Question about Dryers
Fin inside dryer drum loose and rattles can it be
One fin inside dryer drum is loose,rattles and begining to catch and tear or cause holes in laundry. can I tighten or reattach it somehow?
  • 1 more comment
  • bookertpizzl Apr 25, 2010
    its a whirlpool gas dryer LG8648 thanks!
    how do I get to outside of drum to tighten screws?
  • BRIAN
    BRIAN May 11, 2010
    WHAT KIND OF DRYER AND I CAN HELP. MODEL NUMBER WOULD BE HELPFUL.
    Scholar:
  • 126 Answers
Remove the lin filter. remove the 2 screws at the lint filter area. next put a smal screw driver or butter knife in the seam between top panel and front panel. push down or pull up on the tool to release the left and the right sides.
Posted on Apr 25, 2010
    Sergeant:
  • 239 Answers
Get to out side of drum and tighten screws
  • dweatherby Apr 26, 2010
    if norrmal dryer..pull lint filter,take out 2 screws..use flat blade screw driver between front and top clips about 3" from each side,pop top up.. i cant find that model number need full # from tag if newer dryer they are a little different
On spin cycle sounds like change or rocks spinning around in drum.
Could be a bad bearing or something loose on the drum that doesn't rattle until you get up to spin speed. Look for something like pins, nails or screws stuck in the holes of the drum, or possibly under the protuberances (fins) inside the drum. Does the sound occur all through the spin cycle or only at top speed?
Jul 08, 2015 | Washing Machines
What could be the cause of my Samsung electric dryer DV5451A tearing towels when drying?
Most likely one of the vanes in the drum has got a gap that is catching it, or perhaps a fastener has worked it's way loose and is hooking the towels.
Jan 31, 2015 | Samsung Dryers
Making thumping noise and burning clothes
You list no brand or model so an answer must be somewhat vague. A loose drum causes the noise described while it also allows air to leak from outside the normal air flow path causing erratic high/low temperatures contributing to burning. Sometimes clothes can also get caught in the gaps caused by the tub moving excessively which causes tears, pinches and rips in clothing. Most dryers will have rollers and/or glides to carry the weight at the front of the drum. Check to determine if these are worn, loose or broken. A few models carry all the weight at the rear of the drum (Frigidaire and some GE) so check the rear bearing for excess wear and replace as needed. It's always a good idea to also clean debris and lint from inside the cabinet while the dryer is disassembled for repairs.
Aug 25, 2014 | Dryers
The dryer twists and ties sheets into ropes making them impossible to dry. Why
? is the fins on drum of dryer still there only other way is sheets are catching on inside or closed in door check in side dryer drum for what its catching on
Dec 03, 2013 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
My L.G. gas dryer has gotten noticeably noisier in the past 2-3 months sounds like there is something loose inside or a loose side or back panel after reading comments on the web I have checked the drum...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Aug 22, 2011 | LG DLE5955 Dryer
Fin on gas dryer loose.
The model number is generally inside the door or door jamb area. The top must be removed to access the drum to tighten the screws to the fin
Apr 15, 2010 | Maytag SDG4606A Gas Dryer
Fins inside drumare loose
Open the top ... held down with spring clips ... remove the front panel ... probably 2 to 4 screws ... be careful of the wires ... unplug the machine of course. Remove the drum ... but first observe the belt arrangement so you can reinstall. Tighten the 'fins'. Reverse the procedure.
You can use a pry or large screw driver to pop the top. Be careful of the finish.
Mar 21, 2010 | Dryers
Hi, We have a Neptune dryer that has lost all of its 3 fins.
yes this is to me, you have to take off the door, and panel, loose bolt that holds top to front panel and you will be able to turn the drum and reinstall baffles with screws, you may need to add a flat washer if the holes have stretched.
thanks
Aug 22, 2009 | Dryers
Sheets literally get burn marks
Look for a loose Tub Fin and tighten it if its loose.Also,If the dryer has bad drum supports than it will allow this problem to occur.Other than that visually inspect the inside area in dryer to see if there is some thing sticking up that is catching the item.
May 21, 2008 | Frigidaire GLER642A Electric Dryer
Dryers Logo
238 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
