Question about Refrigerators
We accidentally pushed in the manual defrost
We accidentally pushed in the automatic defrost button on the refrigerator that requires us to defrost it. is there any way to undo this?
2 Suggested Answers
huuum
  • 750 Answers
SOURCE: semi automatic defrost button won't pop up
The switch is broken and needs to be replaced.
This happens a lot
Huum
Please remember to leave feed back .
This is the answer.
click solve please1
Posted on Dec 09, 2008
Where is the defrost relay button?
Frigidaire equips most of its refrigerator models with automatic defrosting capabilities. This means that owners don't have to set a calendar reminder to manually defrost. The internal automatic defrost control and timing mechanism is placed at the bottom of most Frigidaire refrigerators, next to the stationary panicon1.png that captures water - even the defrosted meltwater is automatically evaporated. You might be confused about how the defrost timer works, thinking it is broken. Frigidaire understood this might be an issue for some owners and suggests double-checking the defroster for normal operation because it may not be malfunctioning at all.
Read more: http://www.ehow.com/how_12165725_troubleshooting-frigidaire-defrost-timer.html#ixzz32x8RyDGe
May 27, 2014 | Frigidaire Ffhs2622mh 26 Cu. Ft....
How do you manualy defrost?
Defrost the refrigerator when the frost accumulated on the evaporator is about 1/4" thick. To defrost, simply push the defrost button. Be sure to keep the drain pan in place. Defrosting usually takes a few hours. The refrigerator will restart automatically when defrosting ends. Empty water from the drain pan after defrosting.
Jun 18, 2011 | Magic Chef MCBR445W1 Compact Refrigerator
My GE Fridge PSS26SGRD has a moaning howling
The fan is hitting on ice buildup...unit is not defrosting...
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jul 12, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
What is the button in the middle of the temp gage? My refrigerator always seems to be too cold.
It is a defrost button. Defrost the refrigerator when the frost accumulated on the evaporator is about 1/4" thick. To defrost push the defrost button. Be sure to keep the drain pan in place. Defrosting usually takes a few hours. The refrigerator will restart when defrosting ends. Empty water from the drain pan after defrosting. (taken directly out of owners manual)
Jan 28, 2010 | Magic Chef MCBR440 Compact Refrigerator
Whats the push in button in the center of temp. conrtol knob, on the dorm size model?
On this model, the push button in the center of the temperature control is for starting a manual defrost cycle.
If you see ice building up on the evaporator (the freezer section), you just push the button and the fridge will stop the cooling cycle and initiate a defrost cycle to melt the ice.
The unit will automatically start cooling after the pre-determined defrost cycle time has elapsed.
Hope you find this Very Helpful and best regards!
Aug 22, 2009 | Magic Chef Refrigerators
I cant find the edit/ undo option on the toolbar
It's in the upper left corner, near the big round office button. It's a small arrow pointing to the left. But if you still can't find it, ctrl+z is the button combination for undo.
Jun 13, 2009 | Microsoft Office Professional 2007 Full...
Accidental defrost
I did the same thing. I know it's a little late now but for anyone that does this again here's what to do. There's a thermostat in your actual freezer you might not be able to see it, because it might be covered in ice. It looks like a tiny tube, To stop the defrosting all you have to do is warm up the thermostat either pressing a hot towel agaisnt it or meltling the ice with a dryer (but be careful)! After a minute or so the red button should pop out again and the refrigerator will start humming again. Unplugging the refrigerator will not reset anything and don't try to pop the red button out of your own!
Feb 27, 2009 | Danby Compact Refrigerator DCR-101W
Semi automatic defrost button won't pop up
This happens a lot
Huum
This is the answer.
click solve please1
Dec 09, 2008 | Refrigerators
Refrig/Freezer not getting cold
If there is frost on the back wall of the freezer section a defrost is required. Defrost is normally automatic on a timed cycle. If you have frost and you know it is because of the door being open to long with the refrigerator running it could clear the coil automatically in the next 12 hours of operation. If it does not clear the frost from the coil inside the back wall you may require service to check out the timing device, heaters, and defrost thermostat.
Mar 07, 2008 | GE Profile PSW26P Stainless Steel Side by...
Atlas frost refrigerator
Push in the red "Defrost Button" located in the center of the temperature control dial. Defrost cycle will start immediately. NOTE: Turning the temperature control dial to the OFF position is not required. Defrosting usually takes a few hours. When defrosting is complete, the red "Defrost Button" will release automatically. Then the refrigerator will resume normal operation while moving towards the set temperature. NOTE: After defrosting, allow a few hours to reach the set temperature before making any further adjustments.
Dec 30, 2007 | Atlas Refrigerators
Refrigerators Logo
556 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
