 200 Ma
Class 2 Transformer
Oct 17, 2009 | Audio Players & Recorders
Need AC 15V 1.1A power cord for HK195 speakers
Hey, I was in the same situation. I tried a 9V DC (yes DC) converter I had and it works perfect. You can use a DC on a AC input - never the other way around. Due to insufficient power I get distortion at very high volumes... but I never play that high so I'm good..
Oct 07, 2009 | Harman Kardon HK206 Computer Speakers
Just wondering what the power supply output JBL Media 3 Speakers
I have a pair of Media 3 JBL computer speakers. I am using a generic 12V DC adapter rated at 1000mA with a positive tip polarity, and it works fine.
Aug 15, 2009 | JBL Audio Players & Recorders
Do I need a battery? What is my power source?
Well first off if there is a power cord that goes in the front then it should be powered by that. Second of all you should have a power switch on the front of the speakers to turn it on and volume control.
Jun 18, 2009 | Boston Acoustics MicroMedia Computer...
Need a replacement power cord for harmon kardon sound sticks II
its not that expensive for a power cord. they are running on 12v so you go and buy a 12v power supply with a jack that fits the speakers or you can just find a power supply at home if you have one that is 12v
Jan 05, 2009 | Audio Players & Recorders
Output voltage of 120volt AC brick & approx dimensions
Any PC speakers that have a AC plug pak attached can probably use 12V simply cut off the AC plug packs lead that goes to the speakers, and connect up 12V ya should be good to go.. some connect with a Phono Plug, and usually the Outer is Minus Voltage and the Centre is Plus Voltage .. they are also generally Diode protected so a reversal shouldn't cause too many probs... GL
Jul 29, 2008 | AOpen MA-691 Computer Speakers
Video upload....
well, the connector that comes from the 2nd speaker goes into the speaker port in the back of the first speaker.
The wierd cord possibly fits into the 12v dc slot in the back.. and the other end would go to a power adapter..
Seems you are missing a power adapter,, like you said earlyer.
Basically you would need a standard power adapter which fits into the speaker.
You could get some universal power adapter for it like
http://cgi.ebay.com/UNIVERSAL-DIGITAL-AC-ADAPTER-ADJUSTABLE-VOLTAGE-NEW_W0QQitemZ150275118131QQcmdZViewItem?_trksid=p3286.m20.l1116
Or
something to this direction
http://cgi.ebay.com/UNIVERSAL-AC-TO-DC-POWER-SUPPLY-ADAPTOR-ADAPTER-CHARGER_W0QQitemZ230275174536QQcmdZViewItem?hash=item230275174536&_trksid=p3286.m14.l1318
If you want to make sure you get the right kind of power apdater
Try contacting jbl directly
http://www.jbl.com/home/product_support/JBL_contactus.aspx?ProdId=PLATINUM%20SERIES&ProdName=COMPAQ:%20Platinum%20Series
I was looking around ebay, found this
http://cgi.ebay.com/NEW-JBL-Platinum-Series-PC-Speakers_W0QQitemZ260266345340QQcmdZViewItem?hash=item260266345340&_trksid=p3286.m14.l1318
Theres the power adapter in the middle, I think the odd cord goes to the back of the first speaker and the other end would go to a power adapter.. try contacting jbl they should be able to get you what you need.
Seems you have everything else you need except for the power adapter.
Jul 26, 2008 | HP JBL Platinum Computer Speakers
12v ac/dc
Take u'r sound system to electronics shop..... get it!!!
Dec 27, 2007 | Boston Acoustics MicroMedia Computer...
Boston Acoustics BA65 Computer Speakers Logo
797 people viewed this question
Top Boston Acoustics Audio Players & Recorders Experts
 Grubhead
Grubhead
Vito Vacirca Jr.
Are you a Boston Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
