Question about Pantech Matrix Cell Phone
My phone isnt working cuz it says its missin a card but its there
My phone won't let me do anything on it because it is telling me to "insert SIM card", I looked and the card is in my phone. How do I make my phone work again?
    Problem Solver:
  • 7 Answers
Is your simcard in the right way, is your sim card old?, make sure the simcard you are using for the phone is the corect one. make sure that your phone isnt locked to another service.
Posted on Apr 25, 2010
I cannot login
If you cant login to your SIM card and it has a password:
If your SIM card is blocked from to many tymes of typing the wrong password you will have to go to your phone operator and tell them that you blocked your SIM card
If your SIM card isnt blocked : Step 1 . Turn off your phone Step 2 . Get out your SIM card out the phone Step 3 . Blow air in to the place that your SIM card should be (you can use your mouth or can of compressed air) Step 4 . Blow your SIM card with air (you can use your mouth or can of compressed air) Step 5 . Insert the SIM card back in to place
!!! If this fails you will have to visit a cetificed phone service !!!
If you made your SIM card in to Mini format theres a chance you damaged your SIM card
Jul 28, 2011 | Cell Phones
It says there isnt a sim card inserted when there is i have resonally come back from holland and when i returned it was in offline mode ?
I think the problem is with your sim card. Insert the sim card in another mobile and check whether it is working or not.
May 21, 2010 | Nokia 5800 XpressMusic Smartphone
Emergency calls only and not showing service provider
sounds like either your sim card isnt inserted correctly, or the slots arent turned on. sim card slot 2 is the slot closest to the phone, gold chip faces up, sim card slot one is slightly elevetaed off the phone, gold chip faces down. make sure it is inserted all the way down. perss fimly. then go to SETTINGS>DUAL SIM SETTINGS>DUAL SIM OPEN>CLICK OK. This opens up both sim card slots. after you find out which slot you are going to use, you can repeat these steps and only have opened the one you are using.
Jun 02, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
Phone says no sim card inserted
Your phone will operate without the sim card. But you won`t be able to make calls etc.
Make sure it`s inserted correctly and use a dry piece of cloth to clean the sim card.
Hope this helps
Jan 22, 2009 | Nokia 6500 Slide Cellular Phone
I can't unlock my LG 3G phone, please help me.
if the SIM is secured properyl (not backward or anything) then there must be a hardware problem and you will need to get LG to repair it
Jan 15, 2009 | LG KM500 Cellular Phone - Unlocked
Error messgae "Insert sim"
remove the mobile parts safely and clean each and every part
see if anything like broken like tat to the pins where u put the sim tat could be the problem
Dec 19, 2008 | Sony Ericsson W200i Cellular Phone
Insert simcard nokia 7200
hi the only one thing you can try without replacing the sim card reader is do you know when you put the simcard in if you push on the simcard with your finger so your pushing it down onto the contacts is fold up some paper so that it put pressure onto the simcard when you put the battery on as alot of times the contacts dont touch the sim card properly so putting some folded paper on top of sim card pushes it down onto the contacts properly.
This solves the problem in most cases but it can be difficult to get right as if the paper isnt thick enough then it might not push it down hard enough to make contact.
If after doing this it still dont work then this either means the sim cards no good but you could try it in another phone or it could be that the sim card reader is not connecting with the board properly and would need replacing.
Make sure you check the contacts are clean on the sim card and the sim card reader to make sure this isnt problem.
If you have not tried the sim card in a different phone then it could be the sim card is no good.
Did this sim work in the phone before just in case the phone dont accept that network as you can get this message if this is the case.
Let me know how you get on and if you need further assistance ok
Apr 08, 2008 | Nokia N95 Cellular Phone
Phone problems
I have had a new orange sim card for my SonyE W850i, however the new sim card isnt connecting to the phone (i think). I have noticed that the new sim card has a smaller 'chip?' on it. Could this be the problem. I have tested both the phone and the sim card on phones/ sims and they seem to work fine, just not when they are together. It seems as though they are incompatible (the phone is an orange make so there should be no problems there). The phone sometimes reads 'insert sim'. athough other times it works ok but then for no reason it breaks down to 'insert sim' again.
Mar 09, 2008 | Sony Ericsson W850i Cellular Phone
Insert sim message
yes there is one way to fix this it would however involve taking it to a repair centre and will probably cost you about £40.00 as it sounds like the charger port has become disconnected and requires a new port and the sim holder has become loosened so therefore needs replacing.
Dec 08, 2007 | Motorola Mobility RAZR V3
Pantech Matrix  Cell Phone Logo
234 people viewed this question
Top Pantech Cell Phones Experts
Computer Repairing
Computer Repairing
Jax Planet
Jax Planet
Abdul Mannan
Abdul Mannan
Are you a Pantech Cell Phone Expert? Answer questions, earn points and help others
